Data sheet | Item number: 232-135/005-000
Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight;
Pin spacing 5 mm; 5-pole; gray
www.wago.com/232-135/005-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/7
Dimensions in mm
L = (pole no. x pin spacing) + 1.5 mm
2- to 3-pole female connectors – one latch only
Item description
Pluggable connectors for rail-mount terminal blocks equipped with CAGE CLAMP® connection
Female connectors with long contact pins connect to the termination ports of 280 Series Rail-Mount Terminal Blocks
Female connectors are touch-proof when unmated, providing a pluggable, live output
With coding fingers
Data
Hansastr. 27
32423 Minden
07.10.2021 Page 2/7
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Electrical data
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
12 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL 1977
600 V
Rated current UL 1977
15 A
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Connection data
Total number of potentials
5
Number of connection types
1
Number of levels
1
Pole No.
5
Hansastr. 27
32423 Minden
07.10.2021 Page 3/7
Pole No.
5
Physical data
Pin spacing
5 mm / 0.197 inch
Width
26.5 mm / 1.043 inch
Height
32.75 mm / 1.289 inch
Height from the surface
18.25 mm / 0.719 inch
Depth
11.6 mm / 0.457 inch
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for front-entry rail-mount terminal block
Mismating protection
No
Locking of plug-in connection
Without
Mating direction to the rail-mount terminal block
90 °
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.095 MJ
Weight
5.3 g
Environmental requirements
Limit temperature range
-60 … +85 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
100 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918569576
Customs tariff number
85366990990
Hansastr. 27
32423 Minden
07.10.2021 Page 4/7
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2
1466354
KEMA/KEUR
EN 61984
2190761.01
Approval
BV
Bureau Veritas S.A.
IEC 60998
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1977
E45171
UL
UL 1059
E45172
Ship Approvals
Logo
Certificate
name
11915/D0
BV
UL-Approvals
Logo
Counterpart
Item no.231-605
1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 5-pole; 2,50 mm²; gray
www.wago.com/231-605
Optional
accessories
Hansastr. 27
32423 Minden
07.10.2021 Page 5/7
Optional accessories
Testing and measuring
Testing accessories
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray
www.wago.com/231-661
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 232-135/005-000
URL
Download
ZUKEN Portal 232-135/005-000
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 232-135/005-000
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 232-135/005-000
Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin
Installation Notes
Hansastr. 27
32423 Minden
07.10.2021 Page 6/7
Product family
MCS MIDI Classic
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 7/7
很抱歉,暂时无法提供与“232-135/005-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+99.937301+12.95378
