Data sheet | Item number: 235-851/333-000
Stackable 2-conductor PCB terminal block; 0.75 mm²; Pin spacing 10/10.16
mm; 1-pole; PUSH WIRE®; with test port; 0,75 mm²; gray
www.wago.com/235-851/333-000
i
Picture differs from the item.
Color:
Item description
Modular PCB terminal blocks with push-buttons and PUSH WIRE® connection for custom terminal strip assemblies
Double-wire connection for commoning signals
Push-in termination of solid conductors
Easy conductor removal via push-button
Set to metric or inch pin spacing by compressing PCB terminal strips or pulling them apart
Also available with a test slot
Data
Notes
Variants:
Other colors
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/6
300 V
Rated current CSA (Use Group B)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
630 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
500 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Connection data
Total number of connection points
2
Total number of potentials
1
Number of connection types
1
Number of levels
1
Connection technology
PUSH WIRE®
Actuation type
Push-button
Solid conductor
0.2 … 0.75 mm² / 24 … 18 AWG
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Conductor connection direction to PCB
0 °
Pole No.
1
Physical data
Pin spacing
10/10.16 mm / 0.394/0.4 inch
Width
11.5 mm / 0.453 inch
Height
19.1 mm / 0.752 inch
Height from the surface
15.5 mm / 0.61 inch
Depth
12.5 mm / 0.492 inch
Solder pin length
3.6 mm
Solder pin dimensions
0.8 x 0.4 mm
Drilled hole diameter with tolerance
Hansastr. 27
32423 Minden
13.10.2021 Page 2/6
1 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
within the terminal block (in-line)
Number of solder pins per potential
2
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.019 MJ
Weight
1 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
400 (100) Stück
Packaging type
box
Country of origin
CN
GTIN
4044918833783
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CSA
DEKRA Certification B.V.
C22.2
1673956
Hansastr. 27
32423 Minden
13.10.2021 Page 3/6
UL-Approvals
Logo
Approval
Certificate
name
UL
UL International Germany GmbH
E45172
Required accessories
End plate
End plate
Item no.: 235-100
End plate; snap-fit type; 1 mm thick; gray
www.wago.com/235-100
Optional accessories
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-221
Hansastr. 27
32423 Minden
13.10.2021 Page 4/6
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
EPLAN Data Portal 235-851/333-000
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAE data
PCB Design
Symbol and Footprint 235-851/333-000
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Hansastr. 27
32423 Minden
13.10.2021 Page 5/6
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 235-851/333-000
URL
Download
Stackable 2-conductor PCB terminal block; 0.75 mm²; Pin spacing 10/10.16 mm; 1pole; PUSH WIRE®; with test port; 0,75 mm²; gray
Installation Notes
Hansastr. 27
32423 Minden
13.10.2021 Page 6/6
很抱歉,暂时无法提供与“235-851/333-000”相匹配的价格&库存,您可以联系我们找货
