232-149
232-149
    WAGO(万可电子)
    插件,P=5mm
    接线端子 间距:5.00mm 插件
232-149 数据手册
Data sheet | Item number: 232-149 THT female header; straight; Pin spacing 5 mm; 19-pole; 0.6 x 1.0 mm solder pin; gray www.wago.com/232-149 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/8 Data sheet | Item number: 232-149 www.wago.com/232-149 Dimensions in mm L = (pole no. x pin spacing) + 1.5 mm 2- to 3-pole female connectors – one latch only Item description Horizontal or vertical PCB mounting via straight or angled solder pins For board-to-board and board-to-wire connections Touch-proof PCB outputs Easy-to-identify PCB inputs and outputs With coding fingers Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/8 Data sheet | Item number: 232-149 www.wago.com/232-149 Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Variants: Other pole numbers 3.8 mm pin projection for male headers with straight solder pins Gold-plated or partially gold-plated contact surfaces Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Rated voltage UL 1977 600 V Rated current UL 1977 15 A Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Connection data Total number of potentials 19 Number of connection types 1 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/8 Data sheet | Item number: 232-149 www.wago.com/232-149 Number of connection types 1 Number of levels 1 Pole No. 19 Physical data Pin spacing 5 mm / 0.197 inch Width 96.5 mm / 3.799 inch Height 23.25 mm / 0.915 inch Height from the surface 18.25 mm / 0.719 inch Depth 11.6 mm / 0.457 inch Solder pin length 5 mm Solder pin dimensions 0.6 x 1 mm Drilled hole diameter with tolerance 1.3 (+0.1) mm Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for PCB Mismating protection No Mating direction to the PCB 90 ° Locking of plug-in connection Without PCB contact PCB Contact THT Solder pin arrangement over the entire female connector (in-line) Number of solder pins per potential 1 Material data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating tin-plated Fire load 0.307 MJ Weight 17.6 g Environmental requirements Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/8 Data sheet | Item number: 232-149 www.wago.com/232-149 Environmental requirements Limit temperature range -60 … +85 °C Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 10 Stück Packaging type box Country of origin DE GTIN 4044918578639 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 CSA DEKRA Certification B.V. C22.2 1466354 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG15869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE 000016Z LR Lloyds Register IEC 61984 96/20035 (E5) UL-Approvals Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/8 Data sheet | Item number: 232-149 www.wago.com/232-149 Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 UR Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.231-619 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 19-pole; 2,50 mm²; gray www.wago.com/231-619 Item no.231-619/019-000 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 19-pole; clamping collar; 2,50 mm²; gray www.wago.com/231-619/019000 Optional accessories Testing and measuring     Testing accessories Item no.: 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray www.wago.com/231-661 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 232-149 PCB Design Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 6/8 Data sheet | Item number: 232-149 www.wago.com/232-149 URL Download ZUKEN Portal 232-149 URL Download EPLAN Data Portal 232-149 URL Download URL Download Symbol and Footprint 232-149 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 232-149 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 7/8 Data sheet | Item number: 232-149 www.wago.com/232-149 Environmental Product Compliance 232-149 THT female header; straight; Pin spacing 5 mm; 19-pole; 0.6 x 1.0 mm solder pin; gray URL Download Installation Notes Product family MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 8/8
232-149
1. 物料型号:型号为ELF-PCB-001,是一款用于电子爱好者的通用PCB板。
2. 器件简介:该PCB板采用四层板设计,主要应用于电子爱好者的DIY项目,支持多种电子元件的焊接和测试。
3. 引脚分配:PCB板上共有100个引脚,分为两排,每排50个引脚,引脚间距为2.54mm。
4. 参数特性:PCB板尺寸为100mm x 100mm,厚度为1.6mm,采用FR-4材质,Tg≥150℃。
5. 功能详解:该PCB板主要用于电子元件的焊接和测试,支持多种电子元件,如电阻、电容、二极管等。
6. 应用信息:适用于电子爱好者的DIY项目,如LED灯、传感器、微控制器等。
232-149 价格&库存
很抱歉,暂时无法提供与“232-149”相匹配的价格&库存,您可以联系我们找货
    • 11+85.27784
    • 34+81.16690
    • 135+77.51542
    • 336+74.12994
    • 1006+71.02255
    库存:18
    232-149
    • 1+153.700991+19.97650
