2202-1711
2202-1711
    WAGO(万可电子)
    3-CONDUCTOR FUSE TERMINAL BLOCK;
2202-1711 数据手册
Data sheet | Item number: 2202-1711 3-conductor fuse terminal block; with pivoting fuse holder; and end plate; for 5 x 20 mm miniature metric fuse; with push-button; without blown fuse indication; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2202-1711 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 1/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Data Electrical data Power loss (max.) Pl (max.) (note) When selecting glass cartridge fuses, make sure that the maximum power loss listed below is not exceeded. The power loss is determined according to IEC or EN 60947-7-3/VDE 0611-6 at 23°C. The temperature rise of the terminal block must be checked according to their application and mounting. Higher ambient temperatures represent an additional impact on miniature fuses. Therefore, in such applications, the rated current must be reduced if necessary. More details are available from the manufacturers. Power loss Pl (max.) 1.6 W Power loss Pl (note) Overload and short circuit protection (Individual arrangement) Power loss Pl 2 (max.) 1.6 W Power loss Pl 2 (note) Overload and short circuit protection (Group arrangement) Power loss Pl 3 (max.) 2.5 W Power loss Pl 3 (note) Short circuit protection only (Individual arrangement) Power loss Pl 4 (max.) 2.5 W Power loss Pl 4 (note) Short circuit protection only (Group arrangement) Ratings per IEC/EN 60947-7-3 Ratings (note) Electrical ratings are given by the fuse. Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 6 kV Rated current 6.3 A Operation status indicator without Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Approvals per C22.2 No 158 Rated voltage CSA (Use Group B) 250 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group C) 250 V Rated current CSA (Use Group C) 10 A Rated voltage CSA (Use Group D) 250 V Rated current CSA (Use Group D) 10 A Approvals per UL 1059 Rated voltage UL (Use Group B) 250 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 250 V Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 2/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Rated voltage UL (Use Group C) 250 V Rated current UL (Use Group C) 10 A Rated voltage UL (Use Group D) 250 V Connection data Total number of connection points 3 Total number of potentials 1 Number of levels 1 Number of jumper slots 2 Connection technology Push-in CAGE CLAMP® Actuation type Push-in Push-button Operating tool Connectable conductor materials Copper Nominal cross-section 2.5 mm² Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor; push-in termination 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor; with ferrule; push-in termination 1 … 2.5 mm² / 18 … 14 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 10 … 12 mm / 0.39 … 0.47 inch Wiring direction Front-entry wiring Physical data Width 6.2 mm / 0.244 inch Height 76.8 mm / 3.024 inch Depth from upper edge of DIN-rail 57.6 mm / 2.268 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Art der Sicherung Cylindrical fuse 5 x 20 mm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 3/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Material data Color gray Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.139 MJ Weight 14.8 g Commercial data PU (SPU) 50 Stück Packaging type box Country of origin DE GTIN 4055143955904 Customs tariff number 85369095000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 E185892 ATEX Physikalisch Technische Bundesanstalt EN IEC 60079-0 PTB 20 ATEX 1007U (II 3 G Ex ec IIC Gc) CCCEx CQST/CNEx CNCA-C23-01 2020312313000288 IECEx Physikalisch Technische Bundesanstalt IEC 60079 IECEx PTB 20.0013 U (Ex ec IIC Gc) Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 701737745 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 4/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 Optional accessories Jumpers     Jumper Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 2004-403 Jumper; 3-way; insulated; light gray www.wago.com/2004-403 Item no.: 2004-406 Jumper; 6-way; insulated; light gray www.wago.com/2004-406 Item no.: 2004-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2004-405 /011-000 Item no.: 2004-402 Jumper; 2-way; insulated; light gray www.wago.com/2004-402 Item no.: 2004-407 Jumper; 7-way; insulated; light gray www.wago.com/2004-407 Item no.: 2004-408 Jumper; 8-way; insulated; light gray www.wago.com/2004-408 Item no.: 2004-404 Jumper; 4-way; insulated; light gray www.wago.com/2004-404 Item no.: 2004-405 Jumper; 5-way; insulated; light gray www.wago.com/2004-405 Item no.: 2004-409 Jumper; 9-way; insulated; light gray www.wago.com/2004-409 Item no.: 2004-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2004-433 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 5/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Jumper; from 1 to 3; insulated; light gray Item no.: 2004-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2004-436 Item no.: 2004-410 Jumper; 10-way; insulated; light gray www.wago.com/2004-410 Item no.: 2004-406/020-000 Delta jumper; insulated; light gray www.wago.com/2004-406 /020-000 Item no.: 2004-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2004-438 Item no.: 2004-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2004-440 Item no.: 2004-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2004-435 Item no.: 2004-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2004-437 Item no.: 2004-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2004-439 Item no.: 2004-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2004-434 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Marking accessories     Marking strip Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110     Marker carrier Item no.: 2009-198 Adaptor; gray www.wago.com/2009-198 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007     Marker Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 6/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 7/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012 type; orange Item no.: 793-5501/000-014 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-014 type; brown Item no.: 793-5501/000-017 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 8/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; green /000-017 Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 9/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-005 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-115 /000-005     Group marker carrier Item no.: 2009-193 Group marker carrier www.wago.com/2009-193 Item no.: 2009-192 Group marker carrier www.wago.com/2009-192 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Ferrule     Ferrule Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight www.wago.com/216-242 crimped; acc. to DIN 46228, Part 4/09.90; gray Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 10/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 crimped; acc. to DIN 46228, Part 4/09.90; gray Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Locking levers     Locking device Item no.: 210-254 Interlocking link; mechanically locks multiple links; 1 m long; transparent www.wago.com/210-254 Insulation stop     Insulation stop Item no.: 2002-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2002-171 Item no.: 2002-172 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray www.wago.com/2002-172 Testing and measuring     Testing accessories Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Tool     Operating tool Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-720 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 11/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Item no.: 2002-991 End plate for fuse terminal blocks; 2 mm thick; gray www.wago.com/2002-991 Item no.: 2002-992 End plate for fuse terminal blocks; 2 mm thick; orange www.wago.com/2002-992 End plate     End plate Mounting     Mounting accessories Item no.: 709-156 Cover; Type 3; suitable for cover carrier, type 3; 1 m long; transparent www.wago.com/709-156 Item no.: 709-169 Cover carrier; Type 3; gray www.wago.com/709-169 Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 12/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Item no.: 210-112 www.wago.com/210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.2 MB Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 2202-1711 3-conductor fuse terminal block; with pivoting fuse holder; and end plate; for 5 x 20 mm miniature metric fuse; with push-button; without blown fuse indication; for DINrail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray Installation Notes Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 13/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 All conductor types at a glance Push-in termination of solid and ferruled conductors Insert fine-stranded conductors via operating tool. Removing all conductors via operating tool. Push-in termination of solid and ferruled conductors Commoning Insert a push-in type jumper bar and push down until it hits the backstop. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 14/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 Marking Snapping a marking strip into a marker slot. Snapping a marking strip into the marker slot. Product family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 15/16 Data sheet | Item number: 2202-1711 www.wago.com/2202-1711 TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 16/16
2202-1711 价格&库存
很抱歉,暂时无法提供与“2202-1711”相匹配的价格&库存,您可以联系我们找货
