Data sheet | Item number: 231-107/008-000
1-conductor female connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm;
7-pole; Snap-in mounting feet; 2,50 mm²; gray
www.wago.com/231-107/008-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/14
Dimensions in mm
L = (pole no. x pin spacing) + 1.5 mm
2- to 3-pole female connectors – one latch only
Item description
Universal connection for all conductor types
Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation
Integrated test ports
With coding fingers
Data
Hansastr. 27
32423 Minden
07.10.2021 Page 2/14
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Gold-plated or partially gold-plated contact surfaces
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
16 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL 1977
600 V
Rated current UL 1977
15 A
Connection data
Total number of connection points
7
Total number of potentials
7
Number of connection types
1
Number of levels
1
Hansastr. 27
32423 Minden
07.10.2021 Page 3/14
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm²
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Pole No.
7
Conductor entry direction to mating direction
0 °
Physical data
Pin spacing
5 mm / 0.197 inch
Width
36.5 mm / 1.437 inch
Height
18.8 mm / 0.74 inch
Height from the surface
14.3 mm / 0.563 inch
Depth
26.5 mm / 1.043 inch
Mechanical data
Housing sheet thickness
0.6 … 1.2 mm / 0.024 … 0.047 inch
Mounting type
Snap-in foot
Mounting type
Panel mounting
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Mismating protection
No
Locking of plug-in connection
Without
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Hansastr. 27
32423 Minden
07.10.2021 Page 4/14
Contact plating
tin-plated
Fire load
0.182 MJ
Weight
12.8 g
Environmental requirements
Limit temperature range
-60 … +85 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
25 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918375146
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2
LR 1867725
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
BV
Bureau Veritas S.A.
IEC 60998
11915/D0
BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
Hansastr. 27
32423 Minden
07.10.2021 Page 5/14
UL-Approvals
Logo
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1059
E45172
UR
UL 1977
E45171
Counterpart
Item no.231-607
1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 7-pole; 2,50 mm²; gray
www.wago.com/231-607
Optional accessories
Insulation stop
Insulation stop
Item no.: 231-672
Insulation stop; 0.75 - 1 mm²; dark gray
www.wago.com/231-672
Item no.: 231-670
Insulation stop; 0.08-0.2 mm² / 0.2 mm² “s”; white
www.wago.com/231-670
Item no.: 231-671
Insulation stop; 0.25 - 0.5 mm²; light gray
www.wago.com/231-671
Marking accessories
Marking strip
Item no.: 210-331/500-103
Marking strips; as a DIN A4 sheet; MARKED; 1-12 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip
length 182 mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-331
/500-103
Item no.: 210-331/500-104
Marking strips; as a DIN A4 sheet; MARKED; 13-24 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip
/500-104
Item no.:
210-332/500-202
Subject to changes.
Please
Hansastr. 27
32423 Minden
07.10.2021 Page 6/14
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
/500-206
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
/500-204
Mounting adapter
Mounting accessories
Item no.: 209-148
Multi mounting adapter; for DIN-35 rail; 25 mm wide; gray
www.wago.com/209-148
Item no.: 231-668
Lockout caps; for covering unused clamping units; gray
www.wago.com/231-668
Cover
Cover
Mounting
Item no.: 209-137
Mounting adapter; can be used as end stop; 6.5 mm wide; gray
www.wago.com/209-137
Testing and measuring
Testing accessories
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray
www.wago.com/231-661
Tool
Operating tool
Item no.: 209-130
Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material; white
www.wago.com/209-130
Item no.: 209-132
Operating tool; for connecting comb-style jumper bar; 2-way; of insulating material
www.wago.com/209-132
Item no.: 231-159
Operating tool; natural
Hansastr. 27
32423 Minden
www.wago.com/231-159
07.10.2021 Page 7/14
Item no.: 231-231
Combination operating tool; red
www.wago.com/231-231
Item no.: 231-131
Operating tool; made of insulating material; 1-way; loose; white
www.wago.com/231-131
Item no.: 231-291
Operating tool; made of insulating material; 1-way; loose; red
www.wago.com/231-291
Item no.: 280-432
Operating tool; made of insulating material; 2-way; white
www.wago.com/280-432
Item no.: 280-434
Operating tool; made of insulating material; 4-way
www.wago.com/280-434
Item no.: 280-437
Operating tool; made of insulating material; 7-way
www.wago.com/280-437
Item no.: 280-440
Operating tool; made of insulating material; 10-way
www.wago.com/280-440
Item no.: 280-435
Operating tool; made of insulating material; 5-way; gray
www.wago.com/280-435
Item no.: 280-436
Operating tool; made of insulating material; 6-way
www.wago.com/280-436
Item no.: 280-438
Operating tool; made of insulating material; 8-way
www.wago.com/280-438
Item no.: 280-433
Operating tool; made of insulating material; 3-way
www.wago.com/280-433
Strain relief
Strain relief housing
Item no.: 232-607
Strain relief housing; gray
www.wago.com/232-607
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Ferrule
Ferrule
Hansastr. 27
32423 Minden
07.10.2021 Page 8/14
Item no.: 216-106
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.:
216-201
Subject to changes.
Please
Hansastr. 27
32423 Minden
07.10.2021 Page 9/14
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Jumpers
Hansastr. 27
32423 Minden
07.10.2021 Page 10/14
Jumpers
Jumper
Item no.: 231-905
Jumper; for conductor entry; 5-way; insulated; gray
www.wago.com/231-905
Item no.: 231-903
Jumper; for conductor entry; 3-way; insulated; gray
www.wago.com/231-903
Item no.: 231-907
Jumper; for conductor entry; 7-way; insulated; gray
www.wago.com/231-907
Item no.: 231-910
Jumper; for conductor entry; 10-way; insulated; gray
www.wago.com/231-910
Item no.: 231-902
Jumper; for conductor entry; 2-way; insulated; gray
www.wago.com/231-902
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 231-107/008-000
URL
Download
ZUKEN Portal 231-107/008-000
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 231-107/008-000
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 231-107/008-000
1-conductor female connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 7-pole;
Hansastr. 27
32423 Minden
07.10.2021 Page 11/14
Installation Notes
Inserting a conductor via 3.5 mm
screwdriver – CAGE CLAMP® actuation
parallel to conductor entry.
perpendicular to conductor entry.
Inserting a conductor into CAGE CLAMP®
unit via operating lever (231-291).
Inserting a conductor via operating tool.
Hansastr. 27
32423 Minden
07.10.2021 Page 12/14
Coding a female connector by removing
coding finger(s).
Testing – female connector with CAGE
CLAMP®
Integrated test ports for testing
perpendicular to conductor entry via 2 or 2.3
mm Ø test plug
Installation
Male connector with strain relief plate
Strain relief housing shown with a male
connector equipped with CAGE CLAMP®
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 13/14
Marking
Labeling via direct marking or self-adhesive
strips.
Product family
MCS MIDI Classic
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 14/14
很抱歉,暂时无法提供与“231-107/008-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+118.634701+15.36735
