232-162/031-000
232-162/031-000
    WAGO(万可电子)
    插件
    接线端子 插件
232-162/031-000 数据手册
Data sheet | Item number: 232-162/031-000 THT female header; straight; Pin spacing 5.08 mm; 2-pole; clamping collar; 0.6 x 1.0 mm solder pin; orange www.wago.com/232-162/031-000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/8 Data sheet | Item number: 232-162/031-000 www.wago.com/232-162/031-000 Dimensions in mm L = pole no. x pin spacing L1 = L + 3 mm L2 = L + 8.8 mm L3 = L + 14.8 mm 2- to 3-pole female connectors – one latch only Item description Horizontal or vertical PCB mounting via straight or angled solder pins For board-to-board and board-to-wire connections Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/8 Data sheet | Item number: 232-162/031-000 www.wago.com/232-162/031-000 For board-to-board and board-to-wire connections Touch-proof PCB outputs Easy-to-identify PCB inputs and outputs With coding fingers Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole numbers 3.8 mm pin projection for male headers with straight solder pins Gold-plated or partially gold-plated contact surfaces Electrical data Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Rated voltage UL 1977 600 V Rated current UL 1977 15 A Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/8 Data sheet | Item number: 232-162/031-000 www.wago.com/232-162/031-000 Rated current UL (Use Group D) 10 A Connection data Total number of connection points 2 Total number of potentials 2 Number of connection types 1 Number of levels 1 Pole No. 2 Physical data Pin spacing 5.08 mm / 0.2 inch Width 24.96 mm / 0.983 inch Height 23.25 mm / 0.915 inch Height from the surface 18.25 mm / 0.719 inch Depth 11.6 mm / 0.457 inch Solder pin length 5 mm Solder pin dimensions 0.6 x 1 mm Drilled hole diameter with tolerance 1.3 (+0.1) mm Mechanical data Mounting type Mounting flange Mounting type Feed-through mounting Panel mounting Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for PCB Mismating protection No Mating direction to the PCB 90 ° Locking of plug-in connection Without PCB contact PCB Contact THT Solder pin arrangement over the entire female connector (in-line) Number of solder pins per potential 1 Material data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/8 Data sheet | Item number: 232-162/031-000 www.wago.com/232-162/031-000 Material data Color orange Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating tin-plated Fire load 0.05 MJ Weight 2.4 g Environmental requirements Limit temperature range -60 … +85 °C Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 100 Stück Packaging type box Country of origin DE GTIN 4044918623711 Customs tariff number 85366990990 Approvals / Certificates Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG15869876PDA BV Bureau Veritas S.A. IEC 60998 11915/D0 BV UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/8 Data sheet | Item number: 232-162/031-000 www.wago.com/232-162/031-000 UR Underwriters Laboratories Inc. UL 1059 E45172 Counterpart Item no.231-632 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5.08 mm; 2-pole; 2,50 mm²; orange www.wago.com/231-632 Optional accessories Testing and measuring     Testing accessories Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray www.wago.com/231-661 Mounting     Mounting accessories Item no.: 231-194 Self-tapping screw; B 2.2x13, fixing hole 1.8 mm Ø www.wago.com/231-194 Item no.: 231-195 Screw with nut; M2x12; for fixing element www.wago.com/231-195 Item no.: 231-295 Screw with nut www.wago.com/231-295 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download CAD/CAE-Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/8 Data sheet | Item number: 232-162/031-000 www.wago.com/232-162/031-000 CAD/CAE-Data CAD data 2D/3D Models 232-162/031-000 URL Download EPLAN Data Portal 232-162/031-000 URL Download EPLAN Data Portal 232-162/031-000 URL Download ZUKEN Portal 232-162/031-000 URL Download URL Download CAE data PCB Design Symbol and Footprint 232-162/031-000 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/8 Data sheet | Item number: 232-162/031-000 www.wago.com/232-162/031-000 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Environmental Product Compliance Compliance Search Environmental Product Compliance 232-162/031-000 URL Download THT female header; straight; Pin spacing 5.08 mm; 2-pole; clamping collar; 0.6 x 1.0 mm solder pin; orange Installation Notes Application The innovative flange design provides standard panel mounting options or various through-panel mounting configurations. Depending on the type of application and flange, female headers can be used either for through-panel or flush mounted applications. Product family MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/8
232-162/031-000 价格&库存
很抱歉,暂时无法提供与“232-162/031-000”相匹配的价格&库存,您可以联系我们找货
