2000-2207/099-000
2000-2207/099-000
    WAGO(万可电子)
    DOUBLE-DECK TERMINAL BLOCK; 4-CO
2000-2207/099-000 数据手册
Data sheet | Item number: 2000-2207/099-000 Double-deck terminal block; 4-conductor ground terminal block; with end plate; 1 mm²; PE; without marker carrier; internal commoning; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 1,00 mm²; green-yellow www.wago.com/2000-2207/099-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Data Electrical data Ratings per IEC/EN 60947-7-2 Connection data Total number of connection points 4 Total number of potentials 2 Number of levels 2 Number of jumper slots 3 Connection technology Push-in CAGE CLAMP® Actuation type Push-in Operating tool Connectable conductor materials Copper Nominal cross-section 1 mm² Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Solid conductor; push-in termination 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.14 … 0.75 mm² / 24 … 18 AWG Fine-stranded conductor; with ferrule; push-in termination 0.5 … 0.75 mm² / 20 … 18 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 9 … 11 mm / 0.35 … 0.43 inch Wiring direction Front-entry wiring Physical data Width 4.2 mm / 0.165 inch Height 69.7 mm / 2.744 inch Depth from upper edge of DIN-rail 51.7 mm / 2.035 inch Mechanical data Potentialkennzeichnung PE Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Material data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Material data Color green-yellow Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.209 MJ Weight 11.8 g Commercial data Product Group 22 (TOPJOB S) PU (SPU) 50 Stück Packaging type box Country of origin DE GTIN 4050821037583 Customs tariff number 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 E185892 ATEX Physikalisch Technische Bundesanstalt EN 60079 PTB 11 ATEX 1041 U (II 2 G Ex eb IIC Gb bzw. I M 2 Ex eb I Mb) CCCEx CQST/CNEx CNCA-C23-01 2020312313000182 EAC Brjansker Zertifizierungsstelle TP TC 012/2011 RU C-DE.AM02.B. 00127/19 IECEx Physikalisch Technische Bundesanstalt IEC 60079 IECEx PTB 11.0093 U (Ex e IIC Gb or Ex e I Mb) Country specific Approvals Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 71102841 CCA DEKRA Certification B.V. EN 60947 NTR NL 7671 Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Optional accessories Protective warning marker     Cover Item no.: 2001-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2001-115 Push-in type wire jumper     Jumper Item no.: 2009-404 Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; gray www.wago.com/2009-404 Item no.: 2009-402 Push-in type wire jumper; 0.75 mm²; insulated; 60 mm long; gray www.wago.com/2009-402 Item no.: 2009-406 Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; gray www.wago.com/2009-406 Testing and measuring     Testing accessories Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray Item no.: 2009-182 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-174 www.wago.com/2009-182 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Ferrule     Ferrule Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Jumpers     Jumper Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 2001-402 Jumper; 2-way; insulated; light gray www.wago.com/2001-402 Item no.: 2001-403 Jumper; 3-way; insulated; light gray www.wago.com/2001-403 Item no.: 2001-405 Jumper; 5-way; insulated; light gray www.wago.com/2001-405 Item no.: 2001-406/020-000 Delta jumper; insulated; light gray www.wago.com/2001-406 /020-000 Item no.: 2001-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2001-405 /011-000 Item no.: 2001-407 Jumper; 7-way; insulated; light gray www.wago.com/2001-407 Item no.: 2001-409 Jumper; 9-way; insulated; light gray www.wago.com/2001-409 Item no.: 2001-406 Jumper; 6-way; insulated; light gray www.wago.com/2001-406 Item no.: 2001-404 Jumper; 4-way; insulated; light gray www.wago.com/2001-404 Item no.: 2001-410 www.wago.com/2001-410 Jumper; 10-way; insulated; light gray Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Jumper; 10-way; insulated; light gray Item no.: 2001-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2001-433 Item no.: 2001-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2001-435 Item no.: 2001-408 Jumper; 8-way; insulated; light gray www.wago.com/2001-408 Item no.: 2001-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2001-437 Item no.: 2001-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2001-436 Item no.: 2001-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2001-440 Item no.: 2001-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2001-438 Item no.: 2001-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2001-434 Item no.: 2001-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2001-439 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Marking accessories     Marking strip Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110     Marker carrier Item no.: 2000-121 Adaptor; gray www.wago.com/2000-121 Item no.: 2009-114/000-002 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/2009-114 /000-002 Item no.: 2009-114/000-005 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/2009-114 /000-005     Marker Item no.: 2009-114/000-007 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Item no.: 2009-114/000-007 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/2009-114 /000-007 Item no.: 2009-114/000-023 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/2009-114 /000-023 Item no.: 2009-114/000-006 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/2009-114 /000-006 Item no.: 2009-114/000-024 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/2009-114 /000-024 Item no.: 2009-114/000-012 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/2009-114 /000-012 Item no.: 2009-114 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/2009-114 Item no.: 793-4501/000-002 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/793-4501 /000-002 Item no.: 793-4501/000-006 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/793-4501 /000-006 Item no.: 793-4501/000-014 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; brown www.wago.com/793-4501 /000-014 Item no.: 793-4501 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/793-4501 Item no.: 793-4501/000-023 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; light green www.wago.com/793-4501 /000-023 Item no.: 793-4501/000-024 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/793-4501 /000-024 Item no.: 793-4501/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/793-4501 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Item no.: 793-4501/000-005 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/793-4501 /000-005 Item no.: 793-4501/000-007 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/793-4501 /000-007 Item no.: 793-4501/000-012 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/793-4501 /000-012 Item no.: 793-4501/000-017 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/793-4501 /000-017 Mounting     Mounting accessories Item no.: 709-156 Cover; Type 3; suitable for cover carrier, type 3; 1 m long; transparent www.wago.com/709-156 Item no.: 709-169 Cover carrier; Type 3; gray www.wago.com/709-169 Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Tool     Operating tool Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured www.wago.com/210-647 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Documentation Bid Text 2000-2207/099-000 Feb 19, 2019 xml 3.8 kB Download Aug 7, 2018 docx 15.0 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download EPLAN Data Portal 2000-2207/099-000 URL Download WSCAD Universe 2000-2207/099-000 URL Download ZUKEN Portal 2000-2207/099-000 URL Download X81 - Datei 2000-2207/099-000 docx - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 2000-2207/099-000 CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 WSCAD Universe 2000-2207/099-000 URL Download EPLAN Data Portal 2000-2207/099-000 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 2000-2207/099-000 Double-deck terminal block; 4-conductor ground terminal block; with end plate; 1 mm²; PE; without marker carrier; internal commoning; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 1,00 mm²; green-yellow Installation Notes Conductor termination All conductor types at a glance Push-in termination of solid and ferruled conductors Inserting a conductor via operating tool: Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. Advantage: To open the clamp, the operating tool is inserted vertically. The conductor entry is less than 15 degrees for easier wiring. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 10/11 Data sheet | Item number: 2000-2207/099-000 www.wago.com/2000-2207/099-000 Inserting a conductor via push-in termination: Conductor termination – insulation stop Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Marking Snapping WMB Inline markers into marker slots. Double-Deck Terminal Blocks A double-deck marker carrier (2000-121) can be retrofitted to double-deck terminal blocks without a marker carrier. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 11/11
2000-2207/099-000 价格&库存
很抱歉,暂时无法提供与“2000-2207/099-000”相匹配的价格&库存,您可以联系我们找货
