Data sheet | Item number: 231-2110/026-000
2-conductor female connector; Push-in CAGE CLAMP®; 2.5 mm²; Pin
spacing 5 mm; 10-pole; with integrated end plate; 2,50 mm²; gray
www.wago.com/231-2110/026-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
19.11.2021 Page 1/12
Dimensions in mm
L = (pole no. – 2) x pin spacing + 10 mm
Item description
Universal connection for all conductor types
Two conductor entries per pole
For looping through power or data buses
Bus connection is retained, even when unmated
Push-in termination of solid and ferruled conductors
With coding fingers
Data
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 2/12
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Variants:
Gold-plated or partially gold-plated contact surfaces
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
16 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
20 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Ratings per UL
Rated voltage UL 1977
600 V
Rated current UL 1977
20 A
Ratings per CSA
Approvals per
CSA
Rated voltage
CSAPlease
(Use Group
B)
Subject
to changes.
also observe
the further product documentation!300 V
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 3/12
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Total number of connection points
Total number of potentials
10
Number of connection types
1
Number of levels
1
Connection 1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.2 … 2.5 mm² / 24 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm²
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Pole No.
10
Conductor entry direction to mating direction
0 °
Physical data
Pin spacing
5 mm / 0.197 inch
Width
50 mm / 1.969 inch
Height
20.8 mm / 0.819 inch
Depth
26.45 mm / 1.041 inch
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Mismating protection
No
Locking of plug-in connection
Without
Material data
Color
gray
Material group
I
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 4/12
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.356 MJ
Weight
22.1 g
Environmental requirements
Limit temperature range
-60 … +85 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
50 Stück
Packaging type
box
Country of origin
PL
GTIN
4044918563161
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Approval
UL Please also observe the further product documentation!UL 1059
Subject to changes.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Certificate
name
E45172
19.11.2021 Page 5/12
Logo
Approval
name
UL
Underwriters Laboratories Inc.
UL 1059
E45172
UL
UL 1977
E45171
Counterpart
Item no.231-610
1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 10-pole; 2,50 mm²;
gray
www.wago.com/231-610
Item no.231-140/001-000
THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 10-pole; gray
www.wago.com/231-140/001000
Item no.231-440/001-000
THT male header; 1.0 x 1.0 mm solder pin; angled; Pin spacing 5 mm; 10-pole; gray
www.wago.com/231-440/001000
Optional accessories
Testing and measuring
Testing accessories
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray
www.wago.com/231-661
Marking accessories
Marking strip
Item no.: 210-331/500-103
Marking strips; as a DIN A4 sheet; MARKED; 1-12 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip
length 182 mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-331
/500-103
Item no.: 210-331/500-104
Marking strips; as a DIN A4 sheet; MARKED; 13-24 (300x); Height of marker strip: 2.3 mm/0.091 in; Strip
/500-104
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 6/12
/500-206
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
/500-204
Strain relief
Strain relief plate
Item no.: 734-326
Strain relief plate; gray
www.wago.com/734-326
Insulation stop
Insulation stop
Item no.: 231-672
Insulation stop; 0.75 - 1 mm²; dark gray
www.wago.com/231-672
Item no.: 231-670
Insulation stop; 0.08-0.2 mm² / 0.2 mm² “s”; white
www.wago.com/231-670
Item no.: 231-671
Insulation stop; 0.25 - 0.5 mm²; light gray
www.wago.com/231-671
Tool
Operating tool
Item no.: 209-130
Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material; white
www.wago.com/209-130
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Item no.: 280-432
Operating tool; made of insulating material; 2-way; white
www.wago.com/280-432
Item no.: 280-434
Operating tool; made of insulating material; 4-way
www.wago.com/280-434
Item no.: 280-437
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
www.wago.com/280-437
19.11.2021 Page 7/12
Item no.: 280-437
Operating tool; made of insulating material; 7-way
Item no.: 280-440
Operating tool; made of insulating material; 10-way
www.wago.com/280-440
Item no.: 280-435
Operating tool; made of insulating material; 5-way; gray
www.wago.com/280-435
Item no.: 280-436
Operating tool; made of insulating material; 6-way
www.wago.com/280-436
Item no.: 280-438
Operating tool; made of insulating material; 8-way
www.wago.com/280-438
Item no.: 280-433
Operating tool; made of insulating material; 3-way
www.wago.com/280-433
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Ferrule
Ferrule
Item no.: 216-143
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 8/12
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
www.wago.com/216-244
19.11.2021 Page 9/12
Item no.: 216-244
crimped; acc. to DIN 46228, Part 4/09.90; black
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 231-2110/026-000
URL
Download
URL
Download
ZUKEN Portal 231-2110/026-000
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 231-2110/026-000
CAE data
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 10/12
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 231-2110/026-000
URL
Download
2-conductor female connector; Push-in CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm;
Installation Notes
Conductor termination
Operating Push-in CAGE CLAMP® is easy,
fast and identical to that of CAGE CLAMP®.
The screwdriver is fully inserted into the
operating slot, holding Push-in CAGE
CLAMP® open. After the conductor has been
inserted into the clamping unit and the
screwdriver been withdrawn, the conductor
is clamped safely. Solid and fine-stranded
conductors < 0.5 mm² (20 AWG) are
terminated and removed using a screwdriver.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 11/12
Solid conductors ≥ 0.5 mm² (20 AWG), as
well as ferruled, fine-stranded conductors
can be terminated by simply pushing them
into unit. Integrated test ports allow touch
contact with current bar via test probes in
both horizontal and vertical directions.
Product family
MCS MIDI Classic
Show all products from the family
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 12/12
很抱歉,暂时无法提供与“231-2110/026-000”相匹配的价格&库存,您可以联系我们找货
