232-146/005-000/039-000
    WAGO(万可电子)
    插件
    接线端子 插件
232-146/005-000/039-000 数据手册
Data sheet | Item number: 232-146/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing 5 mm; 16-pole; gray www.wago.com/232-146/005-000/039-000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 19.11.2021    Page 1/6 Data sheet | Item number: 232-146/005-000/039-000 www.wago.com/232-146/005-000/039-000 Dimensions in mm L = pole no. x pin spacing 2- to 3-pole female connectors – one latch only Item description Pluggable connectors for rail-mount terminal blocks equipped with CAGE CLAMP® connection Female connectors with long contact pins connect to the termination ports of 280 Series Rail-Mount Terminal Blocks Female connectors are touch-proof when unmated, providing a pluggable, live output With coding fingers Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Variants: Other pole numbers Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Ratings per IEC/EN Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 19.11.2021    Page 2/6 Data sheet | Item number: 232-146/005-000/039-000 www.wago.com/232-146/005-000/039-000 Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per UL Rated voltage UL 1977 600 V Rated current UL 1977 15 A Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Total number of potentials 16 Number of connection types 1 Number of levels 1 Connection 1 Pole No. 16 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 19.11.2021    Page 3/6 Data sheet | Item number: 232-146/005-000/039-000 www.wago.com/232-146/005-000/039-000 Pole No. 16 Physical data Pin spacing 5 mm / 0.197 inch Width 95.8 mm / 3.772 inch Height 36.1 mm / 1.421 inch Height from the surface 21.6 mm / 0.85 inch Depth 11.6 mm / 0.457 inch Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for front-entry rail-mount terminal block Mismating protection No Locking of plug-in connection locking lever Mating direction to the rail-mount terminal block 90 ° Material data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating tin-plated Fire load 0.322 MJ Weight 17.7 g Environmental requirements Limit temperature range -60 … +85 °C Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 10 Stück Packaging type box Country of origin DE GTIN 4044918570954 Customs tariff number 85366990990 Approvals / Certificates Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 19.11.2021    Page 4/6 Data sheet | Item number: 232-146/005-000/039-000 www.wago.com/232-146/005-000/039-000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 1466354 Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Counterpart Item no.231-616 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 16-pole; 2,50 mm²; gray www.wago.com/231-616 Optional accessories Testing and measuring     Testing accessories Item no.: 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray www.wago.com/231-661 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download CAD/CAE-Data CAE data EPLAN Data Portal 232-146/005-000/039-000 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 19.11.2021    Page 5/6 Data sheet | Item number: 232-146/005-000/039-000 www.wago.com/232-146/005-000/039-000 EPLAN Data Portal 232-146/005-000/039-000 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 232-146/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing 5 mm; 16-pole; gray Installation Notes Product family MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 19.11.2021    Page 6/6
232-146/005-000/039-000 价格&库存
很抱歉,暂时无法提供与“232-146/005-000/039-000”相匹配的价格&库存,您可以联系我们找货
