2091-1732
    WAGO(万可电子)
    SOLDER PIN STRIP 1.0 MM SOLDER
2091-1732 数据手册
Data sheet | Item number: 2091-1732 THT male header; 1.0 mm Ø solder pin; angled; Pin spacing 3.5 mm; 12-pole; black www.wago.com/2091-1732 i Picture differs from the item. Color: Item description Lötstiftleisten mit geraden und abgewinkelten Lötstiften für rechtwinklige und parallele Steckrichtung zur Leiterplatte Polverlustfreies Aneinanderreihen von mehreren Federleisten in einer Lötstiftleiste zur Trennung von Funktionen möglich Data Notes Safety information 1 The picoMAX® Pluggable Connection System includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Electrical data Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 1/4 Data sheet | Item number: 2091-1732 www.wago.com/2091-1732 Electrical data Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 160 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Number of connection types 1 Number of levels 1 Connection 1 Pole No. 12 Physical data Pin spacing 3.5 mm / 0.138 inch Width 43.7 mm / 1.720 inch Height 7.1 mm / 0.28 inch Height from the surface 3.5 mm / 0.138 inch Depth 10.2 mm / 0.402 inch Solder pin length 3.6 mm Solder pin diameter 1 mm Drilled hole diameter with tolerance 1.2 (+0.1) mm Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection No Mating direction to the PCB 0  ° Locking of plug-in connection Without Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 2/4 Data sheet | Item number: 2091-1732 www.wago.com/2091-1732 PCB contact PCB Contact THT Material data Note on material data Information on material data can be found here Color black Material group I Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight 1.6 g Environmental requirements Limit temperature range -60 … +100 °C Commercial data PU (SPU) 300 Stück Packaging type bag Country of origin CN GTIN 4055143935661 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-49736/A CSA DEKRA Certification B.V. C22.2 2362521 KEMA/KEUR DEKRA Certification B.V. EN 61984 71102260REV. 1 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 3/4 Data sheet | Item number: 2091-1732 www.wago.com/2091-1732 UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 UL Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.2091-1132 www.wago.com/20911-conductor female connector; push-button; Push-in CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 12-pole; 1132 1,50 mm²; light gray Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 2091-1732 THT male header; 1.0 mm Ø solder pin; angled; Pin spacing 3.5 mm; 12-pole; black Installation Notes Product family picoMAX® 3.5 Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 4/4
2091-1732 价格&库存
很抱歉,暂时无法提供与“2091-1732”相匹配的价格&库存,您可以联系我们找货
