Data sheet | Item number: 2086-3124/300-000
THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 5 mm; 4-pole;
Push-in CAGE CLAMP®; Solder pin length 1.5 mm; 1,50 mm²; black
www.wago.com/2086-3124/300-000
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Corporation
Germantown, WI 53022
Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.us
Do you have any questions about our products?
We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL.
05.10.2021 Page 1/9
Dimensions in mm
A = even number of poles
B = odd number of poles
Dimensions in mm
L = (pole no. – 1) x pin spacing + 4.2 mm
Item description
Ideal for compact device connection, panel feedthrough and tight spaces
Push-in CAGE CLAMP® allows push-in termination of solid and fine-stranded conductors with ferrules
SMD and THR variants available
Delivery in tape-and-reel packaging for full integration into SMT soldering process
Push-button moves in direction of conductor connection
Conductor connection and mating direction both parallel and perpendicular to the PCB
Choice of double pin spacing or alternating pin spacing, 3.5 and 5 mm pin spacing
Data
WAGO Corporation
05.10.2021 Page 2/9
Data
Electrical data
IEC Approvals
Ratings per
IEC/EN 60664-1
Rated voltage (III / 3)
500 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
17.5 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
UL Approvals
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
CSA Approvals
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Total number of potentials
4
Number of connection types
1
Number of levels
1
WAGO Corporation
05.10.2021 Page 3/9
Connection 1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 0.75 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 1.5 mm²
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Conductor connection direction to PCB
90 °
Number of poles
4
Physical data
Pin spacing
5 mm / 0.197 inch
Width
19.2 mm / 0.756 inch
Height
15.1 mm / 0.594 inch
Height from the surface
13.6 mm / 0.535 inch
Depth
7.8 mm / 0.307 inch
Solder pin length
1.5 mm
Solder pin dimensions
0.3 x 0.8 mm
Plated through-hole diameter (THR)
1 (+0.1) mm
PCB contact
PCB Contact
THR
Solder pin arrangement
over the entire terminal strip (staggered)
Number of solder pins per potential
1
Material data
Color
black
Insulation material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Weight
2.4 g
WAGO Corporation
05.10.2021 Page 4/9
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
PU (SPU)
168 Stück
Packaging type
BOX
Country of origin
CH
GTIN
4055144090093
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 60947-7-4
NL-74022
CSA
C22.2
80060692
KEMA/KEUR
EN 60947-7-4
71119449
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1059
E45172
UL-Approvals
Logo
Optional accessories
Tools
Operating tool
Item no.: 210-719
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-719
Ferrules
Ferruleto changes. Please also observe the further product documentation!
Subject
WAGO Corporation
05.10.2021 Page 5/9
Ferrules
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
WAGO Corporation
05.10.2021 Page 6/9
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Testing accessories
Testing accessories
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Item no.: 859-500
www.wago.com/859-500
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
THR Soldering Process
pdf
2.0 MB
Download
pdf
548.2 kB
Download
URL
Download
URL
Download
URL
Download
CAD files
CAD data
2D/3D Models 2086-3124/300-000
CAE data
ZUKEN Portal 2086-3124/300-000
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2086-3124/300-000
THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 5 mm; 4-pole; Push-in
Installation Notes
Conductor termination
WAGO Corporation
05.10.2021 Page 7/9
Inserting solid conductor via push-in
termination.
Conductor removal
Removing fine-stranded conductors via
push-buttons.
Inserting and removing fine-stranded
conductors via push-buttons.
Testing
WAGO Corporation
05.10.2021 Page 8/9
Testing via 1 mm Ø test pin.
Touch contact with current bar.
Marking
Pole marking via direct marking
perpendicular to conductor entry.
WAGO Corporation
05.10.2021 Page 9/9
很抱歉,暂时无法提供与“2086-3124/300-000”相匹配的价格&库存,您可以联系我们找货
