Data sheet | Item number: 2022-109/000-016
1-conductor female connector; Push-in CAGE CLAMP®; 4 mm²; Pin spacing
5.2 mm; 9-pole; 4,00 mm²; green-yellow
www.wago.com/2022-109/000-016
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/7
Data
Notes
Safety information 1
According to EN 61984, pluggable connectors without current
interrupting capacity must not be mated or unmated when live or
under load.
Electrical data
Ratings per
IEC/EN 61984
Connection data
Total number of connection points
9
Total number of potentials
9
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Push-in
Connectable conductor materials
Copper
Nominal cross-section
2.5 mm²
Solid conductor
0.25 … 4 mm² / 22 … 12 AWG
Solid conductor; push-in termination
0.75 … 4 mm² / 18 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 2.5 mm² / 22 … 14 AWG
Fine-stranded conductor; with ferrule; push-in termination
1 … 2.5 mm² / 18 … 14 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
10 … 12 mm / 0.39 … 0.47 inch
Pole No.
9
Wiring direction
Front-entry wiring
Physical data
Width
46.8 mm / 1.843 inch
Height
40.5 mm / 1.594 inch
Depth
22.4 mm / 0.882 inch
Module width
5.2 mm / 0.205 inch
Hansastr. 27
32423 Minden
13.10.2021 Page 2/7
Mechanical data
Marking level
Side marking
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Material data
Color
green-yellow
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.484 MJ
Weight
29.6 g
Commercial data
Product Group
18 (X-COM-System)
PU (SPU)
50 Stück
Packaging type
box
Country of origin
DE
GTIN
4045454705664
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CSA
DEKRA Certification B.V.
C22.2 No. 158
2437422
Optional accessories
Insulation stop
Insulation stop
Item no.: 2002-171
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
Hansastr. 27
32423 Minden
www.wago.com/2002-171
13.10.2021 Page 3/7
Item no.: 2002-172
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray
www.wago.com/2002-172
Locking levers
Locking device
Item no.: 2022-151
Locking lever; gray
www.wago.com/2022-151
Item no.: 2022-152
Locking lever; orange
www.wago.com/2022-152
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Ferrule
Ferrule
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-246
Item no.: 216-266
www.wago.com/216-266
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-286
www.wago.com/216-286
Item no.: 216-262
www.wago.com/216-262
Marking accessories
Hansastr. 27
32423 Minden
13.10.2021 Page 4/7
Marking accessories
Marking strip
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 210-831
Marking strips; on reel; 2.3 mm wide; plain; Self-adhesive; white
www.wago.com/210-831
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Item no.: 210-834
Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white
www.wago.com/210-834
Item no.: 210-832
Marking strips; on reel; 3 mm wide; plain; Self-adhesive; white
www.wago.com/210-832
Item no.: 210-805
Labels; for Smart Printer; permanent adhesive; 6 x 15 mm; white
www.wago.com/210-805
Item no.: 210-805/000-002
Labels; for Smart Printer; permanent adhesive; 6 x 15 mm; yellow
/000-002
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Label
Marker
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Strain relief
Strain relief plate
Item no.: 734-326
Strain relief plate; gray
www.wago.com/734-326
Protective warning marker
Cover
Item no.: 2002-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2002-115
Tool
Operating tool
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
Hansastr. 27
32423 Minden
www.wago.com/210-720
13.10.2021 Page 5/7
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 2022-109/000-016
URL
Download
WSCAD Universe 2022-109/000-016
URL
Download
URL
Download
URL
Download
ZUKEN Portal 2022-109/000-016
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2022-109/000-016
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2022-109/000-016
1-conductor female connector; Push-in CAGE CLAMP®; 4 mm²; Pin spacing 5.2 mm;
Installation Notes
Coding
Hansastr. 27
32423 Minden
13.10.2021 Page 6/7
Insert coding pin into the corresponding slot
and twist it off.
Coding a female plug: remove coding finger
using a suitable tool.
Insert coded female plug into X-COM®SSYSTEM terminal block assembly.
Locking system
Slide the locking lever into position.
Female plugs can be individually locked.
Product family
X-COM S
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 7/7
很抱歉,暂时无法提供与“2022-109/000-016”相匹配的价格&库存,您可以联系我们找货
