2091-1108/000-1000
2091-1108/000-1000
    WAGO(万可电子)
    P=3.5mm
    接线端子 间距:3.50mm 自由悬挂(直插式)
2091-1108/000-1000 数据手册
Data sheet | Item number: 2091-1108/000-1000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 8-pole; Gripping plate; direct marking; 1,50 mm²; light gray www.wago.com/2091-1108/000-1000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/8 Data sheet | Item number: 2091-1108/000-1000 www.wago.com/2091-1108/000-1000 Dimensions in mm L = (pole no. – 1) x pin spacing Item description Universal connection for all conductor types Simple, push-in termination of solid and ferruled conductors Easy-to-use design does not require specialty tools Ability to wire while mated or unmated Test port parallel to conductor entry – touch contact Integrated locking latches prevent accidental disconnection Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/8 Data sheet | Item number: 2091-1108/000-1000 www.wago.com/2091-1108/000-1000 Data Notes Safety information 1 The picoMAX® Pluggable Connection System includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Direct marking Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 160 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Total number of connection points 8 Total number of potentials 8 Number of connection types 1 Number of levels 1 Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.2 … 1.5 mm² / 24 … 14 AWG Fine-stranded conductor 0.2 … 1.5 mm² / 24 … 14 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 0.75 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 1.5 mm² Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/8 Data sheet | Item number: 2091-1108/000-1000 www.wago.com/2091-1108/000-1000 Fine-stranded conductor; with uninsulated ferrule 0.25 … 1.5 mm² Strip length 8 … 9 mm / 0.31 … 0.35 inch Pole No. 8 Physical data Pin spacing 3.5 mm / 0.138 inch Width 28 mm / 1.102 inch Height 33 mm / 1.299 inch Depth 11.4 mm / 0.449 inch Mechanical data Design With gripping plate Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for conductor Mismating protection No Locking of plug-in connection Without Material data Color light gray Material group I Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.018 MJ Weight 3.8 g Environmental requirements Limit temperature range -60 … +100 °C Commercial data PU (SPU) 50 Stück Packaging type box Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/8 Data sheet | Item number: 2091-1108/000-1000 www.wago.com/2091-1108/000-1000 Packaging type box Country of origin DE GTIN 4050821365891 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CB DEKRA Certification B.V. IEC 61984 NL-49736 /A1 CSA DEKRA Certification B.V. C22.2 2362521 KEMA/KEUR DEKRA Certification B.V. EN 61984 71102260 REV.1 Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1977 E45171 UR Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Counterpart Item no.2091-1428 THT male header; 1.0 mm Ø solder pin; angled; Pin spacing 3.5 mm; 8-pole; light gray www.wago.com/2091-1428 Item no.2091-1408 THT male header; 1.0 mm Ø solder pin; straight; Pin spacing 3.5 mm; 8-pole; light gray www.wago.com/2091-1408 Item no.2091-1528/002-000 1-conductor male connector; Push-in CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 8-pole; Integrated Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2091-1528 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/8 Data sheet | Item number: 2091-1108/000-1000 www.wago.com/2091-1108/000-1000 Item no.2091-1528/002-000 1-conductor male connector; Push-in CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 8-pole; Integrated release lever; 1,50 mm²; light gray www.wago.com/2091-1528 /002-000 Optional accessories Coding     Coding Item no.: 2091-1610 Coding key carrier; suitable for 3.5 mm pin spacing; orange www.wago.com/2091-1610 Testing and measuring     Testing accessories Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Tool     Operating tool Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 2091-1108/000-1000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 8-pole; Gripping plate; direct marking; 1,50 mm²; light gray Installation Notes Locking system Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/8 Data sheet | Item number: 2091-1108/000-1000 www.wago.com/2091-1108/000-1000 Disconnecting a female connector via unlocking tool. Plug unlocking tool into the male header's locking latch. Insert unlocking tool until it hits the backstop. Wedge opens locking latches. Pull on both unlocking tool and conductors to remove female connector from male header. Conductor termination Inserting fine-stranded conductor into mated female connector via push-button. Inserting a fine-stranded conductor into an unmated female connector via push-button. Inserting solid and ferruled conductors via push-in termination. Marking Pole marking via factory direct marking. Coding Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/8 Data sheet | Item number: 2091-1108/000-1000 www.wago.com/2091-1108/000-1000 Coding a female connector (via coding key carrier and two keys for female connector, see symbol). Testing Testing via 1 mm Ø test pin – touch contact. Product family picoMAX® 3.5 Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/8
2091-1108/000-1000 价格&库存
很抱歉,暂时无法提供与“2091-1108/000-1000”相匹配的价格&库存,您可以联系我们找货
