221-412/K194-4045
221-412/K194-4045
    WAGO(万可电子)
    端子 对接接头,闭端,单独开口 连接器 按进式 12-24AWG 透明 - 橙色
221-412/K194-4045 数据手册
ƹ6HULHVLEVER-NUTS® The Next Generation of Compact Splicing Connectors 6(5,(6/(9(5ǫ1876® Compact Splicing Connectors for All Wire Types 10 AWG family ::::$*2&20ǬǬ86 12 AWG family Setting new standards in electrical installation, the 221 Series LEVER-NUTS® splicing connector is now smaller, more user-friendly and made for larger conductors. • &RQQHFWDQ\FRPELQDWLRQRIVROLGVWUDQGHGDQGưH[LEOH copper wires faster and more reliably • Equipped with two test slots: one on the front and one on the back for maximum convenience • Visually inspect for proper strip length and complete wire insertion through its transparent housing • Operate comfortably with lower operating forces by using familiar orange levers current: 20 A •Nominal (30 A 10 AWG) voltage: 600 V •Rated 9VLJQV Ʈ[WXUHV  •Operating temperature: 105 °C LISTED splicing wire •cULus FRQQHFWRUƮOH( Splicing wire connector 667 F Wire Stripped d Properly erly Easily combine various types and sizes of wires: solid, VWUDQGHGDQGưH[LEOH • 12 AWG family: 24 - 12 AWG • 10 AWG family: 20 - 10 AWG l Wire Inserted Properly ly L Two Test Slots 221 Series for 12 AWG $:*&RSHUDWLQJWHPS $:*&RSHUDWLQJWHPS $:*&RSHUDWLQJWHPS 9$LLQPP 9$LLQPP 9$LLQPP 5-conductor nductor connector, with levers 8.3 8.3 3-conductor connector, with levers 8.3 2-conductor connector, with levers 18 .6 .6 18 .6 18 Item No. 29.9 18.7 13.1 Pack-Unit pcs Item No. 221-412 1=box of 100 221-413 1=box of 50 221-415 1=box of 25 221-412/VE00-2500 2500 (bulk) 221-413/VE00-2500 2500 (bulk) 221-415/VE00-1000 1000 (bulk) 221-412/996-010 1=10 (clamshell) 221-413/996-010 221-412/K194-4045/000-100 1=jug of 550 Pack-Unit pcs Item No. Pack-Unit pcs 1=10 (clamshell) 221-415/996-010 221-413/K194-4045/000-100 1=jug of 350 1=10 (clamshell) 221-415/K194-4045/000-100 1=jug of 225 221 Series for 10 AWG • Same design and handling as the original 221, but for larger conductors (10 AWG) and greater current capacity (30 A) • Universal connection technology for ALL copper conductor types sized 20 – 10 AWG 221-613 • Proven and familiar lever technology 221-413 $:*&RSHUDWLQJWHPS $:*&RSHUDWLQJWHPS $:*&RSHUDWLQJWHPS 9$LLQPP 9$LLQPP 9$LLQPP 3-conductor connector,with levers 5-conductor connector,with levers 10.1 10.1 10.1 2-conductor connector,with levers .1 21 .1 21 .1 21 36.7 22.9 16 Item No. Pack-Unit pcs Item No. Pack-Unit pcs Item No. Pack-Unit pcs 221-612 1=box of 50 221-613 1=box of 30 221-615 1=box of 15 221-612/VE00-1000 1000 (bulk) 221-613/VE00-1000 1000 (bulk) 221-615 / VE00-500 500 (bulk) 02817,1*$&&(6625,(6 ([SDQGLQVWDOODWLRQưH[LELOLW\E\FRXSOLQJWKHHDV\WRXVH6HULHVLEVER-NUTS® with these mounting accesssories. The mounting carrier converts the compact splicing connector into a DIN rail or chassis mount terminal block solution. Operating Tool, for opening 221 Series levers • 0RXQWLQJưH[LELOLW\KRUL]RQWDORUYHUWLFDOVQDSWR',1UDLORUVFUHZPRXQWWRưDWSDQHO • Open face design: allows access for wiring and testing even after the connector is mounted into the carrier • Easy wire management: multiple cable tie locations; two marking surfaces; built-in VSDFLQJƮQJHUVIRUYLVXDOVHSDUDWLRQRISRWHQWLDOV Item No.  Pack-Unit pcs 210-102 (12 AWG) 1 210-104 (10 AWG) 1 Accessories for 12 AWG Family Angled DIN rail adapter, in combination with 221-500 or 221-510 mounting carrier for DIN rail mounting 52 21.5 Strain relief plate, IRUVQDSRQƮ[LQJWRRU mounting carrier 25.5 Mounting carrier (DIN rail and panel mount), for 2-, 3- and 5-conductor compact splicing connectors 77.6 67.5 42 Item No. Pack-Unit pcs Item No. Pack-Unit pcs Item No. Pack-Unit pcs 221-500 1=box of 10 222-505 1=box of 10 222-510 1=box of 10 Mounting carrier (Panel mount), for single 2-conductor connector Mounting carrier (Panel mount), for single 3-conductor connector Mounting carrier (Panel mount), for single 5-conductor connector Item No. Pack-Unit pcs Item No. Pack-Unit pcs Item No. Pack-Unit pcs 1=box of 10 221-503 1=box of 10 221-505 1=box of 10  221-502 Accessories for 10 AWG Family Angled DIN rail adapter, in combination with 221-500 or 221-510 mounting carrier for DIN rail mounting 52 21.5 Strain relief plate, IRUVQDSRQƮ[LQJWRRU mounting carrier 28.3 Mounting carrier (DIN rail and panel mount), for 2-, 3- and 5-conductor 10 AWG splicing connectors 94.2 42 67.5 Item No. Pack-Unit pcs Item No. Pack-Unit pcs Item No. Pack-Unit pcs 221-510 1=box of 10 222-505 1=box of 10 222-510 1=box of 10 +$1'/,1* 02817,1* Handling: Access to levers when mounted; wiring possible before and/or after inserting connectors into the carrier Removing connector from the mounting carrier Mounting of strain relief plate (222-505) to the mounting carrier Snapping the angled DIN rail adapter on the mounting carrier Testing connectors via their front test slots, which remain accessible when mounted Insert connector into the single mounting carrier Inserting a conductor into the single mounting carrier Removing a conductor from the single mounting carrier Insert connectors into the mounting carrier Mounting Options: Vertical mounting on DIN rail with wire ties providing strain relief Horizontal mounting with strain relief plate on DIN rail using angled DIN rail adapter Horizontal screw mounting Vertical mounting with strain relief plate on DIN rail; wiring locations LGHQWLƮHGE\ marker strips Horizontal mounting on DIN rail using angled DIN rail adapter Mounting carrier with strain relief plate mounted YHUWLFDOO\RQDưDW panel Horizontal mounting with strain relief SODWHRQưDW panel; wiring locations LGHQWLƮHGXVLQJ marker strips Vertical screw mounting Example: connecting a light using two single mounting carriers 6(5,(6/(9(5ǫ1876® For Hazardous Locations 4 ::::$*2&20ǬǬ86 221 Series LEVER-NUTS® for Hazardous Locations: •Nominal current: 20 A V with spacing between •440 adjacent connectors in hazardous • Easy, fast and reliable connection technology in Ex areas • Excellent for junction boxes in haz-loc applications locations • Approvals: 4 Class 1, Zone 1 Zone 1, 2 V without spacing in •275 hazardous locations V general industry; •600 F85XVUHFRJQL]HGƮOH( •Operating temperature: 105 °C Class 1, Zone 1 $:*&RSHUDWLQJWHPS $:*&RSHUDWLQJWHPS $:*&RSHUDWLQJWHPS 9$LLQPP 9$LLQPP 9$LLQPP 9ZLWKRXWVSDFLQJ  9ZLWKRXWVSDFLQJ  9ZLWKRXWVSDFLQJ  3-conductor connector, with levers 5-conductor connector, with levers 8.3 8.3 8.3 2-conductor connector, with levers 18 .6 .6 .6 18 18 18.7 13.1 29.9 Item No. Pack-Unit pcs Item No. Pack-Unit pcs Item No. Pack-Unit pcs 221-482 1=box of 100 221-483 1=box of 50 221-485 1=box of 25 Handling & Mounting • 0XVWEHXVHGZLWKPRXQWLQJFDUULHUWRIXOƮOO([UHTXLUHPHQWV 25.5 • Mounting carrier can be DIN rail mounted or can be screwed down to a smooth surface Mounting carrier (DIN rail and panel mount), for 2-, 3- and 5-conductor hazardous rdous location splicing connectors 77.6 Item No. Pack-Unit pcs 221-501 1=box of 10 Easy Operation: Easily open lever by hand and insert conductor Push lever back down Install connectors into the mounting carrier Remove connectors without tools Secure the carrier using screws on smooth surfaces Test inserted connectors in the carrier Rated 440 V with spacing between the adjacent connectors Rated 275 V with no spacing between connectors WAGO SA DE CV Carretera estatal 431 Km. 2+200. Lote 99 6 Parque Industrial Tecnologico Innovacion Queretaro El Marques, Qro. 76246 Lada sin Costo: 01 800 288 WAGO (288-9246) Telefono: 422 / 221-5946 info.mx@wago.com www.wago.mx WAGO is a registered trademark of WAGO Verwaltungsgesellschaft mbH. ”Copyright – WAGO Kontakttechnik GmbH & Co. KG – all rights reserved. The content and structure of the WAGO Websites, catalogs, videos, and other WAGO media are subject to copyright. The dissemination or changing of the content of these pages and videos is not permitted. Furthermore, the content may neither be copied nor made available to third parties for commercial purposes. Also subject to copyright are the images and videos that were made available to WAGO Kontakttechnik GmbH & Co. KG by third parties.” 03/2019 - Printed in the United States 0888-0832/0000-0385 WAGO Canada Inc. 1550 Yorkton Court, Unit 1 Burlington, ON L7P 5B7 Telephone: 888 / WAGO 221 (924-6221) info.ca@wago.com www.wago.ca 60394792 WAGO Corporation N120 W19129 Freistadt Road Germantown, Wisconsin 53022 Telephone: 800 / DIN-Rail (346-7245) Fax: 262 / 255-3232 info.us@wago.com www.wago.us
221-412/K194-4045 价格&库存
很抱歉,暂时无法提供与“221-412/K194-4045”相匹配的价格&库存,您可以联系我们找货
221-412/K194-4045
    • 1+324.415071+42.05037
    • 13+232.8940313+30.18750
    • 52+222.2821652+28.81200
    • 130+212.64238130+27.56250
    • 389+203.73165389+26.40750
    库存:2490
    221-412/K194-4045
      • 5+220.74543
      • 13+210.23835
      • 52+200.63810
      • 130+191.95676
      • 389+183.91624
      库存:2490
      221-412/K194-4045
        • 2+474.729182+61.53394
        • 5+328.445395+42.57278
        库存:7
