MT2-1215WI
MT2-1215WI
    KAGA
    DIP12 模块
    隔离模块 直流转换器 2 输出 15V -15V 65mA,65mA 10.8V - 13.2V 输入
MT2-1215WI 数据手册
MT2 2 WATT DC/DC CONVER TER, SINGLE & MULTIPLE OUTPUTS ELECTRICAL SPECIFICATIONS All specifications are typical at nominal input, full load INPUT SPECIFICATIONS Input Voltage.................................... ± 5% Input Filter........................................ PI-Network OUTPUT SPECIFICATIONS Output Voltage Accuracy................. ±5% Efficiency.......................................... 60% typ. Over-Current Protection...................Built-in (Automatic Recovery) Ripple ..............................................120 mVp-p (DC to 100MHZ) Line Regulation................................ ±0.5% Line Filter......................................... Built-in Load Regulation...............................±1.0% max. (Load Rate 0% ~ 100%) Spike Noise (DC to 100 MHZ).....................Input 150 mVp-p max. FEATURES FULL SMD DESIGN WITH CERAMIC CAPACITORS Output 70 mVp-p max. GENERAL SPECIFICATIONS 5 SIDED METAL CASE Isolation Voltage Primary to Secondary............... DC 500V/ 1min. 5mA Primary to Case........................ DC 500V/ 1min. 5mA Secondary to Case.................... DC 500V/ 1min. 5mA MTBF.............................................. >1,000,000 hours Isolation Resistance........................ INPUT-OUTPUT-CASE 50M-ohms min. (Measured at 500 VDC) EXTREMELY RELIABLE INTERNAL EMI FILTER LOW OUTPUT RIPPLE AND NOISE SHORT CIRCUIT PROTECTION DIRECT PCB-SOLDERING INDUSTRY STANDARD PINOUT (IC-24P) ENVIRONMENTAL SPECIFICATIONS Operating Temperature ................... -25 ~ +75˚C Temperature Coefficient...................±0.05%/ ˚C Humidity........................................... 30%~95% RH Storage Temperature....................... -25°C ~ +85°C LOW PROFILE, 10mm (0.39”) HEIGHT FIVE YEAR WARRANTY EMI Complys with: CISPR CLASS A PHYSICAL SPECIFICATIONS Case Material.....................................Nickel-Plated Steel Dual In-Line Pin Configuration 4 Series MODEL MT2-0505SI MT2-0512SI MT2-0515SI MT2-0512WI MT2-0515WI MT2-1205SI MT2-1212SI MT2-1212WI MT2-1215WI MT2-2405SI MT2-2412SI MT2-2412WI MT2-2415WI INPUT VOLTAGE OUTPUT VOLTAGE OUTPUT CURRENT 5 VDC 12 VDC 15 VDC –12 VDC –15 VDC 400mA 160mA 130mA –80mA –65mA 12 VDC (9 ~ 18V) 5 VDC 12 VDC –12 VDC –15 VDC 400mA 160mA –80mA –65mA 24 VDC (18 ~ 36V) 5 VDC 12 VDC –12 VDC –15 VDC 400mA 160mA –80mA –65mA 5 VDC (4.5 ~ 5.5V) TYPE A: SINGLE OUTPUT 1, 12, 11, 10, 2, 3, 24 13 14 15 23 22 TYPE A: DUALOUTPUT INPUT + V INPUT - V OUTPUT + V OUTPUT - V NC NC 1, 12, 11, 10, 2, 3, NOTE: All specifications typical and nominal / full load and 25˚C unless otherwise noted. Avoid sustained operation in overload or dead short conditions. Specifications subject to changes without notice. 5 24 13 14 15 23 22 INPUT + V INPUT - V OUTPUT1 + V OUTPUT1 - V OUTPUT2 + V OUTPUT2 - V • Dimensions in mm
MT2-1215WI 价格&库存
很抱歉,暂时无法提供与“MT2-1215WI”相匹配的价格&库存,您可以联系我们找货
