Data sheet | Item number: 218-505
PCB terminal block; Locking slides; 0.5 mm²; Pin spacing 2.54 mm; 5-pole;
CAGE CLAMP®; 0,50 mm²; gray
www.wago.com/218-505
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/9
Dimensions in mm
L = (pole no. x pin spacing) + 1.5 mm
A groove at the back of the terminal strip indicates the 2.54 mm
pin spacing (red circle).
Item description
Terminal strips are just 8.1 mm tall and feature an innovative, locking slide-actuated CAGE CLAMP®
Several clamping units can be held open simultaneously
Easily terminate stranded conductors in
tight spaces (e.g., bus connectors)
Hansastr. 27
32423 Minden
07.10.2021 Page 2/9
Data
Notes
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Other colors
Mixed-color PCB connector strips
Direct marking
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
150 V
Rated current UL (Use Group B)
4 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
150 V
Rated current CSA (Use Group B)
4 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
80 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
6 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Connection data
Total number of connection points
5
Total number of potentials
5
Number of connection types
1
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Slider
Solid conductor
0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 mm²
Note (conductor cross-section)
Terminating 0.75 mm²/18 AWG conductors is possible; however
insulation diameter allows only every other clamping unit to be
Hansastr. 27
32423 Minden
07.10.2021 Page 3/9
terminated with this conductor size.
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Conductor connection direction to PCB
40 °
Pole No.
5
Physical data
Pin spacing
2.54 mm / 0.1 inch
Width
14.2 mm / 0.559 inch
Height
10.9 mm / 0.429 inch
Height from the surface
8.1 mm / 0.319 inch
Depth
13 mm / 0.512 inch
Solder pin length
2.8 mm
Solder pin dimensions
0.5 x 0.75 mm
Drilled hole diameter with tolerance
1.1 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.083 MJ
Weight
1.7 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Hansastr. 27
32423 Minden
07.10.2021 Page 4/9
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
500 (100) Stück
Packaging type
box
Country of origin
PL
GTIN
4044918878340
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7076
CCA
EN 60947-7-4
NTR NL7785
CCA
EN 60947-7-4
77-111038
CSA
C22.2 No. 158
1565656
ENEC
EN 60947
2160584.01
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
UL-Approvals
Logo
Hansastr. 27
32423 Minden
07.10.2021 Page 5/9
Optional accessories
Testing and measuring
Testing accessories
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Tool
Operating tool
Item no.: 210-648
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short
www.wago.com/210-648
Item no.: 210-719
www.wago.com/210-719
Marking accessories
Marking strip
Item no.: 210-331/254-204
www.wago.com/210-331
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/254-204
length 182 mm; Horizontal marking; Self-adhesive; white
Item no.: 210-331/254-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/254-206
Item no.: 210-331/254-202
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/254-202
Item no.: 210-331/254-207
Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip
/254-207
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Ferrule
Ferrule
Downloads
Hansastr. 27
32423 Minden
07.10.2021 Page 6/9
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 218-505
URL
Download
ZUKEN Portal 218-505
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 218-505
CAE data
PCB Design
Symbol and Footprint 218-505
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
Hansastr. 27
32423 Minden
07.10.2021 Page 7/9
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 218-505
URL
Download
PCB terminal block; Locking slides; 0.5 mm²; Pin spacing 2.54 mm; 5-pole; CAGE
Installation Notes
Conductor termination
Terminating stranded conductors in
confined spaces requires a great deal of
patience, unless you use the new 218 Series
PCB Terminal Strips. The clamping units of
these strips can be held open during
termination process via integrated locking
slide.
is possible; however insulation diameter
Conductor termination: To momentarily
open the clamping unit, use screwdriver and
then insert a stripped conductor. To open
clamping unit for an extended period, move
locking slide toward conductor entry hole.
Then fully insert stripped conductor and
move locking slide back to original position
(also possible to perform with fingernail).
Hansastr. 27
32423 Minden
07.10.2021 Page 8/9
Incorrect – do not operate the locking slides
from the back.
Marking
Labeling with self-adhesive marking strips.
Labeling via factory direct marking.
Testing
Testing directly on the clamping spring.
Hansastr. 27
32423 Minden
07.10.2021 Page 9/9
很抱歉,暂时无法提供与“218-505”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+65.994831+8.56278
- 10+46.8135510+6.07402
- 25+41.1998425+5.34565
- 50+37.7573050+4.89898
- 100+34.94491100+4.53408
- 250+32.05902250+4.15963
- 500+30.39606500+3.94387
- 1000+29.093101000+3.77481
