2092-1410
2092-1410
    WAGO(万可电子)
    插件,P=5mm
    接线端子 间距:5.00mm 1x10P 直插
2092-1410 数据手册
Data sheet | Item number: 2092-1410 THT male header; 1.4 mm Ø solder pin; straight; Pin spacing 5 mm; 10-pole; light gray www.wago.com/2092-1410 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/8 Data sheet | Item number: 2092-1410 www.wago.com/2092-1410 Dimensions in mm L = (pole no. x pin spacing) + 2.2 mm A = 3.6 mm THT solder pin A = 2.4 mm THR solder pin Item description Assembly of female connectors without loss of poles, allowing different functions to be divided within one male header Coding pins inserted into the header interface prevent mismating, allowing subsequent coding in panel feedthrough applications The female connector is fully shrouded by the male header's housing, providing vibration resistance up to 20 g Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/8 Data sheet | Item number: 2092-1410 www.wago.com/2092-1410 Data Notes Safety information 1 The picoMAX® Pluggable Connection System includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Direct marking Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 16 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Total number of potentials 10 Number of connection types 1 Number of levels 1 Pole No. 10 Physical data Pin spacing 5 mm / 0.197 inch Width 52.2 mm / 2.055 inch Height 23.1 mm / 0.909 inch Height from the surface 19.5 mm / 0.768 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/8 Data sheet | Item number: 2092-1410 www.wago.com/2092-1410 Height from the surface 19.5 mm / 0.768 inch Depth 14.4 mm / 0.567 inch Solder pin length 3.6 mm Solder pin diameter 1.4 mm Drilled hole diameter with tolerance 1.6 (+0.1) mm Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection No Mating direction to the PCB 90 ° Locking of plug-in connection Locking latch PCB contact PCB Contact THT Material data Color light gray Material group I Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.107 MJ Weight 5.7 g Environmental requirements Limit temperature range -60 … +100 °C Commercial data Product Group 26 (picoMAX) PU (SPU) 100 Stück Packaging type box Country of origin DE GTIN 4050821163893 Customs tariff number 85366990990 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/8 Data sheet | Item number: 2092-1410 www.wago.com/2092-1410 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CB DEKRA Certification B.V. IEC 61984 NL-49737 /A1 CSA DEKRA Certification B.V. C22.2 2362521 CSA DEKRA Certification B.V. C22.2 No. 158 2362521 KEMA/KEUR DEKRA Certification B.V. EN 61984 71102261 REV.1 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 E45172 UL Underwriters Laboratories Inc. UL 1977 E45171 UL-Approvals Logo Counterpart Item no.2092-1130 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; 2,50 mm²; light gray www.wago.com/20921130 Item no.2092-1110/000-5000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; Gripping plate; direct marking; 2,50 mm²; light gray www.wago.com/20921110/000-5000 Item no.2092-1110/000-1000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2092- Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/8 Data sheet | Item number: 2092-1410 www.wago.com/2092-1410 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; Gripping plate; direct marking; 2,50 mm²; light gray www.wago.com/20921110/000-1000 Item no.2092-1110 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; Gripping plate; 2,50 mm²; light gray www.wago.com/20921110 Item no.2092-1110/002-000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; Gripping plate sliding connector release; 2,50 mm²; light gray www.wago.com/20921110/002-000 Item no.2092-1130/000-1000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; direct marking; 2,50 mm²; light gray www.wago.com/20921130/000-1000 Item no.2092-1110/002-1000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; Gripping plate sliding connector release; direct marking; 2,50 mm²; light gray www.wago.com/20921110/002-1000 Item no.2092-1130/000-5000 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; direct marking; 2,50 mm²; light gray www.wago.com/20921130/000-5000 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2092-1410 PCB Design Symbol and Footprint 2092-1410 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/8 Data sheet | Item number: 2092-1410 www.wago.com/2092-1410 Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 2092-1410 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 2092-1410 THT male header; 1.4 mm Ø solder pin; straight; Pin spacing 5 mm; 10-pole; light gray Installation Notes Coding Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/8 Data sheet | Item number: 2092-1410 www.wago.com/2092-1410 Coding a male header (via coding key carrier and two keys for male header, see symbol). Product family picoMAX® 5.0 Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/8
2092-1410 价格&库存
很抱歉,暂时无法提供与“2092-1410”相匹配的价格&库存,您可以联系我们找货
