2002-3203
2002-3203
    WAGO(万可电子)
    端子块连接器 6 位置 馈通式 灰色 12-22 AWG
2002-3203 数据手册
Data sheet | Item number: 2002-3203 Triple-deck terminal block; Through/through/through terminal block; L/L/N; without marker carrier; suitable for Ex e II applications; Blue conductor entry upper deck; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2002-3203 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Data Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 20 A Rated voltage UL (Use Group C) 300 V Rated current UL (Use Group C) 20 A Rated voltage UL (Use Group D) 600 V Rated current UL (Use Group D) 5  A Approvals per C22.2 No 158 Rated voltage CSA (Use Group B) 600 V Rated current CSA (Use Group B) 20 A Rated voltage CSA (Use Group C) 600 V Rated current CSA (Use Group C) 20 A Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 500 V Rated surge voltage (III/3) 6 kV Rated current 24 A Rated current 2 28 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Ratings per ATEX: PTB 03 ATEX 1162 U / IECEx: PTB 03.0004U (Ex eb IIC Gb) Rated voltage EN (Ex e II) 440 V Rated current (Ex e II) 19 A Rated current (Ex e II) with jumper 17 A Connection data Total number of connection points 6 Total number of potentials 3 Number of levels 3 Number of jumper slots 6 Number of connection points 2 3 Connection technology Push-in CAGE CLAMP® Number of connection points 3 Actuation type Push-in Operating tool Connectable conductor materials Copper Nominal Subject to cross-section changes. Please also observe the further product documentation!2.5 mm² WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Connectable conductor materials Copper Nominal cross-section 2.5 mm² Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor; push-in termination 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor; with ferrule; push-in termination 1 … 2.5 mm² / 18 … 14 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 10 … 12 mm / 0.39 … 0.47 inch Wiring direction Front-entry wiring Physical data Width 5.2 mm / 0.205 inch Height 93.3 mm / 3.673 inch Depth from upper edge of DIN-rail 69.5 mm / 2.736 inch Mechanical data Potentialkennzeichnung L/L/N Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Material data Color gray Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.316 MJ Weight 16.8 g Commercial data Product Group 22 (TOPJOB S) PU (SPU) 50 Stück Packaging type box Country of origin DE GTIN 4044918691192 Customs tariff number 85369010000 Approvals / Certificates Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 E185892 ATEX Physikalisch Technische Bundesanstalt (PTB) EN 60079 PTB 03 ATEX 1162 U (II 2 G Ex eb IIC Gb bzw. I M 2 Ex eb I Mb) CCCEx CQST/CNEx CNCA-C23-01 2020312313000238 EAC Brjansker Zertifizierungsstelle TP TC 012/2011 RU C-DE.AM02.B. 00127/19 Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 71107687 CCA DEKRA Certification B.V. EN 60947 NTR NL 7730 CCA DEKRA Certification B.V. C22.2 No. 158 1536069 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 20HG1941090PDA BV EN 60947 Subject to changes. Please also observe the further product documentation! 38586/A0 BV WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 BV Bureau Veritas S.A. EN 60947 38586/A0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 Required accessories End plate     End plate Item no.: 2002-3292 End and intermediate plate; 0.8 mm thick; orange www.wago.com/2002-3292 Item no.: 2002-3291 End and intermediate plate; 0.8 mm thick; gray www.wago.com/2002-3291 Optional accessories Jumpers     Jumper Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 2002-402 Jumper; 2-way; insulated; light gray www.wago.com/2002-402 Item no.: 2002-402/000-005 Jumper; 2-way; insulated; red www.wago.com/2002-402 /000-005 Item no.: 2002-400 Continuous jumper; 2-way; insulated; light gray www.wago.com/2002-400 Item no.: 2002-403 Jumper; 3-way; insulated; light gray www.wago.com/2002-403 Item no.: 2002-404/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2002-404 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Item no.: 2002-404/000-005 Jumper; 4-way; insulated; red www.wago.com/2002-404 /000-005 Item no.: 2002-403/000-006 Jumper; 3-way; insulated; blue www.wago.com/2002-403 /000-006 Item no.: 2002-404/000-006 Jumper; 4-way; insulated; blue www.wago.com/2002-404 /000-006 Item no.: 2002-403/000-005 Jumper; 3-way; insulated; red www.wago.com/2002-403 /000-005 Item no.: 2002-405/000-005 Jumper; 5-way; insulated; red www.wago.com/2002-405 /000-005 Item no.: 2002-402/000-006 Jumper; 2-way; insulated; blue www.wago.com/2002-402 /000-006 Item no.: 2002-405/000-006 Jumper; 5-way; insulated; blue www.wago.com/2002-405 /000-006 Item no.: 2002-404 Jumper; 4-way; insulated; light gray www.wago.com/2002-404 Item no.: 2002-406/000-006 Jumper; 6-way; insulated; blue www.wago.com/2002-406 /000-006 Item no.: 2002-406/000-005 Jumper; 6-way; insulated; red www.wago.com/2002-406 /000-005 Item no.: 2002-406/020-000 Delta jumper; insulated; light gray www.wago.com/2002-406 /020-000 Item no.: 2002-405 Jumper; 5-way; insulated; light gray www.wago.com/2002-405 Item no.: 2002-407/000-005 Jumper; 7-way; insulated; red www.wago.com/2002-407 /000-005 Item no.: 2002-408 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Item no.: 2002-408 Jumper; 8-way; insulated; light gray www.wago.com/2002-408 Item no.: 2002-408/000-006 Jumper; 8-way; insulated; blue www.wago.com/2002-408 /000-006 Item no.: 2002-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2002-405 /011-000 Item no.: 2002-407/000-006 Jumper; 7-way; insulated; blue www.wago.com/2002-407 /000-006 Item no.: 2002-408/000-005 Jumper; 8-way; insulated; red www.wago.com/2002-408 /000-005 Item no.: 2002-407 Jumper; 7-way; insulated; light gray www.wago.com/2002-407 Item no.: 2002-406 Jumper; 6-way; insulated; light gray www.wago.com/2002-406 Item no.: 2002-410/000-005 Jumper; 10-way; insulated; red www.wago.com/2002-410 /000-005 Item no.: 2002-410/000-006 Jumper; 10-way; insulated; blue www.wago.com/2002-410 /000-006 Item no.: 2002-410 Jumper; 10-way; insulated; light gray www.wago.com/2002-410 Item no.: 2002-409/000-006 Jumper; 9-way; insulated; blue www.wago.com/2002-409 /000-006 Item no.: 2002-409/000-005 Jumper; 9-way; insulated; red www.wago.com/2002-409 /000-005 Item no.: 2002-409 Jumper; 9-way; insulated; light gray www.wago.com/2002-409 Item no.: 2002-423/000-006 Continuous jumper; from 1 to 3; insulated; blue www.wago.com/2002-423 /000-006 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Item no.: 2002-423 Continuous jumper; from 1 to 3; insulated; light gray www.wago.com/2002-423 Item no.: 2002-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2002-433 Item no.: 2002-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2002-434 Item no.: 2002-423/000-005 Continuous jumper; from 1 to 3; insulated; red www.wago.com/2002-423 /000-005 Item no.: 2002-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2002-435 Item no.: 2002-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2002-436 Item no.: 2002-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2002-437 Item no.: 2002-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2002-438 Item no.: 2002-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2002-439 Item no.: 2002-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2002-440 Item no.: 2002-472 Staggered jumper; 2-way; insulated; light gray www.wago.com/2002-472 Item no.: 2002-473 Staggered jumper; 3-way; insulated; light gray www.wago.com/2002-473 Item no.: 2002-475/011-000 Staggered jumper; 3-way; insulated; light gray www.wago.com/2002-475 /011-000 Item no.: 2002-475 Staggered jumper; 5-way; insulated; light gray www.wago.com/2002-475 Item no.: 2002-476 Staggered jumper; 6-way; insulated; light gray www.wago.com/2002-476 Item no.: 2002-474 Staggered jumper; 4-way; insulated; light gray www.wago.com/2002-474 Item no.: 2002-477 Subject to changes. Please also observe the further product documentation! www.wago.com/2002-477 WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Item no.: 2002-477 Staggered jumper; 7-way; insulated; light gray www.wago.com/2002-477 Item no.: 2002-473/011-000 Staggered jumper; 2-way; from 1 to 3; insulated; light gray www.wago.com/2002-473 /011-000 Item no.: 2002-479 Staggered jumper; 9-way; insulated; light gray www.wago.com/2002-479 Item no.: 2002-478 Staggered jumper; 8-way; insulated; light gray www.wago.com/2002-478 Item no.: 2002-479/011-000 Staggered jumper; insulated; light gray www.wago.com/2002-479 /011-000 Item no.: 2002-480 Staggered jumper; 10-way; insulated; light gray www.wago.com/2002-480 Item no.: 2002-477/011-000 Staggered jumper; insulated; light gray www.wago.com/2002-477 /011-000 Item no.: 2002-492 Vertical jumper; insulated; light gray www.wago.com/2002-492 Item no.: 2002-481/011-000 Staggered jumper; insulated; light gray www.wago.com/2002-481 /011-000 Item no.: 2002-493 Vertical jumper; insulated; light gray www.wago.com/2002-493 Item no.: 2002-481 Staggered jumper; 11-way; insulated; light gray www.wago.com/2002-481 Item no.: 2002-492/000-012 Vertical jumper; insulated; orange www.wago.com/2002-492 /000-012 Item no.: 2002-482 Staggered jumper; 12-way; insulated; light gray www.wago.com/2002-482 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Tool     Operating tool Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured www.wago.com/210-658 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Mounting     Mounting accessories Item no.: 709-156 Cover; Type 3; suitable for cover carrier, type 3; 1 m long; transparent www.wago.com/709-156 Item no.: 709-169 Cover carrier; Type 3; gray www.wago.com/709-169 Testing and measuring     Testing accessories Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 2002-611 TOPJOB®S L-type test plug module; modular; 1-pole; 2,50 mm²; gray www.wago.com/2002-611 Item no.: 2002-649 TOPJOB®S L-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2002-649 Push-in type wire jumper     Jumper Item no.: 2009-412 Push-in type wire jumper; insulated; 60 mm long; black www.wago.com/2009-412 Item no.: 2009-414 Push-in type wire jumper; 1.5 mm²; insulated; 110 mm long; black www.wago.com/2009-414 Item no.: 2009-416 Push-in type wire jumper; 1.5 mm²; insulated; 250 mm long; black www.wago.com/2009-416 Item no.: 2009-414/000-005 Push-in type wire jumper; 1.5 mm²; insulated; 110 mm long; black www.wago.com/2009-414 /000-005 Item no.: 2009-414/000-006 Push-in type wire jumper; insulated; 110 mm long; black www.wago.com/2009-414 /000-006 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight www.wago.com/216-241 Ferrule     Ferrule crimped; acc. to DIN 46228, Part 4/09.90; white Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 10/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 crimped; acc. to DIN 46228, Part 4/09.90; white Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Marking accessories     Marking strip Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110     Marker carrier Item no.: 2009-198 Adaptor; gray www.wago.com/2009-198 Item no.: 2002-131 Adaptor; gray www.wago.com/2002-131 Item no.: 2002-161 Adaptor; gray www.wago.com/2002-161 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002     Marker Item no.: 2009-115/000-007 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 11/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 248-501/000-006 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/248-501 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 12/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012 type; orange Item no.: 793-5501/000-014 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 13/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; brown /000-014 Item no.: 793-5501/000-017 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-017 type; green Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/793-501 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 14/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-005 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-115 /000-005     Group marker carrier Item no.: 2009-193 Group marker carrier www.wago.com/2009-193 Item no.: 2009-192 Group marker carrier www.wago.com/2009-192 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Carrier rail Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 15/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Insulation stop     Insulation stop Item no.: 2002-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2002-171 Item no.: 2002-172 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray www.wago.com/2002-172 Protective warning marker     Cover Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 16/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203     Cover Item no.: 2002-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2002-115 Downloads Documentation Bid Text 2002-3203 Apr 18, 2019 xml 4.4 kB Download Apr 18, 2019 docx 15.9 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download EPLAN Data Portal 2002-3203 URL Download WSCAD Universe 2002-3203 URL Download ZUKEN Portal 2002-3203 URL Download URL Download X81 - Datei 2002-3203 docx - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 2002-3203 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 2002-3203 Triple-deck terminal block; Through/through/through terminal block; L/L/N; without marker carrier; suitable for Ex e II applications; Blue conductor entry upper deck; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 17/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Installation Notes Conductor termination All conductor types at a glance Push-in termination of solid and ferruled conductors Inserting a conductor via push-in termination: Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Inserting a conductor via operating tool: Conductor termination – insulation stop Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. Advantage: To open the clamp, the operating tool is inserted vertically. The conductor entry is less than 15 degrees for easier wiring. Commoning Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 18/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 Removing a push-in type jumper bar: Insert the operating tool between the jumper and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers for up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Commoning Commoning three levels via triple-deck vertical jumper (2002‑493). Created for double- and triple-deck TOPJOB® S Terminal Blocks, the vertical jumpers can common two or three levels. Clearly marked numerals (“2” and “3”) distinguish the double-deck (2002-0492) and triple-deck vertical jumpers (20020493), even when inserted. Product family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 19/20 Data sheet | Item number: 2002-3203 www.wago.com/2002-3203 TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 20/20
2002-3203 价格&库存
很抱歉,暂时无法提供与“2002-3203”相匹配的价格&库存,您可以联系我们找货
    • 1+121.994751+15.86268
      • 1+712.30646
      库存:220
