233-212
233-212
    WAGO(万可电子)
    插件,P=2.5mm
    接线端子 间距:2.50mm 每排针脚数:12 排数:单排
233-212 数据手册
Data sheet | Item number: 233-212 PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.5 mm; 12-pole; CAGE CLAMP®; 0,50 mm²; gray www.wago.com/233-212 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/9 Data sheet | Item number: 233-212 www.wago.com/233-212 Dimensions in mm L = (pole no. x pin spacing) + 2.3 mm Item description Compact PCB terminal strips with CAGE CLAMP® connection and screwdriver actuation parallel or perpendicular to conductor entry Double solder pins for high mechanical Custom color combinations Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/9 Data sheet | Item number: 233-212 www.wago.com/233-212 Data Notes Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole numbers Other colors Mixed-color PCB connector strips Direct marking Electrical data Approvals per CSA Rated voltage CSA (Use Group B) 150 V Rated current CSA (Use Group B) 4  A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 63 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 6  A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 150 V Rated current UL (Use Group B) 4  A Connection data Total number of connection points 12 Total number of potentials 12 Number of connection types 1 Number of levels 1 Connection technology CAGE CLAMP® Actuation type Push-button Solid conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor; with insulated ferrule 0.25 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 mm² Note (conductor cross-section) Terminating 0.75 mm²/18 AWG conductors is possible; however insulation diameter allows only every other clamping unit to be Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/9 Data sheet | Item number: 233-212 www.wago.com/233-212 insulation diameter allows only every other clamping unit to be terminated with this conductor size. Strip length 5 … 6 mm / 0.2 … 0.24 inch Conductor connection direction to PCB 30 ° Pole No. 12 Physical data Pin spacing 2.5 mm / 0.098 inch Width 32.3 mm / 1.272 inch Height 19.5 mm / 0.768 inch Height from the surface 15.5 mm / 0.61 inch Depth 13.9 mm / 0.547 inch Solder pin length 4 mm Solder pin dimensions 0.5 x 0.75 mm Drilled hole diameter with tolerance 1.1 (+0.1) mm PCB contact PCB Contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 2 Material data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.076 MJ Weight 4.8 g Environmental requirements Limit temperature range -60 … +105 °C Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/9 Data sheet | Item number: 233-212 www.wago.com/233-212 Commercial data Product Group 4 (Printed Circuit) PU (SPU) 140 (35) Stück Packaging type box Country of origin CH GTIN 4045454049546 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60998 NTR NL 6946 CCA DEKRA Certification B.V. EN 60998 2153951.01 CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL 7786 CSA DEKRA Certification B.V. C22.2 1465035 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71-111040 Approval Additional Approval Text ABS American Bureau of Shipping - Ship Approvals Logo BV IEC 60998 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate name 19HG1869876PDA 11915/D0 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/9 Data sheet | Item number: 233-212 www.wago.com/233-212 BV Bureau Veritas S.A. IEC 60998 11915/D0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1059 E45172 Optional accessories Marking accessories     Marking strip Item no.: 210-331/250-207 Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /250-207 Item no.: 210-331/250-202 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /250-202 Item no.: 210-331/254-204 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /254-204 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/250-204 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /250-204 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/254-206 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /254-206 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/250-206 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /250-206 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/254-202 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /254-202 Item no.: 210-331/254-207 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/9 Data sheet | Item number: 233-212 www.wago.com/233-212 Item no.: 210-331/254-207 Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /254-207 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Ferrule     Ferrule Tool     Operating tool Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download EPLAN Data Portal 233-212 URL Download ZUKEN Portal 233-212 URL Download URL Download CAD/CAE-Data CAE data PCB Design Symbol and Footprint 233-212 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/9 Data sheet | Item number: 233-212 www.wago.com/233-212 Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAD data 2D/3D Models 233-212 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 233-212 PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.5 mm; 12-pole; CAGE CLAMP®; 0,50 mm²; gray Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/9 Data sheet | Item number: 233-212 www.wago.com/233-212 Installation Notes Conductor termination Inserting/removing a conductor. Nominal cross-section: 0.5 mm² (20 AWG), 0.75 mm² (18 AWG) only in every other position Marking Labeling via self-adhesive marking strips or factory direct marking. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/9
233-212 价格&库存
很抱歉,暂时无法提供与“233-212”相匹配的价格&库存,您可以联系我们找货
  • 1+43.23240
  • 10+36.40680
  • 30+32.34600
库存:10
233-212
  • 1+69.87685
  • 5+67.09636
  • 10+64.28462
库存:27
233-212
  • 2+55.008722+7.13018
  • 35+54.4574635+7.05873
库存:10
233-212
  • 1+53.930531+6.99043
  • 35+53.3897735+6.92033
库存:11
