2086-1206/700-000/997-607 数据手册
Data sheet | Item number: 2086-1206/700-000/997-607
SMD PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 6-pole;
Push-in CAGE CLAMP®; 1,50 mm²; black
www.wago.com/2086-1206/700-000/997-607
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Corporation
Germantown, WI 53022
Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.us
Do you have any questions about our products?
We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL.
05.10.2021 Page 1/9
Dimensions in mm
L = (pole no. – 1) x pin spacing + 4.2 mm
WAGO Corporation
05.10.2021 Page 2/9
Dimensions in mm
W = Tape width
R = Feed direction
Pole No. 2: Z = 11.5 mm
Pole No. 3: Z = 10.7 mm
Pole No. 4: Z = 12.5 mm
Pole No. 5: Z = 14.2 mm
Pole No. 6; 8; 10; 12: Z = 26.2 mm
Pole No. 7; 9; 11: Z = 24.5 mm
Item description
Ideal for compact device connection, panel feedthrough and tight spaces
Push-in CAGE CLAMP® allows push-in termination of solid and fine-stranded conductors with ferrules
SMD and THR variants available
Delivery in tape-and-reel packaging for full integration into SMT soldering process
WAGO Corporation
05.10.2021 Page 3/9
Push-button moves in direction of conductor connection
Conductor connection and mating direction both parallel and perpendicular to the PCB
Data
Electrical data
IEC Approvals
Ratings per
IEC/EN 60664-1
Rated voltage (III / 3)
160 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
17.5 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
UL Approvals
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
CSA Approvals
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Total number of potentials
6
Number of connection types
1
WAGO Corporation
05.10.2021 Page 4/9
1
Number of levels
1
Connection 1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 0.75 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 1.5 mm²
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Conductor connection direction to PCB
0 °
Number of poles
6
Physical data
Pin spacing
3.5 mm / 0.138 inch
Width
21.7 mm / 0.854 inch
Height
8.15 mm / 0.321 inch
Depth
13.6 mm / 0.535 inch
Reel diameter of tape-and-reel packaging
380 mm
Tape width
56 mm
PCB contact
PCB Contact
SMD
Solder pin arrangement
Over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Color
black
Insulation material
Polyphthalamide (PPA GF)
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
Tin-plated
Weight
4.2 g
WAGO Corporation
05.10.2021 Page 5/9
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
PU (SPU)
2060 (515) Stück
Packaging type
box
Country of origin
CH
GTIN
4055144108279
Customs tariff number
85369010000
Optional accessories
Testing accessories
Testing accessories
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Item no.: 859-500
www.wago.com/859-500
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Ferrules
Ferrule
Item no.:
216-131
Subject to changes.
Please
WAGO Corporation
05.10.2021 Page 6/9
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Tools
Operating tool
Item no.: 210-719
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-719
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
Environmental Product Compliance
Compliance Search
WAGO Corporation
05.10.2021 Page 7/9
URL
Environmental Product Compliance 2086-1206/700-000/997-607
Download
SMD PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 6-pole; Push-in
Installation Notes
Conductor termination
Inserting solid conductor via push-in
termination.
Conductor removal
Removing fine-stranded conductors via
push-buttons.
WAGO Corporation
05.10.2021 Page 8/9
Inserting and removing fine-stranded
conductors via push-buttons.
Testing
Testing via 1 mm Ø test pin.
Touch contact with current bar.
Marking
Pole marking via direct marking
perpendicular to conductor entry.
WAGO Corporation
05.10.2021 Page 9/9
2086-1206/700-000/997-607 价格&库存
很抱歉,暂时无法提供与“2086-1206/700-000/997-607”相匹配的价格&库存,您可以联系我们找货
