Data sheet | Item number: 2202-1303
3-conductor through terminal block; with push-button; 2.5 mm²; with test
port; for Ex e II and Ex i applications; side and center marking; for DIN-rail 35
x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 2,50 mm²; red
www.wago.com/2202-1303
i
Picture differs from the item.
Color:
Data
Electrical data
Ratings per
ATEX: PTB 18 ATEX 1005 U / IECEx: PTB 18.0012U (Ex eb IIC Gb)
Rated voltage EN (Ex e II)
550 V
Rated current (Ex e II)
22 A
Rated current (Ex e II) with jumper
20 A
Ratings per
IEC/EN 60947-7-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated current
24 A
Rated current 2
32 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Approvals per
C22.2 No 158
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
20 A
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group C)
20 A
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/19
20 A
Approvals per
UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
20 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
20 A
Connection data
Total number of connection points
3
Total number of potentials
1
Number of levels
1
Number of jumper slots
2
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-in
Push-button
Operating tool
Connectable conductor materials
Copper
Nominal cross-section
2.5 mm²
Solid conductor
0.25 … 4 mm² / 22 … 12 AWG
Solid conductor; push-in termination
0.75 … 4 mm² / 18 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 2.5 mm² / 22 … 14 AWG
Fine-stranded conductor; with ferrule; push-in termination
1 … 2.5 mm² / 18 … 12 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
10 … 12 mm / 0.39 … 0.47 inch
Wiring direction
Front-entry wiring
Physical data
Width
5.2 mm / 0.205 inch
Height
59.2 mm / 2.33 inch
Depth from upper edge of DIN-rail
32.9 mm / 1.295 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Center/side marking
Hansastr. 27
32423 Minden
13.10.2021 Page 2/19
Material data
Color
red
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Weight
6.3 g
Commercial data
PU (SPU)
100 Stück
Packaging type
box
Country of origin
DE
GTIN
4055143999106
Customs tariff number
85369010000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
AEx
Underwriters Laboratories Inc.
UL 60079
E185892
ATEX
Physikalisch Technische Bundesanstalt
IEC 60079-0
PTB 18 ATEX 1005
U (II 2 G Ex eb IIC Gb
bzw. I M 2 Ex eb I
Mb)
CCCEx
CQST/CNEx
CNCA-C23-01
2020312313000169
IECEx
IEC 60079
IECEx PTB 18.0012
U (Ex eb IIC Gb and
Ex eb I Mb)
Country specific Approvals
Logo
Approval
CCA
DEKRA Certification B.V.
EN 60947
KEMA/KEUR
EN 60947
Hansastr. 27
32423 Minden
Certificate
name
NTR NL
7841
71-
13.10.2021 Page 3/19
KEMA/KEUR
EN 60947
71114275
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1866350PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00003JT
LR
Lloyds Register
19/20050
UL-Approvals
Logo
Approval
Certificate
name
cURus
UL 1059
E45172
Required accessories
End plate
End plate
Item no.: 2002-1391
End and intermediate plate; 0.8 mm thick; gray
www.wago.com/2002-1391
Item no.: 2002-1392
End and intermediate plate; 0.8 mm thick; orange
www.wago.com/2002-1392
Optional accessories
Testing and measuring
Testing accessories
Item no.: 2009-174
Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray
www.wago.com/2009-174
Item no.:
2009-182
Subject to changes.
Please
Hansastr. 27
32423 Minden
13.10.2021 Page 4/19
Item no.: 2009-182
Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray
www.wago.com/2009-182
Item no.: 2002-511
Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 2,50 mm²; gray
www.wago.com/2002-511
Item no.: 2002-549
Spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/2002-549
Item no.: 2002-552
Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 2,50 mm²; gray
www.wago.com/2002-552
Item no.: 2002-558
Modular TOPJOB®S connector; modular; for jumper contact slot; 8-pole; 2,50 mm²; gray
www.wago.com/2002-558
Item no.: 2002-559
Modular TOPJOB®S connector; modular; for jumper contact slot; 9-pole; 2,50 mm²; gray
www.wago.com/2002-559
Item no.: 2002-556
Modular TOPJOB®S connector; modular; for jumper contact slot; 6-pole; 2,50 mm²; gray
www.wago.com/2002-556
Item no.: 2002-553
Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 2,50 mm²; gray
www.wago.com/2002-553
Item no.: 2002-611
TOPJOB®S L-type test plug module; modular; 1-pole; 2,50 mm²; gray
www.wago.com/2002-611
Item no.: 2002-560
Modular TOPJOB®S connector; modular; for jumper contact slot; 10-pole; 2,50 mm²; gray
www.wago.com/2002-560
Item no.: 2002-554
Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 2,50 mm²; gray
www.wago.com/2002-554
Item no.: 2002-555
Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 2,50 mm²; gray
www.wago.com/2002-555
Item no.: 2002-557
Modular TOPJOB®S connector; modular; for jumper contact slot; 7-pole; 2,50 mm²; gray
www.wago.com/2002-557
Item no.: 2002-649
TOPJOB®S L-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/2002-649
Marking accessories
Marking strip
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Marker carrier
Item no.: 2009-198
Adaptor; gray
www.wago.com/2009-198
Item no.: 2002-161
Hansastr. 27
32423 Minden
www.wago.com/2002-161
13.10.2021 Page 5/19
Item no.: 2002-161
Adaptor; gray
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
www.wago.com/2009-115
/000-002
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Marker
Item no.: 2009-145/000-006
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-145/000-002
yellow
/000-002
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-012
orange
/000-012
Item no.: 2009-145/000-023
green
/000-023
Item no.: 2009-145/000-024
Hansastr. 27
32423 Minden
13.10.2021 Page 6/19
violet
/000-024
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
www.wago.com/248-501
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-007
www.wago.com/793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on
/000-007
type; gray
Item no.: 793-5501/000-012
Hansastr. 27
32423 Minden
13.10.2021 Page 7/19
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012
type; orange
Item no.: 793-5501/000-014
/000-014
type; brown
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
www.wago.com/793-501
/000-002
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-006
Hansastr. 27
32423 Minden
13.10.2021 Page 8/19
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-005
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Group marker carrier
Item no.: 2009-193
www.wago.com/2009-193
Item no.: 2009-192
Hansastr. 27
32423 Minden
www.wago.com/2009-192
13.10.2021 Page 9/19
Item no.: 2009-192
Item no.: 2009-191
www.wago.com/2009-191
Push-in type wire jumper
Jumper
Item no.: 2009-412
Push-in type wire jumper; insulated; 60 mm long; black
www.wago.com/2009-412
Item no.: 2009-414
Push-in type wire jumper; 1.5 mm²; insulated; 110 mm long; black
www.wago.com/2009-414
Item no.: 2009-416
Push-in type wire jumper; 1.5 mm²; insulated; 250 mm long; black
www.wago.com/2009-416
Item no.: 2009-414/000-005
/000-005
Item no.: 2009-414/000-006
Push-in type wire jumper; insulated; 110 mm long; black
/000-006
Carrier rail
Mounting accessories
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
silver-colored
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-118
Hansastr. 27
32423 Minden
www.wago.com/210-118
13.10.2021 Page 10/19
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Insulation stop
Insulation stop
Item no.: 2002-171
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/2002-171
Item no.: 2002-172
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray
www.wago.com/2002-172
Mounting
Item no.: 709-156
Cover; Type 3; suitable for cover carrier, type 3; 1 m long; transparent
www.wago.com/709-156
Item no.: 709-169
Cover carrier; Type 3; gray
www.wago.com/709-169
Tool
Operating tool
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Item no.: 210-123
Wire commoning chain; insulated; blue
www.wago.com/210-123
Item no.: 2006-499
Step-down jumper; from 2006/2004 to 2004/2002/2001 series; insulated; light gray
www.wago.com/2006-499
Jumpers
Jumper
Item no.: 2002-402
Hansastr. 27
32423 Minden
www.wago.com/2002-402
13.10.2021 Page 11/19
Item no.: 2002-402
Jumper; 2-way; insulated; light gray
Item no.: 2002-402/000-005
Jumper; 2-way; insulated; red
/000-005
Item no.: 2002-400
Continuous jumper; 2-way; insulated; light gray
www.wago.com/2002-400
Item no.: 2002-403
Jumper; 3-way; insulated; light gray
www.wago.com/2002-403
Item no.: 2002-404/000-005
Jumper; 4-way; insulated; red
www.wago.com/2002-404
/000-005
Item no.: 2002-403/000-006
Jumper; 3-way; insulated; blue
/000-006
Item no.: 2002-404/000-006
Jumper; 4-way; insulated; blue
/000-006
Item no.: 2002-403/000-005
Jumper; 3-way; insulated; red
/000-005
Item no.: 2002-405/000-005
Jumper; 5-way; insulated; red
www.wago.com/2002-405
/000-005
Item no.: 2002-402/000-006
Jumper; 2-way; insulated; blue
/000-006
Item no.: 2002-405/000-006
Jumper; 5-way; insulated; blue
/000-006
Item no.: 2002-404
Jumper; 4-way; insulated; light gray
Item no.: 2002-406/000-006
Jumper; 6-way; insulated; blue
www.wago.com/2002-406
/000-006
Item no.: 2002-406/000-005
Jumper; 6-way; insulated; red
/000-005
Hansastr. 27
32423 Minden
13.10.2021 Page 12/19
Item no.: 2002-406/020-000
Delta jumper; insulated; light gray
/020-000
Item no.: 2002-405
Jumper; 5-way; insulated; light gray
Item no.: 2002-407/000-005
Jumper; 7-way; insulated; red
www.wago.com/2002-407
/000-005
Item no.: 2002-408
Jumper; 8-way; insulated; light gray
www.wago.com/2002-408
Item no.: 2002-408/000-006
Jumper; 8-way; insulated; blue
/000-006
Item no.: 2002-405/011-000
Star point jumper; 3-way; insulated; light gray
/011-000
Item no.: 2002-407/000-006
Jumper; 7-way; insulated; blue
/000-006
Item no.: 2002-408/000-005
Jumper; 8-way; insulated; red
/000-005
Item no.: 2002-407
Jumper; 7-way; insulated; light gray
Item no.: 2002-406
Jumper; 6-way; insulated; light gray
Item no.: 2002-410/000-005
Jumper; 10-way; insulated; red
www.wago.com/2002-410
/000-005
Item no.: 2002-410/000-006
Jumper; 10-way; insulated; blue
/000-006
Item no.: 2002-410
Jumper; 10-way; insulated; light gray
Item no.: 2002-409/000-006
Hansastr. 27
32423 Minden
www.wago.com/2002-409
13.10.2021 Page 13/19
Jumper; 9-way; insulated; blue
/000-006
Item no.: 2002-409/000-005
Jumper; 9-way; insulated; red
/000-005
Item no.: 2002-409
Jumper; 9-way; insulated; light gray
Item no.: 2002-423/000-006
Continuous jumper; from 1 to 3; insulated; blue
www.wago.com/2002-423
/000-006
Item no.: 2002-423
Continuous jumper; from 1 to 3; insulated; light gray
Item no.: 2002-433
Jumper; from 1 to 3; insulated; light gray
www.wago.com/2002-433
Item no.: 2002-434
Jumper; from 1 to 4; insulated; light gray
www.wago.com/2002-434
Item no.: 2002-423/000-005
Continuous jumper; from 1 to 3; insulated; red
/000-005
Item no.: 2002-435
Jumper; from 1 to 5; insulated; light gray
www.wago.com/2002-435
Item no.: 2002-436
Jumper; from 1 to 6; insulated; light gray
www.wago.com/2002-436
Item no.: 2002-437
Jumper; from 1 to 7; insulated; light gray
www.wago.com/2002-437
Item no.: 2002-438
Jumper; from 1 to 8; insulated; light gray
www.wago.com/2002-438
Item no.: 2002-439
Jumper; from 1 to 9; insulated; light gray
www.wago.com/2002-439
Item no.: 2002-440
Jumper; from 1 to 10; insulated; light gray
www.wago.com/2002-440
Item no.: 2002-472
Staggered jumper; 2-way; insulated; light gray
www.wago.com/2002-472
Item no.: 2002-473
Staggered jumper; 3-way; insulated; light gray
www.wago.com/2002-473
Item no.: 2002-475/011-000
www.wago.com/2002-475
Hansastr. 27
32423 Minden
13.10.2021 Page 14/19
/011-000
Item no.: 2002-475
Staggered jumper; 5-way; insulated; light gray
Item no.: 2002-476
Staggered jumper; 6-way; insulated; light gray
www.wago.com/2002-476
Item no.: 2002-474
Staggered jumper; 4-way; insulated; light gray
www.wago.com/2002-474
Item no.: 2002-477
Staggered jumper; 7-way; insulated; light gray
www.wago.com/2002-477
Item no.: 2002-473/011-000
Staggered jumper; 2-way; from 1 to 3; insulated; light gray
/011-000
Item no.: 2002-479
Staggered jumper; 9-way; insulated; light gray
www.wago.com/2002-479
Item no.: 2002-478
Staggered jumper; 8-way; insulated; light gray
www.wago.com/2002-478
Item no.: 2002-479/011-000
Staggered jumper; insulated; light gray
/011-000
Item no.: 2002-480
Staggered jumper; 10-way; insulated; light gray
www.wago.com/2002-480
Item no.: 2002-477/011-000
/011-000
Item no.: 2002-481/011-000
www.wago.com/2002-481
/011-000
Item no.: 2002-481
Staggered jumper; 11-way; insulated; light gray
Item no.: 2002-482
Staggered jumper; 12-way; insulated; light gray
www.wago.com/2002-482
Item no.: 2016-499
Step-down jumper; from 2016/2010 to 2010/2006/2004/2002 series; insulated; light gray
www.wago.com/2016-499
Item no.: 210-103
Wire commoning chain; insulated; black
Hansastr. 27
32423 Minden
www.wago.com/210-103
13.10.2021 Page 15/19
Item no.: 2002-880/1000-411
Component plug; 2-pole; with diode 1N4007; 10.4 mm wide; Operating temperature 85°C max.; gray
www.wago.com/2002-880
/1000-411
Item no.: 2002-880/1000-541
Component plug; 2-pole; LED (red); 10.4 mm wide; Operating temperature 85°C max.; gray
/1000-541
Item no.: 2002-880/1000-542
Component plug; 2-pole; LED (red); 10.4 mm wide; Operating temperature 85°C max.; multicoloured
/1000-542
Item no.: 2002-880/1000-836
/1000-836
Plugs
Diode plug
LED plug
Empty component plug housing
Item no.: 2002-880
Empty component plug housing; 10.4 mm wide; 2-pole; Type 4; gray
Item no.: 2002-1393
Seperator plate; 2 mm thick; oversized; gray
www.wago.com/2002-1393
Item no.: 2002-1394
Seperator plate; 2 mm thick; oversized; orange
www.wago.com/2002-1394
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
End plate
End plate
Ferrule
Ferrule
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
Item no.: 216-263
www.wago.com/216-244
www.wago.com/216-263
Hansastr. 27
32423 Minden
13.10.2021 Page 16/19
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-246
Item no.: 216-266
www.wago.com/216-266
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-262
www.wago.com/216-262
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2202-1303
CAE data
ZUKEN Portal 2202-1303
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2202-1303
3-conductor through terminal block; with push-button; 2.5 mm²; with test port; for Ex
e II and Ex i applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5;
Installation Notes
Conductor termination
Hansastr. 27
32423 Minden
13.10.2021 Page 17/19
All conductor types at a glance
Push-in termination of solid and ferruled
conductors
Insert fine-stranded conductors via
operating tool.
Removing all conductors via operating tool.
Commoning
Commoning with step-down jumpers.
Insert a push-in type jumper bar and push
down until it hits the backstop.
Step-down jumper (2006-499) commons 6
/4 mm² (10/12 AWG) terminal blocks (2206
/2204 Series) with 4/2.5/1.5 mm² (AWG 12/14
/16) terminal blocks (2204/2202/2201
Series).
Testing
Hansastr. 27
32423 Minden
13.10.2021 Page 18/19
Testing with a 2 mm Ø test plug (max. 42 V).
Marking
Snapping a marking strip into a marker slot.
Snapping a marking strip into the marker slot.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 19/19
很抱歉,暂时无法提供与“2202-1303”相匹配的价格&库存,您可以联系我们找货
