Data sheet | Item number: 255-504/333-000
PCB terminal block; finger-operated levers; 2.5 mm²; Pin spacing 7.5/7.62
mm; 4-pole; CAGE CLAMP®; commoning option; 2,50 mm²; gray
www.wago.com/255-504/333-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
02.12.2021 Page 1/11
Dimensions in mm
L = (pole no. x pin spacing) + 2.9 mm
Item description
PCB terminal blocks with push-buttons and CAGE CLAMP® connection
Versions with Ex approval
Set to metric or inch pin spacing by compressing PCB terminal strips or pulling them apart
Ideal for in-the-field wiring thanks to simplified push-button actuation
Convenient, tool-free operation
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 2/11
Data
Notes
Variants:
Other pole numbers
Versions for Ex e II and Ex i
Other colors
Mixed-color PCB connector strips
Direct marking
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
24 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Ratings per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 3/11
Connection data
Total number of connection points
4
Total number of potentials
4
Number of connection types
1
Number of levels
1
Connection 1
Connection technology
CAGE CLAMP®
Actuation type
Finger-operated lever
Solid conductor
0.08 … 2.5 mm² / 25 … 12 AWG
Fine-stranded conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 1.5 mm²
Note (conductor cross-section)
12 AWG: THHN, THWN
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Conductor connection direction to PCB
90 °
Pole No.
4
Physical data
Pin spacing
7.5/7.62 mm / 0.295/0.3 inch
Width
32.9 mm / 1.295 inch
Height
22.2 mm / 0.874 inch
Height from the surface
14.2 mm / 0.559 inch
Depth
23 mm / 0.906 inch
Solder pin length
4 mm
Solder pin dimensions
0.7 x 0.7 mm
Drilled hole diameter with tolerance
1.1 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Note on material data
Information on material data can be found here
Color
gray
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 4/11
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.106 MJ
Weight
6.1 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
140 (35) Stück
Packaging type
box
Country of origin
CH
GTIN
4044918661508
Customs tariff number
85369010000
Approvals / Certificates
UL-Approvals
Logo
Approval
Additional Approval Text
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
Optional accessories
Testing and measuring
Testing accessories
Item no.: 249-112
Test plug adapter; suitable for 255, 256, 257 Series PCB terminal blocks; 1-pole; Pin spacing 7.5 mm /
0.295 in; gray
www.wago.com/249-112
Item no.: 249-113
Test plug adapter; suitable for 255, 256, 257 Series PCB terminal blocks; 1-pole; Pin spacing 7.62 mm / www.wago.com/249-113
0.3 in; orange
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 5/11
0.3 in; orange
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
www.wago.com/216-151
02.12.2021 Page 6/11
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
www.wago.com/216-321
02.12.2021 Page 7/11
Item no.: 216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; light turquoise
www.wago.com/216-302
Marking accessories
Marking strip
Item no.: 210-833
Marking strips; 25 m on roll; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Item no.: 210-332/750-020
Marking strips; as a DIN A4 sheet; MARKED; 1-20 (80x); Height of marker strip: 3 mm; Strip length 182
mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-332
/750-020
Item no.: 210-332/762-020
/762-020
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 255-504/333-000
PCB Design
Symbol and Footprint 255-504/333-000
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 8/11
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 255-504/333-000
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 255-504/333-000
PCB terminal block; finger-operated levers; 2.5 mm²; Pin spacing 7.5/7.62 mm; 4pole; CAGE CLAMP®; commoning option; 2,50 mm²; gray
Installation Notes
Conductor termination
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 9/11
Inserting/removing a conductor – 256 Series.
Inserting/removing a conductor (255 Series)
Inserting/removing a conductor via fingeroperated lever – 255 Series.
Inserting/removing a conductor via fingeroperated lever – 256 Series.
Installation
Possible conductor arrangement with
terminal strips staggered (for 256 Series
only).
Marking
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 10/11
Formation of groups using housings of
different colors
Testing
Testing with test probes.
Testing with test plug modules.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 11/11
很抱歉,暂时无法提供与“255-504/333-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 35+30.0706035+3.90908
