Data sheet | Item number: 2092-3705/200-000
Solder pin strip; 1.4 mm Ø solder pin; straight; Pin spacing 7.5 mm; 5-pole;
black
www.wago.com/2092-3705/200-000
Color:
Item description
Lötstiftleisten mit geraden und abgewinkelten Lötstiften für rechtwinklige und parallele Steckrichtung zur Leiterplatte
Polverlustfreies Aneinanderreihen von mehreren Federleisten in einer Lötstiftleiste zur Trennung von Funktionen möglich
Subject to changes. Please also observe the further product documentation!
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
19.11.2021 Page 1/5
Data
Notes
Safety information 1
The picoMAX® Pluggable Connection System includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
400 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
16 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Connection data
Number of connection types
1
Number of levels
1
Connection 1
Pole No.
5
Physical data
Pin spacing
7.5 mm / 0.295 inch
Width
40.4 mm / 1.591 inch
Height
13.4 mm / 0.528 inch
Height from the surface
11 mm / 0.433 inch
Depth
2.8 mm / 0.110 inch
Solder pin length
2.4 mm
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 2/5
Solder pin length
2.4 mm
Solder pin diameter
1.4 mm
Plated through-hole diameter (THR)
1.6 (+0.1) mm
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
No
Mating direction to the PCB
90 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THR
Material data
Color
black
Material group
I
Insulation material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Weight
1 g
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
PU (SPU)
400 Stück
Packaging type
bag
Country of origin
CN
GTIN
4055143934879
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Certificate
19.11.2021 Page 3/5
Approval
Additional Approval Text
Certificate
name
CSA
DEKRA Certification B.V.
C22.2
2362521
KEMA/KEUR
EN 61984
71102261
REV.2
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1977
E45171
Logo
UL-Approvals
Logo
Counterpart
Item no.2092-3125
1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 7.5 mm; 5-pole;
2,50 mm²; light gray
www.wago.com/20923125
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
THR Soldering Process
pdf
2.0 MB
Download
pdf
402.7 kB
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2092-3705/200-000
Solder pin strip; 1.4 mm Ø solder pin; straight; Pin spacing 7.5 mm; 5-pole; black
Installation
NotesPlease also observe the further product documentation!
Subject to changes.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 4/5
Installation Notes
Product family
picoMAX® 7.5
Show all products from the family
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 5/5
很抱歉,暂时无法提供与“2092-3705/200-000”相匹配的价格&库存,您可以联系我们找货
