Data sheet | Item number: 235-106/330-000
PCB terminal block; 1.5 mm²; Pin spacing 3.81 mm; 6-pole; PUSH WIRE®;
1,50 mm²; orange
www.wago.com/235-106/330-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/10
Dimensions in mm
L = (pole no. x pin spacing) + 1.5 mm
Item description
Low-profile terminal strips with screwdriver-actuated PUSH WIRE® termination
Push-in termination of solid conductors
Double solder pins for high mechanical stability
Conductor removal via screwdriver (2.5 mm blade width)
Hansastr. 27
32423 Minden
07.10.2021 Page 2/10
Data
Notes
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Other colors
Mixed-color PCB connector strips
Direct marking
Electrical data
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
200 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
500 V
Rated surge voltage (II/2)
4 kV
Rated current
17.5 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Connection data
Total number of connection points
6
Total number of potentials
6
Number of connection types
1
Number of levels
1
Connection technology
PUSH WIRE®
Actuation type
Operating tool
Solid conductor
0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor; with insulated ferrule
0.25 … 0.75 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 0.75 mm²
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Conductor connection direction to PCB
0 °
Hansastr. 27
32423 Minden
07.10.2021 Page 3/10
0 °
Pole No.
6
Physical data
Pin spacing
3.81 mm / 0.15 inch
Width
24.36 mm / 0.959 inch
Height
12.8 mm / 0.504 inch
Height from the surface
9.2 mm / 0.362 inch
Depth
12.5 mm / 0.492 inch
Solder pin length
3.6 mm
Solder pin dimensions
0.8 x 0.4 mm
Drilled hole diameter with tolerance
1 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Color
orange
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.052 MJ
Weight
3.3 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
180 (45) Stück
Packaging type
box
Hansastr. 27
32423 Minden
07.10.2021 Page 4/10
Packaging type
box
Country of origin
CN
GTIN
4044918828642
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7144
CCA
EN 60947
2149549.02
CCA
EN 60998
NTR NL
6919
CCA
EN 60947-7-4
NTR NL7774
VDE
VDE Prüf- und Zertifizierungsinstitut
EN 60947
40029328
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
Hansastr. 27
32423 Minden
07.10.2021 Page 5/10
Optional accessories
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
Hansastr. 27
32423 Minden
www.wago.com/216-221
07.10.2021 Page 6/10
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Marking accessories
Marking strip
Item no.: 210-332/381-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/381-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/381-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/381-206
Item no.: 210-332/381-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/381-205
Item no.: 210-332/381-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
/381-204
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
Hansastr. 27
32423 Minden
07.10.2021 Page 7/10
CAD/CAE-Data
CAD data
2D/3D Models 235-106/330-000
URL
Download
EPLAN Data Portal 235-106/330-000
URL
Download
URL
Download
ZUKEN Portal 235-106/330-000
URL
Download
URL
Download
CAE data
PCB Design
Symbol and Footprint 235-106/330-000
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Hansastr. 27
32423 Minden
07.10.2021 Page 8/10
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 235-106/330-000
URL
Download
PCB terminal block; 1.5 mm²; Pin spacing 3.81 mm; 6-pole; PUSH WIRE®; 1,50 mm²;
orange
Installation Notes
Inserting a solid conductor via push-in
termination.
Conductor removal
Removing a conductor via screwdriver (2.5
mm blade width).
Conductor termination
Hansastr. 27
32423 Minden
07.10.2021 Page 9/10
termination.
Conductor removal
mm blade width).
Hansastr. 27
32423 Minden
07.10.2021 Page 10/10
很抱歉,暂时无法提供与“235-106/330-000”相匹配的价格&库存,您可以联系我们找货
