2092-1633/024-000
2092-1633/024-000
    WAGO(万可电子)
    PANEL FEEDTHROUGH MALE CONNECTOR
2092-1633/024-000 数据手册
Data sheet | Item number: 2092-1633/024-000 Panel feedthrough male connector; clamping collar; 3-pole; Pin spacing 5 mm; light gray www.wago.com/2092-1633/024-000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 1/7 Data sheet | Item number: 2092-1633/024-000 www.wago.com/2092-1633/024-000 Dimensions in mm L = (pole no. x pin spacing) + 2.2 mm L1 = (pole no. x pin spacing) + 8 mm L2 = (pole no. x pin spacing) + 7 mm Item description Male connectors for screw mounting in device or enclosure panels External plug-in connection via locking latches to female connectors with conductor terminations Internal plug-in connection to female headers with solder pins or female connectors with conductor terminations Also available with pre-assembled female connectors on both sides Fixing flanges also suitable for panel mounting Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 2/7 Data sheet | Item number: 2092-1633/024-000 www.wago.com/2092-1633/024-000 Fixing flanges also suitable for panel mounting Data Notes Safety information 1 The picoMAX® Pluggable Connection System includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 16 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Total number of potentials 3 Number of connection types 1 Number of levels 1 Pole No. 3 Physical data Pin spacing 5 mm / 0.197 inch Width 29.2 mm / 1.15 inch Height 14.4 mm / 0.567 inch Depth 33.4 mm / 1.315 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 3/7 Data sheet | Item number: 2092-1633/024-000 www.wago.com/2092-1633/024-000 Depth 33.4 mm / 1.315 inch Mechanical data Mounting type Mounting flange Mounting type Feed-through mounting Panel mounting Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for pluggable connector Mismating protection No Locking of plug-in connection Locking latch Material data Color light gray Material group I Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.08 MJ Weight 3.4 g Environmental requirements Limit temperature range -60 … +100 °C Commercial data Product Group 26 (picoMAX) PU (SPU) 100 Stück Packaging type box Country of origin DE GTIN 4050821165712 Customs tariff number 85366990990 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 4/7 Data sheet | Item number: 2092-1633/024-000 www.wago.com/2092-1633/024-000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CB DEKRA Certification B.V. IEC 61984 NL-49737 /A1 CSA DEKRA Certification B.V. C22.2 2362521 CSA DEKRA Certification B.V. C22.2 No. 158 2362521 KEMA/KEUR DEKRA Certification B.V. EN 61984 71102261 REV.2 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 E45172 UL Underwriters Laboratories Inc. UL 1977 E45171 UL-Approvals Logo Counterpart Item no.2092-1123 1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 3-pole; 2,50 mm²; light gray www.wago.com/20921123 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 5/7 Data sheet | Item number: 2092-1633/024-000 www.wago.com/2092-1633/024-000 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2092-1633/024-000 CAE data ZUKEN Portal 2092-1633/024-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 2092-1633/024-000 Panel feedthrough male connector; clamping collar; 3-pole; Pin spacing 5 mm; light gray Installation Notes “Wire-to-wire” panel feedthrough connection Notice: Male connectors must not be live when disconnected! Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 6/7 Data sheet | Item number: 2092-1633/024-000 www.wago.com/2092-1633/024-000 “Wire-to-board” panel feedthrough connection Product family picoMAX® 5.0 Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 7/7
2092-1633/024-000 价格&库存
很抱歉,暂时无法提供与“2092-1633/024-000”相匹配的价格&库存,您可以联系我们找货
2092-1633/024-000
    • 70+13.07038
    • 219+12.42955
    • 873+11.88546
    • 2183+11.42600
    • 6547+10.88191
    库存:492
    2092-1633/024-000
      库存:492
