231-654/019-000
231-654/019-000
    WAGO(万可电子)
    P=5.08mm
    接线端子 间距:5.08mm 自由悬挂(直插式)
231-654/019-000 数据手册
Data sheet | Item number: 231-654/019-000 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5.08 mm; 24-pole; clamping collar; 2,50 mm²; orange www.wago.com/231-654/019-000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Dimensions in mm L = (pole no. – 1) x pin spacing + 8.2 mm L3 = L – 0.2 mm L4 = L3 + 5.8 mm L5 = L3 + 11.8 mm Item description Universal connection for all conductor types Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation For wire-to-wire and board-to-wire connections Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 For wire-to-wire and board-to-wire connections Versions available with snap-in mounting feet or flanges for panel or through-panel mounting With coding fingers Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole numbers Gold-plated or partially gold-plated contact surfaces Electrical data Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Rated voltage UL 1977 600 V Rated current UL 1977 15 A Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Connection data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Connection data Total number of connection points 24 Total number of potentials 24 Number of connection types 1 Number of levels 1 Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 1.5 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 2.5 mm² Strip length 8 … 9 mm / 0.31 … 0.35 inch Pole No. 24 Conductor entry direction to mating direction 0  ° Physical data Pin spacing 5.08 mm / 0.2 inch Width 136.72 mm / 5.383 inch Height 14.3 mm / 0.563 inch Depth 27.5 mm / 1.083 inch Mechanical data Mounting type Mounting flange Mounting type Feed-through mounting Panel mounting Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for conductor Mismating protection No Locking of plug-in connection Without Material data Color orange Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.621 MJ Weight 37.8 g Environmental requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 10 Stück Packaging type box Country of origin DE GTIN 4044918261357 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 CSA DEKRA Certification B.V. C22.2 1466354 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Approval Additional Approval Text ABS American Bureau of Shipping - Ship Approvals Logo Certificate name 19HG1869876PDA Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 BV Bureau Veritas S.A. IEC 60998 11915/D0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 UR Underwriters Laboratories Inc. UL 1059 E45172 Counterpart Item no.231-324/026-000 www.wago.com/231-324/0261-conductor female connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5.08 mm; 24-pole; 2,50 mm²; 000 orange Item no.232-284 THT female header; angled; Pin spacing 5.08 mm; 24-pole; 0.6 x 1.0 mm solder pin; orange www.wago.com/232-284 Item no.232-184 THT female header; straight; Pin spacing 5.08 mm; 24-pole; 0.6 x 1.0 mm solder pin; orange www.wago.com/232-184 Optional accessories Ferrule     Ferrule Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-106 Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored www.wago.com/216-106 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-102 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92; silver-colored www.wago.com/216-144 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-223 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Marking accessories     Marking strip Item no.: 210-331/508-103 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-331 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Item no.: 210-331/508-103 Marking strips; as a DIN A4 sheet; MARKED; 1-12 (200x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /508-103 Item no.: 210-331/508-104 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 13-24 (200x); Height of marker strip: 2.3 mm/0.091 in; Strip /508-104 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-332/508-202 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182 /508-202 mm; Horizontal marking; Self-adhesive; white Item no.: 210-332/508-204 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /508-204 Item no.: 210-332/508-206 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /508-206 Item no.: 210-332/508-205 Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /508-205 Mounting     Mounting accessories Item no.: 209-147 Self-tapping screw www.wago.com/209-147 Item no.: 231-194 Self-tapping screw; B 2.2x13, fixing hole 1.8 mm Ø www.wago.com/231-194 Item no.: 231-195 Screw with nut; M2x12; for fixing element www.wago.com/231-195 Item no.: 231-295 Screw with nut www.wago.com/231-295 Item no.: 231-905 Jumper; for conductor entry; 5-way; insulated; gray www.wago.com/231-905 Item no.: 231-903 Jumper; for conductor entry; 3-way; insulated; gray www.wago.com/231-903 Item no.: 231-907 Jumper; for conductor entry; 7-way; insulated; gray www.wago.com/231-907 Item no.: 231-910 Jumper; for conductor entry; 10-way; insulated; gray www.wago.com/231-910 Jumpers     Jumper Item no.: 231-902 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Item no.: 231-902 Jumper; for conductor entry; 2-way; insulated; gray www.wago.com/231-902 Tool     Operating tool Item no.: 209-130 Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material; white www.wago.com/209-130 Item no.: 209-132 Operating tool; for connecting comb-style jumper bar; 2-way; of insulating material www.wago.com/209-132 Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured www.wago.com/210-657 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Item no.: 231-131 Operating tool; made of insulating material; 1-way; loose; white www.wago.com/231-131 Item no.: 231-291 Operating tool; made of insulating material; 1-way; loose; red www.wago.com/231-291 Item no.: 280-432 Operating tool; made of insulating material; 2-way; white www.wago.com/280-432 Item no.: 280-434 Operating tool; made of insulating material; 4-way www.wago.com/280-434 Item no.: 280-437 Operating tool; made of insulating material; 7-way www.wago.com/280-437 Item no.: 280-440 Operating tool; made of insulating material; 10-way www.wago.com/280-440 Item no.: 280-435 Operating tool; made of insulating material; 5-way; gray www.wago.com/280-435 Item no.: 280-436 Operating tool; made of insulating material; 6-way www.wago.com/280-436 Item no.: 280-438 Operating tool; made of insulating material; 8-way www.wago.com/280-438 Item no.: 280-433 Operating tool; made of insulating material; 3-way www.wago.com/280-433 Insulation stop     Insulation stop Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 10/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Item no.: 231-672 Insulation stop; 0.75 - 1 mm²; dark gray www.wago.com/231-672 Item no.: 231-670 Insulation stop; 0.08-0.2 mm² / 0.2 mm² “s”; white www.wago.com/231-670 Item no.: 231-671 Insulation stop; 0.25 - 0.5 mm²; light gray www.wago.com/231-671 Item no.: 231-669 Lockout caps; for covering unused clamping units; orange www.wago.com/231-669 Item no.: 231-129 Coding key; snap-on type; light gray www.wago.com/231-129 Cover     Cover Coding     Coding Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download EPLAN Data Portal 231-654/019-000 URL Download ZUKEN Portal 231-654/019-000 URL Download EPLAN Data Portal 231-654/019-000 URL Download URL Download CAD/CAE-Data CAE data CAD data 2D/3D Models 231-654/019-000 Environmental Product Compliance Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 11/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 231-654/019-000 URL Download 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5.08 mm; 24-pole; clamping collar; 2,50 mm²; orange Installation Notes Inserting a conductor via 3.5 mm screwdriver – CAGE CLAMP® actuation parallel to conductor entry. Inserting a conductor via 3.5 mm screwdriver – CAGE CLAMP® actuation perpendicular to conductor entry. Inserting a conductor into CAGE CLAMP® unit via operating lever (231-291). Inserting a conductor via operating tool. Coding Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 12/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Coding a male header – fitting coding key(s). Testing – female connector with CAGE CLAMP® Integrated test ports for testing perpendicular to conductor entry via 2 or 2.3 mm Ø test plug Installation Male connector with strain relief plate Strain relief housing shown with a male connector equipped with CAGE CLAMP® Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 13/14 Data sheet | Item number: 231-654/019-000 www.wago.com/231-654/019-000 Marking Labeling via direct marking or self-adhesive strips. Product family MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 14/14
231-654/019-000 价格&库存
很抱歉,暂时无法提供与“231-654/019-000”相匹配的价格&库存,您可以联系我们找货
