Data sheet | Item number: 2060-472/998-404
SMD PCB terminal block; push-button; 0.75 mm²; Pin spacing 4 mm; 2-pole;
Push-in CAGE CLAMP®; in tape-and-reel packaging; 0,75 mm²; black
www.wago.com/2060-472/998-404
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/9
Dimensions in mm
R = feed direction
Hansastr. 27
32423 Minden
07.10.2021 Page 2/9
Item description
SMD PCB terminal blocks with Push-in CAGE CLAMP® connection technology and push-buttons
Push-in termination of solid and ferruled conductors
Convenient termination/removal of fine-stranded conductors via push-buttons
Just 4.5 mm tall
Available in tape-and-reel packaging for automated assembly
Data
Notes
Note
Application notes:
Suitable for lead-free, reflow-soldering profiles per DIN EN 61760-1
and IEC 60068-2-58 up to max. 260°C peak temperature. Due to
application-specific variables (component configuration and
orientation, type of soldering machine, solder paste), trial runs are
recommended to ensure product and process compatibility under
actual manufacturing conditions.
Note
Depending on reflow soldering temperatures and times, color
deviations may occur. These deviations will have no impact on
functionality.
Recommendation
Hansastr. 27
32423 Minden
07.10.2021 Page 3/9
Recommendation
Recommendation for stencil:
Material thickness: 150 µm; Pattern layout identical to solder pad
layout
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
63 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
9 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL 1977
320 V
Rated current UL 1977
9 A
Connection data
Total number of connection points
2
Total number of potentials
2
Number of connection types
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.2 … 0.75 mm² / 24 … 18 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 0.34 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 0.34 mm²
Strip length
7 … 9 mm / 0.28 … 0.35 inch
Conductor connection direction to PCB
0 °
Pole No.
2
Physical data
Pin spacing
4 mm / 0.157 inch
Width
7.9 mm / 0.311 inch
Hansastr. 27
32423 Minden
07.10.2021 Page 4/9
Width
7.9 mm / 0.311 inch
Height
4.5 mm / 0.177 inch
Depth
13.1 mm / 0.516 inch
Reel diameter of tape-and-reel packaging
330 mm
Tape width
24 mm
PCB contact
PCB Contact
SMD
Solder pin arrangement
Over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Color
black
Material group
I
Insulation material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Clamping spring material
Copper alloy
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.007 MJ
Weight
0.5 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
PU (SPU)
9000 (1000) Stück
Packaging type
box
Country of origin
CH
GTIN
4055143251181
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
EN 60947
NTR NL-
DEKRA Certification B.V.
Hansastr. 27
32423 Minden
7724
07.10.2021 Page 5/9
CCA
EN 60947
NTR NL7724
CCA
EN 60838
NTR NL
2168246
CCA
EN 60947-7-4
NTR NL
7843
KEMA/KEUR
EN 60838
2168246.01
KEMA/KEUR
EN 60947
71-108183
KEMA/KEUR
EN 60947-7-4
71-114208
KEMA/KEUR
EN 60998
71-109040
UL-Approvals
Logo
Approval
Certificate
name
cURus
Underwriters Laboratories Inc.
UL 1977
E45171
Counterpart
Item no.2060-952/028-000
Board-to-Board Link; Pin spacing 4 mm; 2-pole; Length: 28 mm; white
www.wago.com/2060-952/028-000
Item no.2060-952/030-000
Hansastr. 27
32423 Minden
07.10.2021 Page 6/9
Board-to-Board Link; Pin spacing 4 mm; 2-pole; Length: 30 mm; white
www.wago.com/2060-952/030-000
Optional accessories
Tool
Operating tool
Item no.: 206-860
Operating tool; for 2060 Series; multicoloured
www.wago.com/206-860
Item no.: 2060-189
Operating tool; made of insulating material; for 2060 Series; white
www.wago.com/2060-189
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Ferrule
Ferrule
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2060-472/998-404
CAE data
ZUKEN Portal 2060-472/998-404
Hansastr. 27
32423 Minden
07.10.2021 Page 7/9
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2060-472/998-404
URL
Download
SMD PCB terminal block; push-button; 0.75 mm²; Pin spacing 4 mm; 2-pole; Push-in
Installation Notes
Conductor termination
Insert solid conductors via push-in
termination.
Insert/remove fine-stranded conductors by
lightly pressing on push-button, e.g., via
optional operating tool (206-860).
Hansastr. 27
32423 Minden
07.10.2021 Page 8/9
Terminal blocks can be arranged side-byside without loss of poles.
Hansastr. 27
32423 Minden
07.10.2021 Page 9/9
很抱歉,暂时无法提供与“2060-472/998-404”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.67000
- 10+4.48200
- 30+3.88800
- 100+3.29400
- 500+2.93760
- 国内价格 香港价格
- 1+13.397731+1.73548
- 10+9.7397310+1.26164
- 25+8.4790525+1.09834
- 50+7.6613350+0.99241
- 100+6.96234100+0.90187
- 250+6.21748250+0.80539
- 500+5.77433500+0.74798
