Data sheet | Item number: 2070-452/998-406
Through-Board SMD PCB Terminal Block; 0.75 mm²; Pin spacing 6.5 mm; 2pole; Push-in CAGE CLAMP®; in tape-and-reel packaging; 0,75 mm²; white
www.wago.com/2070-452/998-406
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/9
Dimensions in mm
R = feed direction
Item description
SMD PCB terminal block with Push-in CAGE CLAMP® connection for back-side wiring of LED modules
Low profile of just 1.1 mm on the module’s front side
Push-in termination of solid conductors
Insert fine-stranded conductors and remove all conductors via operating tool
Hansastr. 27
32423 Minden
07.10.2021 Page 2/9
Data
Notes
Note
Depending on reflow soldering temperatures and times, color
deviations may occur. These deviations will have no impact on
functionality.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Reel diameter of tape-and-reel packaging: 381 mm
Electrical data
Ratings per
IEC/EN 60664-1
Ratings (note)
Electrical Data for FR4 PCB Type
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
9 A
Ratings per
IEC/EN 60664-1
Ratings (note) 2
Electrical Data for Metal-Core PCBs
Rated voltage (III/3) 2
200 V
Rated surge voltage (III/3) 2
4 kV
Rated voltage (III/2) 2
320 V
Rated surge voltage (III/2) 2
4 kV
Rated voltage (II/2) 2
500 V
Rated surge voltage (II/2) 2
4 kV
Rated current 2
9 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL 1977
600 V
Rated current UL 1977
9 A
Connection data
Total number of connection points
2
Total number of potentials
2
Number of connection types
1
Hansastr. 27
32423 Minden
07.10.2021 Page 3/9
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.2 … 0.75 mm² / 24 … 18 AWG
Fine-stranded conductor
Strip length
8 … 10 mm / 0.31 … 0.39 inch
Conductor connection direction to PCB
0 °
Pole No.
2
Physical data
Pin spacing
6.5 mm / 0.256 inch
Width
11.8 mm / 0.465 inch
Height
7.45 mm / 0.293 inch
Depth
22.2 mm / 0.874 inch
330 mm
Tape width
44 mm
Mechanical data
Design
without Cover
Mounting type
Through-board
PCB contact
PCB Contact
SMD
Solder pin arrangement
Over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Color
white
Material group
I
Insulation material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Contact material
Copper alloy
Contact plating
tin-plated
Weight
2 g
Environmental
requirements
Hansastr. 27
32423 Minden
07.10.2021 Page 4/9
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
PU (SPU)
2385 (477) Stück
Packaging type
box
Country of origin
CH
GTIN
4055143645171
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
EN 60998
NL-57653
CB
IEC 60998
NL-57652
KEMA/KEUR
EN 60947-7-4
71107965
KEMA/KEUR
EN 60998
71107967
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1977
E45171
UL-Approvals
Logo
Optional accessories
Tool
Operating tool
Item no.: 2070-400
Operating tool; made of insulating material; green
Hansastr. 27
32423 Minden
www.wago.com/2070-400
07.10.2021 Page 5/9
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2070-452/998-406
PCB Design
Symbol and Footprint 2070-452/998-406
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Hansastr. 27
32423 Minden
07.10.2021 Page 6/9
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 2070-452/998-406
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2070-452/998-406
Through-Board SMD PCB Terminal Block; 0.75 mm²; Pin spacing 6.5 mm; 2-pole;
Installation Notes
all conductor types via operating tool. Solid
conductors can also be terminated by
simply pushing them in.
Hansastr. 27
32423 Minden
07.10.2021 Page 7/9
Use an operating tool or simply “twist and
pull” to remove solid conductors.
Installation
Shift wiring to the back of the LED module
via 2070 Series SMD PCB Terminal Blocks.
Application
The variants with cover feature a center
contact surface for easy pick-and-place
assembly and minimum shadowing.
Application
Hansastr. 27
32423 Minden
07.10.2021 Page 8/9
The printed variants offer unique pole
marking on the back of the module.
Hansastr. 27
32423 Minden
07.10.2021 Page 9/9
很抱歉,暂时无法提供与“2070-452/998-406”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.952321+1.67887
- 10+9.3893710+1.21704
- 25+8.1778625+1.06001
- 50+7.3849650+0.95723
- 100+6.70933100+0.86966
- 国内价格 香港价格
- 477+5.47563477+0.70975
- 国内价格
- 228+3.77240
- 800+3.60312
- 3200+3.51849
- 7800+3.26457
- 23300+3.17994
