2042-3024
2042-3024
    WAGO(万可电子)
    SOCKETABLE
    RELAY GEN PURPOSE 4PST 5A 24V
2042-3024 数据手册
Data sheet | Item number: 2042-3024 Relay module; Nominal input voltage: 24 VDC; 4 make contacts; Limiting continuous current: 5 A; Railway; Green status indicator; Module width: 25 mm www.wago.com/2042-3024 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/6 Data sheet | Item number: 2042-3024 www.wago.com/2042-3024 DC load limit curve Data Technical data Nominal input voltage UN DC 24 V Input voltage range -30 … +25 % Nominal input current at UN 28.1 mA Rated voltage 250 V Pollution degree 2 Dielectric strength, control/load circuit (AC, 1 min) 3 kVrms Dielectric strength, open contact (AC, 1 min) 1 kVrms Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/6 Data sheet | Item number: 2042-3024 www.wago.com/2042-3024 Dielectric strength, open contact (AC, 1 min) 1 kVrms Dielectric strength, channel/channel (AC, 1 min.) 1.5 kVrms Protection type IP20 Number of make/switch-on contacts 4 Contact material (relay) AgNi Limiting continuous current 5 A Inrush current (resistive) (max.) (AC) 15 A / 4 s Switching voltage (max.) AC 250 V Switching power (resistive) (max.) AC 1250 VA; DC (see load limit curve) Recommended minimum load 12 V / 10 mA Pull-in time (typ.) 8 ms Drop-out time (typ.) 6 ms Bounce time (typ.) 4 ms Electrical life (NO; resistive load; 23 °C) 100 x 103 switching operations Mechanical life 10 x 106 switching operations Status indicator Green LED Physical data Width 25.9 mm / 1.02 inch Height 77.7 mm / 3.059 inch Height from the surface 59.3 mm / 2.335 inch Depth 52 mm / 2.047 inch Mechanical data Mounting type Pluggable module for TOPJOB® S carrier terminal block Material data Flammability class per UL94 V0 Fire load 0.232 MJ Weight 70.3 g Environmental requirements Surrounding air temperature (operation at UN) -40 … 70 °C Surrounding air temperature (storage) -40 … 85 °C Processing temperature -25 … +50 °C Operating altitude (max.) 2000 m Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/6 Data sheet | Item number: 2042-3024 www.wago.com/2042-3024 Operating altitude (max.) 2000 m Standards and specifications Standards/Specifications EN 61010-2-201 EN 61373 EN 50121-3-2 Commercial data PU (SPU) 5 Stück Packaging type box Country of origin DE GTIN 4055143651691 Customs tariff number 85364900990 Approvals / Certificates UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. (ORDINARY LOCATIONS) UL 61010-1 E175199 Optional accessories End plate     End plate Item no.: 2002-1892 End and intermediate plate; 1 mm thick; orange www.wago.com/2002-1892 Item no.: 2002-1891 End and intermediate plate; 1 mm thick; gray www.wago.com/2002-1891 Item no.: 2002-1991 End and intermediate plate; 1 mm thick; gray www.wago.com/2002-1991 Item no.: 2002-1992 End and intermediate plate; 1 mm thick; orange www.wago.com/2002-1992 Item no.: 2002-1691 End and intermediate plate; 1 mm thick; gray www.wago.com/2002-1691 Item no.: 2002-1692 End and intermediate plate; 1 mm thick; orange Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2002-1692 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/6 Data sheet | Item number: 2042-3024 www.wago.com/2042-3024 End and intermediate plate; 1 mm thick; orange www.wago.com/2002-1692 Item no.: 2002-1791 End and intermediate plate; 1 mm thick; gray www.wago.com/2002-1791 Item no.: 2002-1792 End and intermediate plate; 1 mm thick; orange www.wago.com/2002-1792 Marking accessories     Marking strip Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501     Marker Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Terminal blocks     Carrier terminal block for modules and plugs Item no.: 2002-1961 2-conductor carrier terminal block; with additional jumper position; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 www.wago.com/2002-1961 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray Item no.: 2002-1661 2-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2002-1661 Item no.: 2002-1761 3-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2002-1761 Item no.: 2002-1861 4-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2002-1861 Downloads Documentation Bid Text 2042-3024 Feb 19, 2019 xml 3.9 kB Download Feb 20, 2019 docx Download X81 - Datei 2042-3024 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/6 Data sheet | Item number: 2042-3024 www.wago.com/2042-3024 2042-3024 docx - Datei Feb 20, 2019 docx 17.1 kB Download V 1.1.0 pdf 2.0 MB Download V 1.0.0 pdf 265.8 kB Download URL Download URL Download URL Download Instruction Leaflet Pluggable Relay Module / Pluggable Solid-State Relay Module Additional Information Disposal; Electrical and electronic equipment, Packaging CAD/CAE-Data CAD data 2D/3D Models 2042-3024 CAE data ZUKEN Portal 2042-3024 Environmental Product Compliance Compliance Search Environmental Product Compliance 2042-3024 Relay module; Nominal input voltage: 24 VDC; 4 make contacts; Limiting continuous current: 5 A; Railway; Green status indicator; Module width: 25 mm Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/6
2042-3024 价格&库存
很抱歉,暂时无法提供与“2042-3024”相匹配的价格&库存,您可以联系我们找货
  • 5+836.389355+108.41199
