2086-3208/700-000/997-607
    WAGO(万可电子)
    SMD,P=5mm
    8 接线板 - 线至板 水平,带板 0.197"(5.00mm) 表面贴装型
2086-3208/700-000/997-607 数据手册
Data sheet | Item number: 2086-3208/700-000/997-607 SMD PCB terminal block; push-button; 1.5 mm²; Pin spacing 5 mm; 8-pole; Push-in CAGE CLAMP®; 1,50 mm²; black www.wago.com/2086-3208/700-000/997-607 Color: Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 1/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 Dimensions in mm L = (pole no. – 1) x pin spacing + 4.2 mm Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 2/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 Dimensions in mm W = Tape width R = Feed direction Pole No. 2: Z = 11.5 mm Pole No. 3: Z = 11.7 mm Pole No. 4: Z = 14.2 mm Pole No. 5: Z = 23.7 mm Pole No. 6: Z = 21.2 mm Pole No. 7: Z = 23.7 mm Pole No. 8: Z = 26.2 mm Item description Ideal for compact device connection, panel feedthrough and tight spaces Push-in CAGE CLAMP® allows push-in termination of solid and fine-stranded conductors with ferrules SMD and THR variants available Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 3/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 SMD and THR variants available Delivery in tape-and-reel packaging for full integration into SMT soldering process Push-button moves in direction of conductor connection Conductor connection and mating direction both parallel and perpendicular to the PCB Data Electrical data IEC Approvals Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 17.5 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 UL Approvals Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 300 V Rated current UL (Use Group C) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A CSA Approvals Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 4/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 Connection data Total number of potentials 8 Number of connection types 1 Number of levels 1 Connection 1 Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 0.75 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 1.5 mm² Strip length 8 … 9 mm / 0.31 … 0.35 inch Conductor connection direction to PCB 0  ° Number of poles 8 Physical data Pin spacing 5 mm / 0.197 inch Width 39.2 mm / 1.543 inch Height 8.15 mm / 0.321 inch Depth 13.6 mm / 0.535 inch Reel diameter of tape-and-reel packaging 380 mm Tape width 56 mm PCB contact PCB Contact SMD Solder pin arrangement Over the entire terminal strip (in-line) Number of solder pins per potential 2 Material data Color black Insulation material Polyphthalamide (PPA GF) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating Tin-plated Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 5/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 Contact plating Tin-plated Weight 6.1 g Environmental requirements Limit temperature range -60 … +105 °C Commercial data PU (SPU) 2060 (515) Stück Packaging type box Country of origin CH GTIN 4055144107890 Customs tariff number 85369010000 Optional accessories Testing accessories     Testing accessories Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Item no.: 859-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/859-500 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Ferrules     Ferrule Item no.: 216-143 Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 6/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92; silver-colored www.wago.com/216-144 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Tools     Operating tool Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download Environmental Product Compliance Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 7/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 Environmental Product Compliance Compliance Search Environmental Product Compliance 2086-3208/700-000/997-607 URL Download SMD PCB terminal block; push-button; 1.5 mm²; Pin spacing 5 mm; 8-pole; Push-in CAGE CLAMP®; 1,50 mm²; black Installation Notes Conductor termination Inserting solid conductor via push-in termination. Conductor removal Removing fine-stranded conductors via push-buttons. Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 8/9 Data sheet | Item number: 2086-3208/700-000/997-607 www.wago.com/2086-3208/700-000/997-607 Inserting and removing fine-stranded conductors via push-buttons. Testing Testing via 1 mm Ø test pin. Touch contact with current bar. Marking Pole marking via direct marking perpendicular to conductor entry. Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 05.10.2021    Page 9/9
2086-3208/700-000/997-607 价格&库存
很抱歉,暂时无法提供与“2086-3208/700-000/997-607”相匹配的价格&库存,您可以联系我们找货
