Data sheet | Item number: 221-515/000-004
Mounting carrier; for 5-conductor terminal blocks; 221 Series - 4 mm²; with
snap-in mounting foot for horizontal mounting; black
www.wago.com/221-515/000-004
i
Picture differs from the item.
Color:
Data
Physical data
Width
35 mm / 1.378 inch
Height
21.4 mm / 0.843 inch
Height from the surface
16.9 mm / 0.665 inch
Depth
52.8 mm / 2.079 inch
Mechanical data
Mounting type
with snap-in mounting foot for horizontal mounting
Suitable
for 5-wire connectors (4 mm²)
Material data
Color
black
Insulation material
Polyamide (PA66)
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/5
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Weight
5 g
Commercial data
PU (SPU)
50 (10) Stück
Packaging type
box
Country of origin
CN
GTIN
4055143640923
Customs tariff number
39269097900
Optional accessories
Marking accessories
Marking strip
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Downloads
Documentation
Bid Text
221-515/000-004
Feb 19, 2019
xml
2.8 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
URL
Download
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAE data
ZUKEN Portal 221-515/000-004
CAD data
2D/3D Models 221-515/000-004
Environmental
Product Compliance
Hansastr. 27
32423 Minden
07.10.2021 Page 2/5
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 221-515/000-004
URL
Download
Mounting carrier; for 5-conductor terminal blocks; 221 Series - 4 mm²; with snap-in
Installation Notes
Inserting a connector into the mounting
carrier.
Removing a connector from the mounting
carrier.
Conductor termination
Inserting a conductor.
Hansastr. 27
32423 Minden
07.10.2021 Page 3/5
Horizontal screw mounting
Vertical screw mounting
Horizontal mounting via snap-in foot
Vertical mounting via snap-in foot
Strain relief
Use a cable tie to secure the conductors to
the strain relief plate.
The strain relief plate can be removed.
Testing
Hansastr. 27
32423 Minden
07.10.2021 Page 4/5
Testing a connector mounted on the carrier
via test slot.
Application
Connecting a light to the mains.
Marking
Labeling the mounting carrier.
Hansastr. 27
32423 Minden
07.10.2021 Page 5/5
很抱歉,暂时无法提供与“221-515/000-004”相匹配的价格&库存,您可以联系我们找货
