SPN50-12S
SPN50-12S
    KAGA
    封闭式 AC DC 转换器 1 输出 12V 85 ~ 264 VAC 输入
SPN50-12S 数据手册
SPN50 Series 50 WATT, Universal Input Fully Enclosed Switching Power Supply ELECTRICAL SPECIFICATIONS All specifications are typical at nominal input, full load INPUT SPECIFICATIONS Input Voltage………..........................85 ~ 264VAC Input Frequency............................... 47 ~ 63Hz Input Current………………………….0.55 ~ 1.0A Typ. Inrush Current 16A ~ 39A Typ OUTPUT SPECIFICATIONS FEATURES 50 WATT OUTPUT POWER UNIVERSAL INPUT OVERVOLTAGE PROTECTION OVERCURRENT PROTECTION Output Voltage ……………………….See Chart Voltage Adjustment.………………….±10% Minimum Load……………………….. 0A Efficiency..................................……..75 ~ 80% Over-Voltage Protection...…………..115 ~ 150% Manual Reset Over-Current Protection………….....Automatic Recovery (105% min) Ripple and Noise…………………….100mVp-p max. Hold-Up Time.......................…….....40 ~ 50 mS Line/Load Regulation...............…… See Chart Rise Time...…...……………………...800 ~ 1700 mS Leakage Current (100/230VAC)………….0.75mA LIGHTWEIGHT CONSTRUCTION GENERAL SPECIFICATIONS METAL CHASSIS WITH COVER COMPACT, LOW-PROFILE PACKAGES 3 YEAR WARRANTY MTBF.............................…………….>160,000 Hours Isolation Voltage Primary to Secondary……………3000VAC Primary to Case………………….1500VAC Secondary to Case………………500VAC Isolation Resistance………………….100 M-Ohms min. ENVIRONMENTAL SPECIFICATIONS SAFETIES/APPROVALS UL/cUL CE CB Operating Temperature ............…….0°C ~ +60°C Cooling………………….....................Convection Temperature Coefficient................... 0.02% / °C Humidity………………......................20 ~ 85%Rh (non-condensing) Storage Temperature………………..-20°C ~ +85°C Shock Vibration………………………Shock: 20G(3 Directions each 3 times) Vibration: 10 ~ 55Hz PHYSICAL SPECIFICATIONS Metal Enclosed – Terminal Block 1 MODEL Output Voltage Output Current (85 ~ 264 VAC) SPN50-05S SPN50-12S SPN50-15S SPN50-24S SPN50-48S Note: • • • • • 5VDC 12VDC 15VDC 24VDC 48VDC 10A 4.2A 3.4A 2.1A 1.1A Efficiency (%) 75% 78% 79% 80% 80% Mounting screws not to exceed max penetration of 6mm Screw thread size is M3 (Metric) or 6/32nd (Inch) Weight 200g typ. Measurements in millimeter (mm) unless otherwise specified Tolerance ± 1mm NOTE: All specifications typical and nominal / full load and 25°C unless otherwise noted. Avoid sustained operation in overload or dead short conditions. Specifications subject to changes without notice. 2 Load Regulation (mV max) 10mV max 10mV max 10mV max 20mV max 40mV max
SPN50-12S 价格&库存
很抱歉,暂时无法提供与“SPN50-12S”相匹配的价格&库存,您可以联系我们找货
