Data sheet | Item number: 2250-301
2-conductor miniature through terminal block; with push-button; 1 mm²; with
test port; side and center marking; End terminal block with mounting flange;
Push-in CAGE CLAMP®; 1,00 mm²; gray
www.wago.com/2250-301
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/14
Data
Electrical data
Rated voltage EN (Ex e II)
352 V
Rated current (Ex e II)
13.5 A
Rated current (Ex e II) with jumper
12 A
Ratings per
IEC/EN 60947-7-1
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
13.5 A
Rated current 2
17.5 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Approvals per
C22.2 No 158
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group C)
300 V
Hansastr. 27
32423 Minden
07.10.2021 Page 2/14
300 V
Rated current CSA (Use Group C)
10 A
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
10 A
Connection data
Total number of connection points
2
Total number of potentials
1
Number of levels
1
Number of jumper slots
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-in
Push-button
Operating tool
Connectable conductor materials
Copper
Nominal cross-section
1 mm²
Solid conductor
0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor; push-in termination
0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.14 … 0.75 mm² / 24 … 18 AWG
Fine-stranded conductor; with ferrule; push-in termination
0.5 … 0.75 mm² / 20 … 18 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
9 … 11 mm / 0.35 … 0.43 inch
Wiring direction
Front-entry wiring
Physical data
Width
3.5 mm / 0.138 inch
Height from the surface
27.2 mm / 1.071 inch
Depth
33.2 mm / 1.307 inch
Mechanical data
Design
horizontal type
Mounting type
Mounting flange
Marking level
Center/side marking
Hansastr. 27
32423 Minden
07.10.2021 Page 3/14
Marking level
Center/side marking
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Weight
2.5 g
Commercial data
PU (SPU)
100 Stück
Packaging type
box
Country of origin
DE
GTIN
4055143965613
Customs tariff number
85369010000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
AEx
Underwriters Laboratories Inc.
UL 60079
E185892
ATEX
Physikalisch Technische Bundesanstalt
EN IEC 60079-0
PTB 19 ATEX 1019
U (II 2G Ex eb IIC Gb
or I M 2 Ex eb I Mb)
CCCEx
CQST/CNEx
CNCA-C23-01
2020312313000289
IECEx
IEC 60079
IECEx PTB 19.0050
U (Ex eb IIC Gb or
EX eb I Mb)
Country specific Approvals
Logo
Approval
CCA
DEKRA Certification B.V.
EN 60998
Certificate
name
NTR NL
7840
Hansastr. 27
32423 Minden
07.10.2021 Page 4/14
CSA
CSA
C22.2 No. 158
80034182
KEMA/KEUR
EN 60998
71113957
Approval
Certificate
name
cURus
UL 1059
E45172
UL-Approvals
Logo
Counterpart
Item no.2250-321
www.wago.
2-conductor miniature through terminal block; with push-button; 1 mm²; with test port; side and center marking;
com/2250Center terminal block without snap-in mounting foot, without mounting flange; Push-in CAGE CLAMP®; 1,00 mm²; gray 321
Required accessories
End plate
End plate
Item no.: 2050-381
End plate; with fixing flange; 1.3 mm thick; gray
www.wago.com/2050-381
Optional accessories
Ferrule
Ferrule
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
Hansastr. 27
32423 Minden
www.wago.com/216-242
07.10.2021 Page 5/14
crimped; acc. to DIN 46228, Part 4/09.90; gray
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Tool
Operating tool
Item no.: 210-648
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short
www.wago.com/210-648
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-647
Item no.: 210-719
www.wago.com/210-719
Item no.: 2000-408
Jumper; 8-way; insulated; light gray
www.wago.com/2000-408
Item no.: 2000-407
Jumper; 7-way; insulated; light gray
www.wago.com/2000-407
Item no.: 2000-409
Jumper; 9-way; insulated; light gray
www.wago.com/2000-409
Item no.: 2000-408/000-006
Jumper; 8-way; insulated; blue
/000-006
Item no.: 2000-408/000-005
Jumper; 8-way; insulated; red
/000-005
Item no.: 2000-409/000-005
Jumper; 9-way; insulated; red
/000-005
Item no.: 2000-407/000-006
Jumper; 7-way; insulated; blue
/000-006
Item no.: 2000-410
Jumper; 10-way; insulated; light gray
www.wago.com/2000-410
Item no.: 2000-410/000-006
Jumper; 10-way; insulated; blue
/000-006
Jumpers
Jumper
Item no.: 2000-433/000-005
Hansastr. 27
32423 Minden
www.wago.com/2000-433
07.10.2021 Page 6/14
Jumper; from 1 to 3; insulated; red
/000-005
Item no.: 2000-407/000-005
Jumper; 7-way; insulated; red
/000-005
Item no.: 2000-433/000-006
Jumper; from 1 to 3; insulated; blue
/000-006
Item no.: 2000-410/000-005
Jumper; 10-way; insulated; red
/000-005
Item no.: 2000-435
Jumper; from 1 to 5; insulated; light gray
www.wago.com/2000-435
Item no.: 2000-409/000-006
Jumper; 9-way; insulated; blue
/000-006
Item no.: 2000-436
Jumper; from 1 to 6; insulated; light gray
www.wago.com/2000-436
Item no.: 2000-433
Jumper; from 1 to 3; insulated; light gray
Item no.: 2000-434
Jumper; from 1 to 4; insulated; light gray
www.wago.com/2000-434
Item no.: 2000-402
Jumper; 2-way; insulated; light gray
www.wago.com/2000-402
Item no.: 2000-402/000-006
Jumper; 2-way; insulated; blue
/000-006
Item no.: 2000-403
Jumper; 3-way; insulated; light gray
www.wago.com/2000-403
Item no.: 2000-402/000-005
Jumper; 2-way; insulated; red
/000-005
Item no.: 2000-402/000-018
Jumper; 2-way; insulated; yellow-green
/000-018
Item no.: 2000-404
Jumper; 4-way; insulated; light gray
www.wago.com/2000-404
Item no.: 2000-403/000-005
Hansastr. 27
32423 Minden
07.10.2021 Page 7/14
Jumper; 3-way; insulated; red
/000-005
Item no.: 2000-404/000-006
Jumper; 4-way; insulated; blue
/000-006
Item no.: 2000-403/000-006
Jumper; 3-way; insulated; blue
/000-006
Item no.: 2000-404/000-005
Jumper; 4-way; insulated; red
/000-005
Item no.: 2000-405
Jumper; 5-way; insulated; light gray
www.wago.com/2000-405
Item no.: 2000-405/011-000
Star point jumper; 3-way; insulated; light gray
/011-000
Item no.: 2000-405/000-006
Jumper; 5-way; insulated; blue
/000-006
Item no.: 2000-406/000-006
Jumper; 6-way; insulated; blue
www.wago.com/2000-406
/000-006
Item no.: 2000-405/000-005
Jumper; 5-way; insulated; red
/000-005
Item no.: 2000-406
Jumper; 6-way; insulated; light gray
Item no.: 2000-406/000-005
Jumper; 6-way; insulated; red
/000-005
Item no.: 2000-406/020-000
Delta jumper; insulated; light gray
/020-000
Item no.: 2000-437
Jumper; from 1 to 7; insulated; light gray
www.wago.com/2000-437
Item no.: 2000-438
Jumper; from 1 to 8; insulated; light gray
www.wago.com/2000-438
Item no.: 2000-439
Hansastr. 27
32423 Minden
www.wago.com/2000-439
07.10.2021 Page 8/14
Item no.: 2000-439
Jumper; from 1 to 9; insulated; light gray
Item no.: 2000-440
Jumper; from 1 to 10; insulated; light gray
www.wago.com/2000-440
Marking accessories
Marking strip
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-113
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white
www.wago.com/2009-113
Item no.: 2009-113/000-002
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; yellow
/000-002
Item no.: 2009-113/000-012
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; orange
/000-012
Item no.: 2009-113/000-007
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; gray
/000-007
Item no.: 2009-113/000-005
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; red
/000-005
Item no.: 2009-113/000-017
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; light green
/000-017
Item no.: 2009-113/000-006
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; blue
/000-006
Item no.: 2009-113/000-024
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; violet
/000-024
Item no.: 2009-113/000-023
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; green
/000-023
Item no.: 793-3501
WMB marking card; as card; plain; snap-on type; white
www.wago.com/793-3501
Marker
Group marker carrier
Item no.: 2009-191
Hansastr. 27
32423 Minden
07.10.2021 Page 9/14
Item no.: 2009-191
www.wago.com/2009-191
Push-in type wire jumper
Jumper
Item no.: 2009-404
Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; gray
www.wago.com/2009-404
Item no.: 2009-402
Push-in type wire jumper; 0.75 mm²; insulated; 60 mm long; gray
www.wago.com/2009-402
Item no.: 2009-406
Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; gray
www.wago.com/2009-406
Testing and measuring
Testing accessories
Item no.: 2009-174
Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray
www.wago.com/2009-174
Item no.: 2009-182
Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray
www.wago.com/2009-182
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Mounting
Mounting accessories
Item no.: 209-123
Mounting foot with screw; can be screwed on terminal blocks with fixing flange; 6.4 mm wide; gray
www.wago.com/209-123
Item no.: 209-137
Mounting adapter; can be used as end stop; 6.5 mm wide; gray
www.wago.com/209-137
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2250-301
Hansastr. 27
32423 Minden
07.10.2021 Page 10/14
URL
Download
ZUKEN Portal 2250-301
URL
Download
EPLAN Data Portal 2250-301
URL
Download
URL
Download
URL
Download
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2250-301
port; side and center marking; End terminal block with mounting flange; Push-in CAGE
Installation Notes
Installation
Conductor termination
Hansastr. 27
32423 Minden
07.10.2021 Page 11/14
Insert solid conductors via push-in
termination.
Insert ferruled conductors via push-in
termination.
Insert fine-stranded conductors via
operating tool.
Marking strip (2009‑110) inserted in the
marking slot with jumper symbols of the
inserted jumper (picture shows terminal
blocks with push-buttons)
Insert a jumper (star point jumper) and push
down until it hits the backstop (picture
shows terminal blocks with push-buttons).
Remove all conductors via operating tool.
Commoning
Insert a jumper (delta jumper) and push down
until it hits the backstop (picture shows
Hansastr. 27
32423 Minden
07.10.2021 Page 12/14
inserted jumper (2000‑405/011‑000 Delta
Jumper) (picture shows terminal blocks with
push-buttons)
Testing
Testing with a 2 mm Ø 210‑136 Test Plug
(max. 42 V).
Installation
Mounting and securing a terminal strip
directly to the plate via screw-type flanges
(picture shows terminal blocks with pushbuttons).
Terminal strip; with mounting flanges; screw
mounting (picture shows terminal blocks
with push-buttons)
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 13/14
Snapping a WMB marking strip into a marker
slot.
Snapping a marking strip (2009‑110) into a
marker slot.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 14/14
很抱歉,暂时无法提供与“2250-301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.27819
- 10+9.89315
- 25+8.90383
- 100+8.64349
- 500+8.38314
- 国内价格 香港价格
- 1+32.738441+4.25589
- 10+23.3064510+3.02977
- 25+20.3697825+2.64801
- 50+18.5304350+2.40890
- 100+17.00079100+2.21005
- 250+15.40631250+2.00277
- 500+14.47601500+1.88184
- 1000+13.741201000+1.78631
- 5000+12.597585000+1.63765
