2273-500
2273-500
    WAGO(万可电子)
    PUSHWIRE MOUNTING CARRIER; 2273
2273-500 数据手册
Data sheet | Item number: 2273-500 Mounting carrier; for single- and double-row con.; 2273 Series; for DIN-35 rail mounting/screw mounting; orange www.wago.com/2273-500 Color: Data Notes Note One single carrier can hold up to 24 clamping units in a very narrow space. Previously, this was only possible using rail-mount terminal blocks. Advantages: Mount carrier onto DIN-35 rail or via screws – easily and quickly Accommodate three 2.5 mm² (12 AWG) 2273 Series Connectors in a single carrier Easily exchange connectors Large marking area for self-adhesive marking strips or for direct marking with permanent felt-tip pen Physical data Width 18.5 mm / 0.728 inch Height 72.5 mm / 2.854 inch Depth from upper edge of DIN-rail 21.5 mm / 0.846 inch Mechanical data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/4 Data sheet | Item number: 2273-500 www.wago.com/2273-500 Mechanical data Mounting type DIN-35 rail Screw mount Suitable for single- and double-row connectors (2273 Series) Material data Color orange Fire load 0.322 MJ Weight 10.7 g Commercial data Product Group 7 (Push Wire Conn.) PU (SPU) 50 (10) Stück Packaging type box Country of origin DE GTIN 4050821101871 Customs tariff number 39269097900 Approvals / Certificates Ship Approvals Logo Approval Additional Approval Text Certificate name DNV GL Det Norske Veritas, Germanischer Lloyd EN 60998 TAE000015T Optional accessories Marking accessories     Marking strip Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 Downloads Documentation Bid Text 2273-500 May 17, 2017 doc - Datei Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com doc Download 24.1 kB Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/4 Data sheet | Item number: 2273-500 www.wago.com/2273-500 doc - Datei 24.1 kB 2273-500 Feb 19, 2019 xml 2.6 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download EPLAN Data Portal 2273-500 URL Download WSCAD Universe 2273-500 URL Download ZUKEN Portal 2273-500 URL Download URL Download X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 2273-500 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 2273-500 Mounting carrier; for single- and double-row con.; 2273 Series; for DIN-35 rail mounting/screw mounting; orange Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/4 Data sheet | Item number: 2273-500 www.wago.com/2273-500 The mounting carrier is suitable for both connector heights. To adjust the mounting carrier, unlock the latch via operating tool (5.5 mm blade) and move the clamping slide to the required width by rotating the tool. The mounting carrier is suitable for both connector widths and can be adjusted by unlocking the latch via operating tool (5.5 mm blade) and moving the clamping slide to the required width by rotating the tool. The mounting carrier is suitable for both connector widths. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/4
2273-500 价格&库存
很抱歉,暂时无法提供与“2273-500”相匹配的价格&库存,您可以联系我们找货
库存:370
