Data sheet | Item number: 231-122/037-000
1-conductor female connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm;
22-pole; Lateral locking levers; 2,50 mm²; gray
www.wago.com/231-122/037-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/14
Dimensions in mm
L = pole no. x pin spacing
2- to 3-pole female connectors – one latch only
Item description
Universal connection for all conductor types
Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation
Integrated test ports
With coding fingers
Data
Hansastr. 27
32423 Minden
13.10.2021 Page 2/14
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Variants:
Gold-plated or partially gold-plated contact surfaces
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
16 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL 1977
600 V
Rated current UL 1977
15 A
Connection data
Total number of connection points
22
Total number of potentials
22
Number of connection types
1
Hansastr. 27
32423 Minden
13.10.2021 Page 3/14
1
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm²
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Pole No.
22
Conductor entry direction to mating direction
0 °
Physical data
Pin spacing
5 mm / 0.197 inch
Width
126.6 mm / 4.984 inch
Height
14.3 mm / 0.563 inch
Depth
29.6 mm / 1.165 inch
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Mismating protection
No
Locking of plug-in connection
locking lever
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.579 MJ
Weight
40 g
Hansastr. 27
32423 Minden
13.10.2021 Page 4/14
Environmental requirements
Limit temperature range
-60 … +85 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
10 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918343084
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2
LR 1867725
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
BV
Bureau Veritas S.A.
IEC 60998
11915/D0
BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Approval
UL
UL 1059
Hansastr. 27
32423 Minden
Certificate
name
E45172
13.10.2021 Page 5/14
UL
Underwriters Laboratories Inc.
UL 1059
E45172
UR
UL 1977
E45171
Counterpart
Item no.231-622
1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 22-pole; 2,50 mm²;
gray
www.wago.com/231-622
Item no.231-152/001-000
THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 22-pole; gray
www.wago.com/231-152/001000
Item no.231-452/001-000
THT male header; 1.0 x 1.0 mm solder pin; angled; Pin spacing 5 mm; 22-pole; gray
www.wago.com/231-452/001000
Optional accessories
Tool
Operating tool
Item no.: 209-130
Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material; white
www.wago.com/209-130
Item no.: 209-132
Operating tool; for connecting comb-style jumper bar; 2-way; of insulating material
www.wago.com/209-132
Item no.: 231-159
Operating tool; natural
www.wago.com/231-159
Item no.: 231-231
Combination operating tool; red
www.wago.com/231-231
Item no.: 231-131
Operating tool; made of insulating material; 1-way; loose; white
www.wago.com/231-131
Item no.: 231-291
Operating tool; made of insulating material; 1-way; loose; red
www.wago.com/231-291
Item no.: 280-432
Hansastr. 27
32423 Minden
www.wago.com/280-432
13.10.2021 Page 6/14
Item no.: 280-432
Operating tool; made of insulating material; 2-way; white
Item no.: 280-434
Operating tool; made of insulating material; 4-way
www.wago.com/280-434
Item no.: 280-437
Operating tool; made of insulating material; 7-way
www.wago.com/280-437
Item no.: 280-440
Operating tool; made of insulating material; 10-way
www.wago.com/280-440
Item no.: 280-435
Operating tool; made of insulating material; 5-way; gray
www.wago.com/280-435
Item no.: 280-436
Operating tool; made of insulating material; 6-way
www.wago.com/280-436
Item no.: 280-438
Operating tool; made of insulating material; 8-way
www.wago.com/280-438
Item no.: 280-433
Operating tool; made of insulating material; 3-way
www.wago.com/280-433
Item no.: 231-905
Jumper; for conductor entry; 5-way; insulated; gray
www.wago.com/231-905
Item no.: 231-903
Jumper; for conductor entry; 3-way; insulated; gray
www.wago.com/231-903
Item no.: 231-907
Jumper; for conductor entry; 7-way; insulated; gray
www.wago.com/231-907
Item no.: 231-910
Jumper; for conductor entry; 10-way; insulated; gray
www.wago.com/231-910
Item no.: 231-902
Jumper; for conductor entry; 2-way; insulated; gray
www.wago.com/231-902
Item no.: 231-668
Lockout caps; for covering unused clamping units; gray
www.wago.com/231-668
Jumpers
Jumper
Cover
Cover
Testing and measuring
Testing accessories
Item no.: 210-136
Hansastr. 27
32423 Minden
www.wago.com/210-136
13.10.2021 Page 7/14
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray
www.wago.com/231-661
Insulation stop
Insulation stop
Item no.: 231-672
Insulation stop; 0.75 - 1 mm²; dark gray
www.wago.com/231-672
Item no.: 231-670
Insulation stop; 0.08-0.2 mm² / 0.2 mm² “s”; white
www.wago.com/231-670
Item no.: 231-671
Insulation stop; 0.25 - 0.5 mm²; light gray
www.wago.com/231-671
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Ferrule
Ferrule
Item no.: 216-132
Hansastr. 27
32423 Minden
13.10.2021 Page 8/14
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Hansastr. 27
32423 Minden
13.10.2021 Page 9/14
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Marking accessories
Marking strip
Item no.: 210-331/500-103
Marking strips; as a DIN A4 sheet; MARKED; 1-12 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip
length 182 mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-331
/500-103
Item no.: 210-331/500-104
Marking strips; as a DIN A4 sheet; MARKED; 13-24 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip
/500-104
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
/500-206
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
Hansastr. 27
32423 Minden
13.10.2021 Page 10/14
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
/500-205
/500-204
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 231-122/037-000
URL
Download
URL
Download
ZUKEN Portal 231-122/037-000
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 231-122/037-000
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 231-122/037-000
1-conductor female connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 22-pole;
Installation Notes
Hansastr. 27
32423 Minden
13.10.2021 Page 11/14
Inserting a conductor via 3.5 mm
screwdriver – CAGE CLAMP® actuation
parallel to conductor entry.
perpendicular to conductor entry.
Inserting a conductor into CAGE CLAMP®
unit via operating lever (231-291).
Inserting a conductor via operating tool.
Coding a female connector by removing
coding finger(s).
Hansastr. 27
32423 Minden
13.10.2021 Page 12/14
Testing – female connector with CAGE
CLAMP®
Integrated test ports for testing
perpendicular to conductor entry via 2 or 2.3
mm Ø test plug
Installation
Male connector with strain relief plate
Strain relief housing shown with a male
connector equipped with CAGE CLAMP®
Marking
Hansastr. 27
32423 Minden
13.10.2021 Page 13/14
Labeling via direct marking or self-adhesive
strips.
Product family
MCS MIDI Classic
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 14/14
很抱歉,暂时无法提供与“231-122/037-000”相匹配的价格&库存,您可以联系我们找货
