MT2
2 WATT DC/DC CONVER TER,
SINGLE & MULTIPLE OUTPUTS
ELECTRICAL SPECIFICATIONS
All specifications are typical at nominal input, full load
INPUT SPECIFICATIONS
Input Voltage.................................... ± 5%
Input Filter........................................ PI-Network
OUTPUT SPECIFICATIONS
Output Voltage Accuracy................. ±5%
Efficiency.......................................... 60% typ.
Over-Current Protection...................Built-in (Automatic Recovery)
Ripple ..............................................120 mVp-p (DC to 100MHZ)
Line Regulation................................ ±0.5%
Line Filter......................................... Built-in
Load Regulation...............................±1.0% max. (Load Rate 0% ~ 100%)
Spike Noise (DC to 100 MHZ).....................Input 150 mVp-p max.
FEATURES
FULL SMD DESIGN WITH CERAMIC CAPACITORS
Output 70 mVp-p max.
GENERAL SPECIFICATIONS
5 SIDED METAL CASE
Isolation Voltage
Primary to Secondary............... DC 500V/ 1min. 5mA
Primary to Case........................ DC 500V/ 1min. 5mA
Secondary to Case.................... DC 500V/ 1min. 5mA
MTBF.............................................. >1,000,000 hours
Isolation Resistance........................ INPUT-OUTPUT-CASE 50M-ohms min.
(Measured at 500 VDC)
EXTREMELY RELIABLE
INTERNAL EMI FILTER
LOW OUTPUT RIPPLE AND NOISE
SHORT CIRCUIT PROTECTION
DIRECT PCB-SOLDERING
INDUSTRY STANDARD PINOUT (IC-24P)
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature ................... -25 ~ +75˚C
Temperature Coefficient...................±0.05%/ ˚C
Humidity........................................... 30%~95% RH
Storage Temperature....................... -25°C ~ +85°C
LOW PROFILE, 10mm (0.39”) HEIGHT
FIVE YEAR WARRANTY
EMI
Complys with: CISPR CLASS A
PHYSICAL SPECIFICATIONS
Case Material.....................................Nickel-Plated Steel
Dual In-Line Pin Configuration
4
Series
MODEL
MT2-0505SI
MT2-0512SI
MT2-0515SI
MT2-0512WI
MT2-0515WI
MT2-1205SI
MT2-1212SI
MT2-1212WI
MT2-1215WI
MT2-2405SI
MT2-2412SI
MT2-2412WI
MT2-2415WI
INPUT VOLTAGE
OUTPUT VOLTAGE OUTPUT CURRENT
5 VDC
12 VDC
15 VDC
–12 VDC
–15 VDC
400mA
160mA
130mA
–80mA
–65mA
12 VDC
(9 ~ 18V)
5 VDC
12 VDC
–12 VDC
–15 VDC
400mA
160mA
–80mA
–65mA
24 VDC
(18 ~ 36V)
5 VDC
12 VDC
–12 VDC
–15 VDC
400mA
160mA
–80mA
–65mA
5 VDC
(4.5 ~ 5.5V)
TYPE A: SINGLE OUTPUT
1,
12,
11,
10,
2,
3,
24
13
14
15
23
22
TYPE A: DUALOUTPUT
INPUT + V
INPUT - V
OUTPUT + V
OUTPUT - V
NC
NC
1,
12,
11,
10,
2,
3,
NOTE:
All specifications typical and nominal / full load and 25˚C unless otherwise noted.
Avoid sustained operation in overload or dead short conditions.
Specifications subject to changes without notice.
5
24
13
14
15
23
22
INPUT + V
INPUT - V
OUTPUT1 + V
OUTPUT1 - V
OUTPUT2 + V
OUTPUT2 - V
• Dimensions in mm
很抱歉,暂时无法提供与“MT2-0505SI”相匹配的价格&库存,您可以联系我们找货
