VTB12SC24-O
VTB12SC24-O
    KAGA
    DC/DC CONVERTER 12V 50W
VTB12SC24-O 数据手册
Volgen Kaga Electronics (USA) Inc. www.volgen.com VTB**SC**-O Series 50 Watt DC/DC Power Supply Available Inputs: 12VDC Nom (DC9~18V) 24VDC Nom (DC 19~36V) 48 VDC NOM (DC 38 ~ 63 V) 110 VDC NOM (DC 85~160V) PART No. Description: VTB__SC__-O 2 Year Warranty INPUT Nom Voltage (Range) Current Typ. Inrush Current Leakage OUTPUT ISOLATION Environment UNIT V A VTB**SC24-O DC 12V (9~18) 8.0 VTB**SC48-O DC 24V (19~36) 3.8 A VTB**SC110-O DC 48 (38~63) 2.0 DC 110V (85~160 0.85 40 ( Ta=25℃ , Io=100% at cold Start ) mA Nominal Voltage VDC Voltage Range Current Total Pwr Efficiency Line Regulation Load Regulation Ripple Ripple Noise Maximum Temp Drift Rise Time Hold up Time OVP OCP Cooling VDC A W % mV mV mVp-p mVp-p mV mS mS V A 3.5 VTB05SC**-O 5 4.95 ~ 5.05 10 50 70 25 50 50 100 75 5.75~7.0 11.0~13.0 VTB12SC**-O 12 11.88~12.12 4.2 50.4 75 60 120 120 170 VTB15SC**-O 15 VTB24SC**-O 14.85~15.15 3.4 51 78 75 150 150 200 180 225 500 max [DC IN 9V I₀ =100%] 10 typ [DC IN 9V,I₀ =100%] 13.8-16.8 17.25~21.0 4.6~5.5 3.7~4.4 Convection Input – Output Input – F.G AC 1.5KV 1 min, cut-off: 20 mA / DC 500V 100MΩ AC 1.5KV 1 min, cut-off: 20 mA / DC 500V 100MΩ Output -F.G AC 500V 1 minute cut-off: 100mA, DC 500V 100MΩ Operating temp Storage WxHxL www.volgen.com 24 23.76~24.24 2.5 60 80 120 240 240 290 360 26.4~33.6 2.8~3.3 -10 ~ +50℃, 20 ~ 90% RH(Non condensing) -10 ~ +70℃, 20 ~ 90% RH(Non condensing) Vibration Dimension VTB**SC12-O Output Voltage Input Voltage (nominal) 10 ~ 55Hz at 1G, 3 minutes period, 30 minutes along X, Y and Z axis mm/g 97x37x178 / 400 Phone:408-570-4205 Fax:408-570-0186 Volgen Kaga Electronics (USA) Inc. BLOCK DIAGRAM Terminal Output Mark www.volgen.com +Vin Pin Connection DC Input (+) -VIN F.G DC Output (-) Frame Ground +V -V DC Output (+) DC Output (-) Phone:408-570-4205 Function DC Input Terminal (+) Fuse In Line DC Input Terminal (-) DC Ground Terminal/ Chassis Ground DC Output Terminal (+) DC Output Terminal (-) Fax:408-570-0186 Volgen Kaga Electronics (USA) Inc. DIMENSIONAL DRAWING (mm) www.volgen.com Phone:408-570-4205 Fax:408-570-0186 OUTPUT DERATING CURVE AND RECCOMENDED MOUNTING DIAGRAM www.volgen.com Phone:408-570-4205 Fax:408-570-0186
VTB12SC24-O 价格&库存
很抱歉,暂时无法提供与“VTB12SC24-O”相匹配的价格&库存,您可以联系我们找货
