218-515
218-515
    WAGO(万可电子)
    插件,P=2.54mm
    接线端子 间距:2.54mm 每排针脚数:15 排数:单排
218-515 数据手册
Data sheet | Item number: 218-515 PCB terminal block; Locking slides; 0.5 mm²; Pin spacing 2.54 mm; 15-pole; CAGE CLAMP®; 0,50 mm²; gray www.wago.com/218-515 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/9 Data sheet | Item number: 218-515 www.wago.com/218-515 Dimensions in mm L = (pole no. x pin spacing) + 1.5 mm A groove at the back of the terminal strip indicates the 2.54 mm pin spacing (red circle). Item description Terminal strips are just 8.1 mm tall and feature an innovative, locking slide-actuated CAGE CLAMP® Several clamping units can be held open simultaneously Easily terminate stranded conductors in tight spaces (e.g., bus connectors) Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/9 Data sheet | Item number: 218-515 www.wago.com/218-515 Data Notes Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole numbers Other colors Mixed-color PCB connector strips Direct marking Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 150 V Rated current UL (Use Group B) 4  A Approvals per CSA Rated voltage CSA (Use Group B) 150 V Rated current CSA (Use Group B) 4  A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 80 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 6  A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Total number of connection points 15 Total number of potentials 15 Number of connection types 1 Number of levels 1 Connection technology CAGE CLAMP® Actuation type Slider Solid conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor; with insulated ferrule 0.25 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 mm² Note (conductor cross-section) Terminating 0.75 mm²/18 AWG conductors is possible; however insulation diameter allows only every other clamping unit to be Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/9 Data sheet | Item number: 218-515 www.wago.com/218-515 insulation diameter allows only every other clamping unit to be terminated with this conductor size. Strip length 5 … 6 mm / 0.2 … 0.24 inch Conductor connection direction to PCB 40 ° Pole No. 15 Physical data Pin spacing 2.54 mm / 0.1 inch Width 39.6 mm / 1.559 inch Height 10.9 mm / 0.429 inch Height from the surface 8.1 mm / 0.319 inch Depth 13 mm / 0.512 inch Solder pin length 2.8 mm Solder pin dimensions 0.5 x 0.75 mm Drilled hole diameter with tolerance 1.1 (+0.1) mm PCB contact PCB Contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 2 Material data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.243 MJ Weight 2.7 g Environmental requirements Limit temperature range -60 … +105 °C Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/9 Data sheet | Item number: 218-515 www.wago.com/218-515 Commercial data Product Group 4 (Printed Circuit) PU (SPU) 120 (30) Stück Packaging type box Country of origin PL GTIN 4044918878654 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7076 CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL7785 CCA DEKRA Certification B.V. EN 60947-7-4 77-111038 CSA DEKRA Certification B.V. C22.2 No. 158 1565656 ENEC DEKRA Certification B.V. EN 60947 2160584.01 Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1059 E45172 UL-Approvals Logo Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/9 Data sheet | Item number: 218-515 www.wago.com/218-515 Optional accessories Ferrule     Ferrule Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Marking accessories     Marking strip Item no.: 210-331/254-204 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /254-204 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/254-206 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /254-206 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/254-202 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /254-202 Item no.: 210-331/254-207 Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /254-207 Testing and measuring     Testing accessories Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Tool     Operating tool Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/9 Data sheet | Item number: 218-515 www.wago.com/218-515 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download EPLAN Data Portal 218-515 URL Download ZUKEN Portal 218-515 URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 218-515 CAE data PCB Design Symbol and Footprint 218-515 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/9 Data sheet | Item number: 218-515 www.wago.com/218-515 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Environmental Product Compliance Compliance Search Environmental Product Compliance 218-515 URL Download PCB terminal block; Locking slides; 0.5 mm²; Pin spacing 2.54 mm; 15-pole; CAGE CLAMP®; 0,50 mm²; gray Installation Notes Conductor termination Terminating stranded conductors in confined spaces requires a great deal of patience, unless you use the new 218 Series PCB Terminal Strips. The clamping units of these strips can be held open during termination process via integrated locking slide. Terminating 0.75 mm²/18 AWG conductors is possible; however insulation diameter allows only every other clamping unit to be terminated with this conductor size. Conductor termination: To momentarily open the clamping unit, use screwdriver and then insert a stripped conductor. To open clamping unit for an extended period, move locking slide toward conductor entry hole. Then fully insert stripped conductor and move locking slide back to original position (also possible to perform with fingernail). Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/9 Data sheet | Item number: 218-515 www.wago.com/218-515 Incorrect – do not operate the locking slides from the back. Marking Labeling with self-adhesive marking strips. Labeling via factory direct marking. Testing Testing directly on the clamping spring. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/9
218-515 价格&库存
很抱歉,暂时无法提供与“218-515”相匹配的价格&库存,您可以联系我们找货
  • 1+65.05920
  • 10+54.98280
  • 30+48.83760
  • 100+43.68600
