2000-5352
2000-5352
    WAGO(万可电子)
    端子块连接器 8 位置 馈通,隔离式(2) 橙色 16-24AWG
2000-5352 数据手册
Data sheet | Item number: 2000-5352 3-conductor sensor supply terminal block; for PNP (positive) switching sensors; Power supply from control panel side; with colored conductor entries; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; orange www.wago.com/2000-5352 Color: Item description 3.5 mm spacing per signal (2 x 3.5 mm = 7 mm) The double spacing per pole of this terminal block series maximizes connectivity. For example, ten sensors may be connected using only five Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 The double spacing per pole of this terminal block series maximizes connectivity. For example, ten sensors may be connected using only five sensor terminal blocks plus a power supply terminal block. Data Electrical data Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 250 V Rated current 28 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 20 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 20 A Approvals per C22.2 No 158 Rated voltage CSA (Use Group C) 300 V Rated current CSA (Use Group C) 20 A Connection data Total number of connection points 8 Total number of potentials 2 Number of levels 3 Number of jumper slots 2 Solid conductor 2 0.25 … 4 mm² / 22 … 12 AWG Solid conductor, push-in termination 2 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor 2 0.25 … 4 mm² / 22 … 12 AWG Connection technology Push-in CAGE CLAMP® Actuation type Push-in Operating tool Connectable conductor materials Copper Nominal cross-section 1 mm² Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Solid conductor; push-in termination 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.14 … 0.75 mm² / 24 … 18 AWG Fine-stranded conductor; with ferrule; push-in termination 0.5 … 0.75 mm² / 20 … 18 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 smaller cross-section can also be inserted via push-in termination. Strip length 9 … 11 mm / 0.35 … 0.43 inch Wiring direction Front-entry wiring Physical data Width 7 mm / 0.276 inch Height 81.1 mm / 3.193 inch Depth from upper edge of DIN-rail 49.4 mm / 1.945 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Material data Color orange Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.314 MJ Weight 15.8 g Commercial data PU (SPU) 15 Stück Packaging type box Country of origin DE GTIN 4055143497121 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 71102841 CCA EN 60947 NTR NL DEKRA Certification B.V. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 7671 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 DEKRA Certification B.V. 7671 CSA DEKRA Certification B.V. C22.2 2130762 Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Required accessories End plate     End plate Item no.: 2000-5391 End and intermediate plate; 1 mm thick; for 3-conductor terminal blocks; gray www.wago.com/2000-5391 Optional accessories Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Protective warning marker     Cover Item no.: 2000-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2000-115 Testing and measuring     Testing accessories Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 2000-408 Jumper; 8-way; insulated; light gray www.wago.com/2000-408 Item no.: 2000-407 Jumper; 7-way; insulated; light gray www.wago.com/2000-407 Item no.: 2000-409 Jumper; 9-way; insulated; light gray www.wago.com/2000-409 Item no.: 2000-408/000-006 Jumper; 8-way; insulated; blue www.wago.com/2000-408 /000-006 Item no.: 2000-408/000-005 Jumper; 8-way; insulated; red www.wago.com/2000-408 /000-005 Item no.: 2000-409/000-005 Jumper; 9-way; insulated; red www.wago.com/2000-409 /000-005 Jumpers     Jumper Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Item no.: 2000-407/000-006 Jumper; 7-way; insulated; blue www.wago.com/2000-407 /000-006 Item no.: 2000-410 Jumper; 10-way; insulated; light gray www.wago.com/2000-410 Item no.: 2000-410/000-006 Jumper; 10-way; insulated; blue www.wago.com/2000-410 /000-006 Item no.: 2000-433/000-005 Jumper; from 1 to 3; insulated; red www.wago.com/2000-433 /000-005 Item no.: 2000-407/000-005 Jumper; 7-way; insulated; red www.wago.com/2000-407 /000-005 Item no.: 2000-433/000-006 Jumper; from 1 to 3; insulated; blue www.wago.com/2000-433 /000-006 Item no.: 2000-410/000-005 Jumper; 10-way; insulated; red www.wago.com/2000-410 /000-005 Item no.: 2000-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2000-435 Item no.: 2000-409/000-006 Jumper; 9-way; insulated; blue www.wago.com/2000-409 /000-006 Item no.: 2000-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2000-436 Item no.: 2000-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2000-433 Item no.: 2000-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2000-434 Item no.: 2000-402 Jumper; 2-way; insulated; light gray www.wago.com/2000-402 Item no.: 2000-402/000-006 Jumper; 2-way; insulated; blue www.wago.com/2000-402 /000-006 Item no.: 2000-403 www.wago.com/2000-403 Jumper; 3-way; insulated; light gray Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Jumper; 3-way; insulated; light gray Item no.: 2000-402/000-005 Jumper; 2-way; insulated; red www.wago.com/2000-402 /000-005 Item no.: 2000-402/000-018 Jumper; 2-way; insulated; yellow-green www.wago.com/2000-402 /000-018 Item no.: 2000-404 Jumper; 4-way; insulated; light gray www.wago.com/2000-404 Item no.: 2000-403/000-005 Jumper; 3-way; insulated; red www.wago.com/2000-403 /000-005 Item no.: 2000-404/000-006 Jumper; 4-way; insulated; blue www.wago.com/2000-404 /000-006 Item no.: 2000-403/000-006 Jumper; 3-way; insulated; blue www.wago.com/2000-403 /000-006 Item no.: 2000-404/000-005 Jumper; 4-way; insulated; red www.wago.com/2000-404 /000-005 Item no.: 2000-405 Jumper; 5-way; insulated; light gray www.wago.com/2000-405 Item no.: 2000-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2000-405 /011-000 Item no.: 2000-405/000-006 Jumper; 5-way; insulated; blue www.wago.com/2000-405 /000-006 Item no.: 2000-406/000-006 Jumper; 6-way; insulated; blue www.wago.com/2000-406 /000-006 Item no.: 2000-405/000-005 Jumper; 5-way; insulated; red www.wago.com/2000-405 /000-005 Item no.: 2000-406 Jumper; 6-way; insulated; light gray www.wago.com/2000-406 Item no.: 2000-406/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Item no.: 2000-406/000-005 Jumper; 6-way; insulated; red www.wago.com/2000-406 /000-005 Item no.: 2000-406/020-000 Delta jumper; insulated; light gray www.wago.com/2000-406 /020-000 Item no.: 2000-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2000-437 Item no.: 2000-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2000-438 Item no.: 2000-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2000-439 Item no.: 2000-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2000-440 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Tool     Operating tool Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured www.wago.com/210-647 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Push-in type wire jumper     Jumper Item no.: 2009-404 Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; gray www.wago.com/2009-404 Item no.: 2009-402 Push-in type wire jumper; 0.75 mm²; insulated; 60 mm long; gray www.wago.com/2009-402 Item no.: 2009-406 Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; gray www.wago.com/2009-406 Marking accessories     Marking strip Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110     Marker Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352     Marker Item no.: 2009-113 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white www.wago.com/2009-113 Item no.: 2009-113/000-002 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; yellow www.wago.com/2009-113 /000-002 Item no.: 2009-113/000-012 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; orange www.wago.com/2009-113 /000-012 Item no.: 2009-113/000-007 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; gray www.wago.com/2009-113 /000-007 Item no.: 2009-113/000-005 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; red www.wago.com/2009-113 /000-005 Item no.: 2009-113/000-017 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; light green www.wago.com/2009-113 /000-017 Item no.: 2009-113/000-006 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; blue www.wago.com/2009-113 /000-006 Item no.: 2009-113/000-024 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; violet www.wago.com/2009-113 /000-024 Item no.: 2009-113/000-023 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; green www.wago.com/2009-113 /000-023 Item no.: 793-3501 WMB marking card; as card; plain; snap-on type; white www.wago.com/793-3501 Mounting     Mounting accessories Item no.: 709-156 Cover; Type 3; suitable for cover carrier, type 3; 1 m long; transparent www.wago.com/709-156 Item no.: 709-169 Cover carrier; Type 3; gray www.wago.com/709-169 Ferrule     Ferrule Item no.: 216-241 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Downloads Documentation Bid Text 2000-5352 Aug 7, 2018 docx 15.4 kB Download Feb 19, 2019 xml 4.0 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download EPLAN Data Portal 2000-5352 URL Download ZUKEN Portal 2000-5352 URL Download URL Download docx - Datei 2000-5352 X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 2000-5352 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 2000-5352 3-conductor sensor supply terminal block; for PNP (positive) switching sensors; Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 10/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 3-conductor sensor supply terminal block; for PNP (positive) switching sensors; Power supply from control panel side; with colored conductor entries; 2.5 mm²; Pushin CAGE CLAMP®; 2,50 mm²; orange Installation Notes Conductor termination All conductor types at a glance Commoning Commoning (signal level): Upper level: Two independent signal pathways Commoning the signal level with push-in type jumper bars (2000 Series). Models with an LED can only be commoned in one jumper slot! TOPJOB® S Test Plug Adapters can be used in all jumper slots. Commoning Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 11/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Commoning (potential level): Commoning (potential level): Commoning potential levels via push-in type jumper bars (2000 Series). Potential levels: Two adjacent commoning options on a current bar Continuous commoning in the potential levels via push-in type jumper bars for even pole numbers (2000 Series) Commoning Ground commoning: For example, colored push-in type jumper bars are used with sensor terminal blocks. For sensor and actuator terminal blocks without ground connection to the DIN-rail, the ground connection can be performed by commoning to the terminal block with a ground foot. Testing Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 12/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Testing via testing tap (2009-182) (up to max. 42 V). Testing via testing tap (2009-174) (up to max. 42 V). Application Supply: Orange supply terminal block of same profile with a power supply option from both the cabinet and sensor sides Terminal block assembly with 4-conductor sensor terminal blocks and 3-conductor actuator terminal blocks Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 13/14 Data sheet | Item number: 2000-5352 www.wago.com/2000-5352 Marking: Marking: 3.5 mm WMB markers (793-35xx) from the top or the side – additional marking option via marker carrier Labeling via marking strips (2009‑110) – from the top or the side. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 14/14
2000-5352
物料型号:2000-5352
器件简介:这是一个3极传感器供电端子排,适用于PNP(正)开关传感器,电源从控制面板侧提供,具有彩色导线入口,2.5 mm²,Push-in CAGE CLAMP®连接技术,橙色。
引脚分配:该端子排具有8个连接点,2个总电位,3个层级,2个跳线槽。
参数特性: - 额定电压(Il/3):250V - 额定电流:28A - 根据IEC/EN60947-7-1标准,具有过电压类别III/污染等级3的标识。 - 符合UL1059标准的额定电压(使用组B):300V,额定电流:20A。 - 符合C22.2 No 158标准的额定电压(CSA,使用组C):300V,额定电流:20A。
功能详解:该端子排系列的每个极点双间距最大化了连接性,例如,可以使用5个传感器端子排加上1个电源端子排连接10个传感器。
应用信息:适用于多种工业应用和现代建筑安装,WAGO的TOPJOB® S系列端子排提供可靠的电气连接。
封装信息: - 宽度:7 mm/0.276 inch - 高度:81.1 mm/3.193 inch - 从DIN轨道上边缘的深度:49.4 mm/1.945 inch - 材料:聚酰胺(PA66),阻燃等级UL94:VO - 重量:15.8g
2000-5352 价格&库存
很抱歉,暂时无法提供与“2000-5352”相匹配的价格&库存,您可以联系我们找货
    • 1+767.85387
    库存:5
    2000-5352
      • 1+1646.79213
      库存:5
