Data sheet | Item number: 2022-108
1-conductor female connector; Push-in CAGE CLAMP®; 4 mm²; Pin spacing
5.2 mm; 8-pole; 4,00 mm²; gray
www.wago.com/2022-108
i
Picture differs from the item.
Color:
Data
Notes
Safety information 1
According to EN 61984, pluggable connectors without current
interrupting capacity must not be mated or unmated when live or
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/8
under load.
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
20 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
20 A
Approvals per
C22.2 No 158
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group C)
20 A
Ratings per
IEC/EN 61984
Nominal voltage (III/3)
690 V
Rated surge voltage (III/3)
6 kV
Rated current
24 A
Rated current 2
32 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
8
Total number of potentials
8
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Push-in
Connectable conductor materials
Copper
Nominal cross-section
2.5 mm²
Solid conductor
0.25 … 4 mm² / 22 … 12 AWG
Solid conductor; push-in termination
0.75 … 4 mm² / 18 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 2.5 mm² / 22 … 14 AWG
Fine-stranded conductor; with ferrule; push-in termination
1 … 2.5 mm² / 18 … 14 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
10 … 12 mm / 0.39 … 0.47 inch
Pole No.
8
Wiring direction
Front-entry wiring
Physical
data
Subject to changes.
Hansastr. 27
32423 Minden
13.10.2021 Page 2/8
Physical data
Width
41.6 mm / 1.638 inch
Height
40.5 mm / 1.594 inch
Depth
22.4 mm / 0.882 inch
Module width
5.2 mm / 0.205 inch
Mechanical data
Marking level
Side marking
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.431 MJ
Weight
25.7 g
Commercial data
PU (SPU)
50 Stück
Packaging type
box
Country of origin
CN
GTIN
4050821242796
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CSA
DEKRA Certification B.V.
C22.2 No. 158
2437422
KEMA/KEUR
EN 61984
71101560
Hansastr. 27
32423 Minden
13.10.2021 Page 3/8
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
BV
Bureau Veritas S.A.
EN 60947
38586/A0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
UL-Approvals
Logo
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1059
E45172
Optional accessories
Insulation stop
Insulation stop
Item no.: 2002-171
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/2002-171
Item no.: 2002-172
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray
www.wago.com/2002-172
Ferrule
Ferrule
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-241
crimped; acc. to DIN 46228, Part 4/09.90; white
Hansastr. 27
32423 Minden
13.10.2021 Page 4/8
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-246
Item no.: 216-266
www.wago.com/216-266
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-286
www.wago.com/216-286
Item no.: 216-262
www.wago.com/216-262
Locking levers
Locking device
Item no.: 2022-151
Locking lever; gray
www.wago.com/2022-151
Item no.: 2022-152
Locking lever; orange
www.wago.com/2022-152
Protective warning marker
Cover
Item no.: 2002-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2002-115
Marking accessories
Marking strip
Item no.: 2009-110
Hansastr. 27
32423 Minden
www.wago.com/2009-110
13.10.2021 Page 5/8
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
Item no.: 210-831
Marking strips; on reel; 2.3 mm wide; plain; Self-adhesive; white
www.wago.com/210-831
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Item no.: 210-834
Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white
www.wago.com/210-834
Item no.: 210-832
Marking strips; on reel; 3 mm wide; plain; Self-adhesive; white
www.wago.com/210-832
Item no.: 210-805
Labels; for Smart Printer; permanent adhesive; 6 x 15 mm; white
www.wago.com/210-805
Item no.: 210-805/000-002
Labels; for Smart Printer; permanent adhesive; 6 x 15 mm; yellow
/000-002
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Label
Marker
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Strain relief
Strain relief plate
Item no.: 734-326
Strain relief plate; gray
www.wago.com/734-326
Tool
Operating tool
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Downloads
Documentation
Bid Text
Hansastr. 27
32423 Minden
May 14, 2019
docx
Download
13.10.2021 Page 6/8
May 14, 2019
docx
15.7 kB
Download
May 17, 2019
xml
4.2 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 2022-108
URL
Download
WSCAD Universe 2022-108
URL
Download
ZUKEN Portal 2022-108
URL
Download
URL
Download
2022-108
docx - Datei
2022-108
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 2022-108
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2022-108
1-conductor female connector; Push-in CAGE CLAMP®; 4 mm²; Pin spacing 5.2 mm;
Installation Notes
Coding
Hansastr. 27
32423 Minden
13.10.2021 Page 7/8
Insert coding pin into the corresponding slot
and twist it off.
Coding a female plug: remove coding finger
using a suitable tool.
Insert coded female plug into X-COM®SSYSTEM terminal block assembly.
Locking system
Slide the locking lever into position.
Female plugs can be individually locked.
Product family
X-COM S
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 8/8
很抱歉,暂时无法提供与“2022-108”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+179.255641+23.21988
