Data sheet | Item number: 2020-215/000-039
2-conductor female connector; Push-in CAGE CLAMP®; 1.5 mm²; Pin
spacing 3.5 mm; 15-pole; 1,50 mm²; green-yellow, blue, gray
www.wago.com/2020-215/000-039
i
Picture differs from the item.
Color:
Data
Notes
Safety information 1
According to EN 61984, pluggable connectors without current
interrupting capacity must not be mated or unmated when live or
under load.
Safety information 2
Notice: An appropriate end plate must be applied to the carrier
terminal blocks after each female plug.
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
14.10.2021 Page 1/6
15 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
15 A
Approvals per
C22.2 No 158
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group C)
300 V
Rated current CSA (Use Group C)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 61984
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
13.5 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
30
Total number of potentials
15
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Push-in
Connectable conductor materials
Copper
Nominal cross-section
1 mm²
Solid conductor
0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor; push-in termination
0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.14 … 0.75 mm² / 24 … 18 AWG
Fine-stranded conductor; with ferrule; push-in termination
0.5 … 0.75 mm² / 20 … 18 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
9 … 11 mm / 0.35 … 0.43 inch
Pole No.
15
Wiring direction
Front-entry wiring
Hansastr. 27
32423 Minden
14.10.2021 Page 2/6
Physical data
Width
53.2 mm / 2.094 inch
Height
40.5 mm / 1.594 inch
Depth
25 mm / 0.984 inch
Module width
3.5 mm / 0.138 inch
Mechanical data
Marking level
Side marking
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Material data
Color
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.675 MJ
Weight
40.8 g
Commercial data
Product Group
18 (X-COM-System)
PU (SPU)
10 Stück
Packaging type
box
Country of origin
DE
GTIN
4050821222095
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
Certificate
name
NTR NL
7617
Hansastr. 27
32423 Minden
14.10.2021 Page 3/6
UL-Approvals
Logo
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
Optional accessories
Ferrule
Ferrule
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Strain relief
Strain relief plate
Item no.: 734-326
Strain relief plate; gray
www.wago.com/734-326
Marking accessories
Marker
Item no.: 2009-113
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white
www.wago.com/2009-113
Item no.: 793-3501
WMB marking card; as card; plain; snap-on type; white
www.wago.com/793-3501
Tool
Operating tool
Item no.: 210-648
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short
www.wago.com/210-648
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-647
Item no.: 210-719
Hansastr. 27
32423 Minden
www.wago.com/210-719
14.10.2021 Page 4/6
Protective warning marker
Cover
Item no.: 2000-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2000-115
Locking levers
Locking device
Item no.: 2022-151
Locking lever; gray
www.wago.com/2022-151
Item no.: 2022-152
Locking lever; orange
www.wago.com/2022-152
Downloads
Documentation
Bid Text
2020-215/000-039
Feb 19, 2019
xml
4.1 kB
Download
Aug 7, 2018
docx
15.7 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 2020-215/000-039
URL
Download
WSCAD Universe 2020-215/000-039
URL
Download
ZUKEN Portal 2020-215/000-039
URL
Download
URL
Download
X81 - Datei
2020-215/000-039
docx - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 2020-215/000-039
CAE data
Hansastr. 27
32423 Minden
14.10.2021 Page 5/6
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2020-215/000-039
2-conductor female connector; Push-in CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm;
Installation Notes
Coding
Insert coding pin into the corresponding slot
and twist it off.
Coding a female plug: remove coding finger
using a suitable tool.
Insert coded female plug into X-COM®SSYSTEM terminal block assembly.
Product family
X-COM S-Mini
Show all products from the family
Hansastr. 27
32423 Minden
14.10.2021 Page 6/6
很抱歉,暂时无法提供与“2020-215/000-039”相匹配的价格&库存,您可以联系我们找货
