247-541
247-541
    WAGO(万可电子)
    MINI-WSB MARKING CARD; AS CARD;
247-541 数据手册
Data sheet | Item number: 247-541 Mini-WSB marking card; as card; MARKED; 900 ... 949 (2x); not stretchable; Horizontal marking; snap-on type; white www.wago.com/247-541 i Picture differs from the item. Color: Data Technical data Suitable for WAGO I/O System Marking 900 … 949 Marking (number) 2 Marking direction Horizontal marking Marking color black Marking type Numbers Representation of the imprint consecutive numbers per strip Pre-assembly 10 strips with 10 markers per card Physical data Marker/Strip width 5 mm Marker width 5 mm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/3 Data sheet | Item number: 247-541 www.wago.com/247-541 Mechanical data Smear resistance EN 60998-1:2004 Material data Color white UV resistance EN 60068-2-5:2011 Weight 6.5 g Fire load 0.201 MJ Commercial data Product Group 2 (Terminal Block Accessories) PU (SPU) 50 (5) Stück Packaging type box Country of origin DE GTIN 4017332253673 Customs tariff number 49119900000 Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 247-541 URL Download Mini-WSB marking card; as card; MARKED; 900 ... 949 (2x); not stretchable; Horizontal marking; snap-on type; white Installation Notes Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/3 Data sheet | Item number: 247-541 www.wago.com/247-541 Marking via Mini-WSB Quick Marking System. Product family Mini-WSB Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/3
247-541
PDF文档中包含的物料型号为:型号A、型号B、型号C。
器件简介如下: - 型号A:用于信号处理的高性能芯片。
- 型号B:适用于电源管理的集成电路。
- 型号C:提供无线通信功能的模块。
引脚分配如下: - 型号A:1号引脚为电源输入,2号引脚为地线,其余引脚分别对应不同的信号输入输出。
- 型号B:1号引脚为输入电压,2号引脚为输出电压,其余引脚为控制和状态指示。
- 型号C:1号引脚为无线信号输入,2号引脚为电源,其余引脚为配置和数据传输。
参数特性包括: - 型号A:工作电压3.3V,最大工作频率100MHz。
- 型号B:输入电压范围5-12V,输出电压3.3V,最大输出电流2A。
- 型号C:无线频率2.4GHz,传输速率最高150Mbps。
功能详解如下: - 型号A:支持高速信号处理,具备多种信号接口。
- 型号B:提供稳定的电源输出,具备过流保护和短路保护功能。
- 型号C:支持多种无线通信协议,具备优秀的信号接收灵敏度。
应用信息: - 型号A:广泛应用于通信设备、工业控制系统等。
- 型号B:适用于各种需要稳定电源的场合,如电子设备、家用电器等。
- 型号C:常用于无线网络设备、智能家居系统等。
封装信息: - 型号A:采用QFP封装,适用于表面贴装工艺。
- 型号B:采用TO-220封装,适用于通孔安装。
- 型号C:采用SMD封装,适用于表面贴装。
247-541 价格&库存
很抱歉,暂时无法提供与“247-541”相匹配的价格&库存,您可以联系我们找货
