Data sheet | Item number: 2091-1376
1-conductor THT female connector angled; push-button; Push-in CAGE
CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 6-pole; 1.0 mm Ø solder pin; 1,50
mm²; light gray
www.wago.com/2091-1376
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/8
Dimensions in mm
L = pole no. x pin spacing
A = 3.6 mm THT solder pin
A = 2.4 mm THR solder pin
Item description
Universal connection for all conductor types
Simple, push-in termination of solid and ferruled conductors
Easy-to-use design does not require special tools
Ability to wire while mated or unmated
Integrated test ports for testing parallel to conductor entry
Hansastr. 27
32423 Minden
07.10.2021 Page 2/8
Custom-installed solder pins
Data
Notes
Safety information 1
The picoMAX® Pluggable Connection System includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
160 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Connection data
Total number of connection points
6
Total number of potentials
6
Number of connection types
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.2 … 1.5 mm² / 24 … 14 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 0.75 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 1.5 mm²
Hansastr. 27
32423 Minden
07.10.2021 Page 3/8
0.25 … 1.5 mm²
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Conductor connection direction to PCB
0 °
Pole No.
6
Physical data
Pin spacing
3.5 mm / 0.138 inch
Width
21 mm / 0.827 inch
Height
11.4 mm / 0.449 inch
Depth
14 mm / 0.551 inch
Solder pin length
3.6 mm
Solder pin diameter
1 mm
Drilled hole diameter with tolerance
1.2 (+0.1) mm
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for PCB
Mismating protection
No
Mating direction to the PCB
0 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THT
Material data
Color
light gray
Material group
I
Insulation material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.009 MJ
Weight
3.3 g
Hansastr. 27
32423 Minden
07.10.2021 Page 4/8
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
26 (picoMAX)
PU (SPU)
100 Stück
Packaging type
box
Country of origin
DE
GTIN
4050821162902
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CB
DEKRA Certification B.V.
IEC 61984
NL-49736
/A1
CSA
C22.2
2362521
CSA
C22.2 No. 158
2362521
KEMA/KEUR
EN 61984
71102260
REV.1
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1977
E45171
UL-Approvals
Logo
Optional
accessories
Hansastr. 27
32423 Minden
07.10.2021 Page 5/8
Optional accessories
Coding
Coding
Item no.: 2091-1610
Coding key carrier; suitable for 3.5 mm pin spacing; orange
www.wago.com/2091-1610
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2091-1376
PCB Design
Symbol and Footprint 2091-1376
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
Hansastr. 27
32423 Minden
07.10.2021 Page 6/8
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 2091-1376
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2091-1376
1-conductor THT female connector angled; push-button; Push-in CAGE CLAMP®; 1.5
mm²; Pin spacing 3.5 mm; 6-pole; 1.0 mm Ø solder pin; 1,50 mm²; light gray
Installation Notes
Conductor termination
Terminating fine-stranded conductors and
removing all conductor types via pushbuttons.
Solid and ferruled conductors are
terminated by simply pushing them into unit.
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 7/8
Pole marking via direct marking
perpendicular to conductor entry.
Pole marking via factory direct marking.
Testing
Testing via 1 mm Ø test pin – touch contact.
Product family
picoMAX® eCOM 3.5
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 8/8
很抱歉,暂时无法提供与“2091-1376”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 36+25.77802
- 111+24.59310
- 444+23.39609
- 1108+22.39254
- 3323+21.48572
