Data sheet | Item number: 258-5000
Thermal transfer printer; Smart Printer; for complete control cabinet
marking; 300 dpi; With marking material
www.wago.com/258-5000
Data
System requirements
Memory
4 GB
Supported operating systems
Windows 7
Windows 8
Windows 10
Technical data
Marking method
Thermal transfer
Print head
Glass layer, spring-mounted
Print resolution
300 dpi
Print resolution
300 dpi (12 pixels/mm)
Print speed (max.)
max. 127 mm/s (WAGO recommends 50.8 mm/s)
Print width
47 mm
Print length (max.)
762 mm
See-through/reflective sensor
yes, centrally fixed
Memory
8 MB
Beschriftungssoftware
Smart Script
Subject to changes. Please also observe the further product documentation!
WAGO Corporation
Germantown, WI 53022
Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.us
Do you have any questions about our products?
We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL.
05.11.2021 Page 1/15
Smart Script
Interfaces
USB, RS-232, ETHERNET 10/100 Mbps
Operating voltage
100 … 240 VAC, 50 … 60 Hz (automatic adjustment)
Safety approvals
CE (EMC)
Operating display
Color TFT LCD with navigation button
Ink ribbon
Reel outside diameter: 40 mm; core inside diameter 12.7 mm (0.5
inch); max. length 110 m; max. width 58 mm
Ink ribbon (width)
50 mm / 1.969 inch
Ink ribbon (length)
74 m / 360.9
Ink ribbon roll outside diameter
33 mm / 1.299 inch
Ink ribbon core inside diameter
12.5 mm / 0.492 inch
Scope of delivery
Power supply + cable, 2 x roller (258‑5006 + 258‑5007), 1 x reel
holder, 1 x ink ribbon (258-5005), Smart Script marking software and
driver, USB cable, external unwinder, 2 empty cardboard roller
cores, 1 x roll of marking strips (2009-110) and WMB Inline markers
(2009-115)
Physical data
Height
175 mm / 6.89 inch
Width
135 mm / 5.315 inch
Depth
245 mm / 9.646 inch
Material data
Weight
3840 g
Environmental requirements
Surrounding air temperature (storage)
-20 … 50 °C
Surrounding air temperature (operation)
5 … 40 °C
Commercial data
Product Group
14 (Tools)
PU (SPU)
1 Stück
Packaging type
box
Country of origin
TW
GTIN
4050821520993
Customs tariff number
8443321050
Approvals / Certificates
WAGO Corporation
05.11.2021 Page 2/15
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
CCC
CQC
2020010904320138
UL-Approvals
Logo
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 60950-1
E482462
Optional accessories
Marking accessories
Marking strip
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 210-877
Marking strips; for Smart Printer; permanent adhesive; 46 mm; silver-colored
www.wago.com/210-877
Item no.: 210-702
Marking strips; for Smart Printer; permanent adhesive; 15 mm; white
www.wago.com/210-702
Item no.: 210-831
Marking strips; on reel; 2.3 mm wide; plain; Self-adhesive; white
www.wago.com/210-831
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Item no.: 210-834
Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white
www.wago.com/210-834
Item no.: 210-832
Marking strips; on reel; 3 mm wide; plain; Self-adhesive; white
www.wago.com/210-832
Item no.: 210-870
Marking strips; for Smart Printer; permanent adhesive; 10 mm; white
www.wago.com/210-870
Item no.: 210-873
WAGO Corporation
www.wago.com/210-873
05.11.2021 Page 3/15
Item no.: 210-873
Marking strips; for Smart Printer; permanent adhesive; 20 mm; silver-colored
Item no.: 210-874
Marking strips; for Smart Printer; permanent adhesive; 30 mm; white
www.wago.com/210-874
Item no.: 210-871
Marking strips; for Smart Printer; permanent adhesive; 10 mm; silver-colored
www.wago.com/210-871
Item no.: 210-876
Marking strips; for Smart Printer; permanent adhesive; 46 mm; white
www.wago.com/210-876
Item no.: 210-872
Marking strips; for Smart Printer; permanent adhesive; 20 mm; white
www.wago.com/210-872
Item no.: 210-875
Marking strips; for Smart Printer; permanent adhesive; 30 mm; silver-colored
www.wago.com/210-875
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Item no.: 757-901/000-050
Marking strips; on reel; not stretchable; plain; snap-on type
www.wago.com/757-901
/000-050
Item no.: 210-880
Marking strips; for Smart Printer; permanent adhesive; 12.7 mm; white
www.wago.com/210-880
Item no.: 210-882
Marking strips; for Smart Printer; permanent adhesive; 22.6 mm; white
www.wago.com/210-882
Item no.: 2009-110/020-002
Marking strips; for Smart Printer; on reel; not stretchable; plain; yellow
/020-002
Item no.: 210-803
Type labels; 99 x 44 mm; white
www.wago.com/210-803
Item no.: 210-801
Type labels; 70 x 33 mm; white
www.wago.com/210-801
Type plate
Item no.: 210-802
WAGO Corporation
www.wago.com/210-802
05.11.2021 Page 4/15
Item no.: 210-802
Type labels; 70 x 33 mm; silver-colored
Item no.: 210-804
Type labels; 99 x 44 mm; silver-colored
www.wago.com/210-804
Item no.: 210-812
Type labels; 50 x 25 mm; silver-colored
www.wago.com/210-812
Push-button label
Item no.: 210-847
Push-button marker; 22 x 22 mm; silver-colored
www.wago.com/210-847
Item no.: 210-848
Push-button marker; 27 x 27 mm; silver-colored
www.wago.com/210-848
Item no.: 210-850
Push-button marker; 26.5 x 18 mm; silver-colored
www.wago.com/210-850
Item no.: 210-856
Push-button marker; 27.5 x 17.5 mm; silver-colored
www.wago.com/210-856
Item no.: 210-852
Push-button marker; 27 x 19 mm; silver-colored
www.wago.com/210-852
Item no.: 210-854
Push-button marker; 28 x 28 mm; silver-colored
www.wago.com/210-854
Item no.: 210-858
www.wago.com/210-858
Item no.: 210-860
www.wago.com/210-860
Item no.: 210-862
Push-button marker; 27 x 12.5 mm; silver-colored
www.wago.com/210-862
Item no.: 210-855
Push-button marker; 27 x 18 mm; silver-colored
www.wago.com/210-855
WAGO Corporation
05.11.2021 Page 5/15
Item no.: 210-836
Push-button marker; for frames, to be snapped in or glued in place; 27 x 17.5 mm; silver-colored
www.wago.com/210-836
Item no.: 210-840
Push-button marker; for frames, to be snapped in or glued in place; 27 x 27 mm; silver-colored
www.wago.com/210-840
Item no.: 210-842
Push-button marker; for frames, to be snapped in or glued in place; 27 x 12.5 mm; silver-colored
www.wago.com/210-842
Wire marker for thread-on mounting
Item no.: 211-863
Conductor markers for thread-on mounting; for Smart Printer; 10 x 17 mm; white
www.wago.com/211-863
Item no.: 211-862
Conductor markers for thread-on mounting; for Smart Printer; 7 x 10.5 mm; white
www.wago.com/211-862
Item no.: 211-861
Conductor markers for thread-on mounting; for Smart Printer; 5 x 10.5 mm; white
www.wago.com/211-861
Item no.: 211-501
Shrink tube; for Smart Printer; Unshrunk diameter: 3.2 mm; white
www.wago.com/211-501
Item no.: 211-502
Shrink tube; for Smart Printer; Unshrunk diameter: 4.8 mm; white
www.wago.com/211-502
Item no.: 211-504
Shrink tube; for Smart Printer; Unshrunk diameter: 9.5 mm; white
www.wago.com/211-504
Item no.: 211-500
Shrink tube; for Smart Printer; Unshrunk diameter: 2.4 mm; white
www.wago.com/211-500
Item no.: 211-503
Shrink tube; for Smart Printer; Unshrunk diameter: 6.4 mm; white
www.wago.com/211-503
Item no.: 211-505
Shrink tube; for Smart Printer; Unshrunk diameter: 12.7 mm; white
www.wago.com/211-505
Item no.: 211-506
Shrink tube; for Smart Printer; Unshrunk diameter: 19.0 mm; white
www.wago.com/211-506
Shrink tube
Label
WAGO Corporation
05.11.2021 Page 6/15
Label
Item no.: 210-805
Labels; for Smart Printer; permanent adhesive; 6 x 15 mm; white
www.wago.com/210-805
Item no.: 210-807
Labels; for Smart Printer; permanent adhesive; 8 x 20 mm; white
www.wago.com/210-807
Item no.: 210-810
Labels; for Smart Printer; 5 x 35 mm; white
www.wago.com/210-810
Item no.: 210-813
Labels; for Smart Printer; permanent adhesive; 40 mm; white
www.wago.com/210-813
Item no.: 210-806
Labels; for Smart Printer; permanent adhesive; 9 x 15 mm; white
www.wago.com/210-806
Item no.: 210-808
Labels; for Smart Printer; 9.5 x 25 mm; white
www.wago.com/210-808
Item no.: 210-811
Textile labels; for Smart Printer; permanent adhesive; 7 x 20 mm; white
www.wago.com/210-811
Item no.: 210-814
www.wago.com/210-814
Item no.: 2009-113
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white
www.wago.com/2009-113
Marker
Item no.: 2009-145
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-114
WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; white
www.wago.com/2009-114
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-515
WMB-Inline; for Smart Printer; 900 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-515
WAGO Corporation
05.11.2021 Page 7/15
Item no.: 2009-615
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-615
Item no.: 211-821
Marker card; for Smart Printer; for use in nozzles; Length: 23 mm; white
www.wago.com/211-821
Item no.: 211-811
Marker card; for Smart Printer; for use in nozzles; Length: 12 mm; white
www.wago.com/211-811
Self-laminating label
Item no.: 211-855
Self-laminating labels; for Smart Printer; 9 x 18 mm; white
www.wago.com/211-855
Item no.: 211-856
Self-laminating labels; for Smart Printer; 15 x 22 mm; white
www.wago.com/211-856
Item no.: 211-857
Self-laminating labels; for Smart Printer; 18 x 44 mm; white
www.wago.com/211-857
Cable tie markers
Item no.: 211-835
Cable tie marker; for Smart Printer; for use with cable ties; 25 x 10 mm; white
www.wago.com/211-835
Item no.: 211-836
Cable tie marker; for Smart Printer; for use with cable ties; 100 x 15mm; white
www.wago.com/211-836
Item no.: 211-837
Cable tie marker; for Smart Printer; for use with cable ties; 44 x 10 mm; white
www.wago.com/211-837
Accessory for marking devices
Accessories for marking devices
Item no.: 258-5009
Roller; for Smart Printer; for WMB-Inline Phoenix (2009-515); 1 grinding device
www.wago.com/258-5009
Item no.: 258-5008
Roller; for Smart Printer; for Mini-WSB Inline WAGO (2009-145); 1 grinding device
www.wago.com/258-5008
WAGO Corporation
05.11.2021 Page 8/15
Item no.: 258-5010
Roller; for Smart Printer; for WMB-Inline Weidmüller (2009-615); 1 grinding device
www.wago.com/258-5010
Item no.: 258-5005
Thermal transfer ink ribbon; for Smart Printer; black
www.wago.com/258-5005
Item no.: 258-5006
Roller; for Smart Printer; for marking strips, device and equipment markers, conductor and cable
markers
www.wago.com/258-5006
Item no.: 258-5007
Roller; for Smart Printer; for WMB-Inline WAGO (2009-115, -114, -113); 1 grinding device
www.wago.com/258-5007
Item no.: 258-5014
Thermal transfer ink ribbon; for Smart Printer; for self-laminating labels; black
www.wago.com/258-5014
Item no.: 258-5015
Carrying case; white
www.wago.com/258-5015
Item no.: 258-5030
Cutter; for Smart Printer; for marking strips, equipment markers, conductor and cable markers;
Durable; High accuracy
www.wago.com/258-5030
Item no.: 258-5005/000-005
Thermal transfer ink ribbon; for Smart Printer; red
/000-005
Item no.: 258-5011
Roller; for Smart Printer; for Micro WSB Inline roller (2009-141); 1 grinding device
www.wago.com/258-5011
Downloads
Documentation
Manual
smartPRINTER operating instructions
003.10.2017
Sep 25, 2020
pdf
3.2 MB
Download
WAGO Smart Script Benutzerhandbuch
1
Mar 3, 2020
pdf
3.6 MB
Download
1
pdf
Download
Aug 28, 2020
1.1 MB
Operating Instructions
211-502 Information on printing material
WAGO Corporation
05.11.2021 Page 9/15
Aug 28, 2020
1.1 MB
211-821 Information on printing material
1
Aug 28, 2020
pdf
1.3 MB
Download
2009-145 Information on printing material
1
Aug 28, 2020
pdf
1.3 MB
Download
210-811 Handhabungshinweis zum Druckmaterial
1
Aug 28, 2020
pdf
1.4 MB
Download
210-813 Information on handling print material
1
Aug 28, 2020
pdf
1.4 MB
Download
211-856 Information on printing material
1
Aug 28, 2020
pdf
1.3 MB
Download
211-836 Information on printing material
1
Aug 28, 2020
pdf
1.5 MB
Download
210-831 Information on handling print material
1
Aug 28, 2020
pdf
1.2 MB
Download
2009-110 Information on printing material
1
Aug 28, 2020
pdf
1.2 MB
Download
211-835 Information on printing material
1
Aug 28, 2020
pdf
1.4 MB
Download
210-852 Information on handling print material
1
Aug 28, 2020
pdf
1.0 MB
Download
2009-615 Information on printing material
1
Aug 28, 2020
pdf
1.3 MB
Download
210-804 Information on handling print material
1
Aug 28, 2020
pdf
1.4 MB
Download
210-805 Information on handling print material
1
Aug 28, 2020
pdf
1.3 MB
Download
2009-515 Information on printing material
1
Aug 28, 2020
pdf
1.3 MB
Download
211-861 Information on printing material
1
Aug 28, 2020
pdf
1.3 MB
Download
1
pdf
Download
2009-115 Information on printing material
WAGO Corporation
05.11.2021 Page 10/15
1
Aug 28, 2020
pdf
1.3 MB
Download
Overview software versions
1
Feb 22, 2021
pdf
733.7 kB
Download
Allocation roller printing material
001.12.2016
Sep 10, 2020
pdf
143.3 kB
Download
Instructions external unwinder
001.12.2016
Sep 8, 2020
pdf
1.0 MB
Download
FAQ fault description and troubleshooting
002.07.2017
Apr 27, 2020
pdf
83.9 kB
Download
Cutting Unit V2
1
Apr 27, 2020
pdf
620.4 kB
Download
IT infrastructure requirements
002.09.2017
Aug 15, 2019
pdf
36.6 kB
Download
Smart Printer accessories
30.01.2017
Jun 30, 2019
pdf
873.7 kB
Download
4.8.1.1
Oct 25, 2021
zip
162.5 MB
Download
Additional Information
Software Solutions (Applications)
Smart Script 4.x Marking Software
Use the new Smart Script 4.x marking software to easily create and print custom
marking strips, markers and labels for any WAGO component.
This software version is tailored to our Smart Printer thermal transfer printer and
comes with all the drivers and settings you need with this printer.
Overview of Features:
Modern design and intuitive use
Fast and easy to use, with all applications such as printer drivers and settings
integrated.
Ideal for professional marking of terminal blocks, labels, type plates and
conductor markers
Optimized data interfaces for Smart Designer configuration software, EPLAN,
Microsoft Excel, CSV
Supported operating systems:
Windows 10, Windows 8, Windows 7 64 Bit
WAGO Corporation
05.11.2021 Page 11/15
System requirements:
3 Gigahertz (GHz) or faster, 64-bit (x64) processor
4 GB RAM, recommended 8 GB
400 MB available storage space on hard drive
Screen resolution of 1360 x 864 or higher (100 % scaling)
Smart Printer Firmware starting from Version 1.UW7v
SmartScript 3.9 Marking Software
Smart Script 3.9 Marking Software
Use the Smart Script 3.9 marking software to easily create and print marking strips,
You may need the current driver (Smart Printer Driver) and the easy-to-use “Printer
Setting Tool” to use the Smart Printer thermal transfer printer.
3.9
Jul 10, 2019
ZIP
47.2 MB
Download
3.88.23.4
Jul 10, 2019
ZIP
47.5 MB
Download
NOTE: Version 3.9.0.0 can only be used together with the Smart Printer thermal
transfer printer and resolves the font width issue for Windows 10 Version 1809.
Smart Printer Firmware starting from version 1.UW7q
Smart Script 3.8 Marking Software
Use the Smart Script 3.8 marking software to easily create and print marking strips,
NOTE: Version 3.88.23.4 supports the WAGO Plotter, WAGO Engraver and standard
A4 printers.
WAGO Corporation
05.11.2021 Page 12/15
Installation Package 3.9 Smart Printer
Installation package for the Smart Printer thermal transfer printer:
3.9
Jul 10, 2019
ZIP
69.8 MB
Download
3.8
Jul 10, 2019
ZIP
70.1 MB
Download
Smart Printer driver
Printer setting tool
Installation Package 3.8 Smart Printer
WAGO Corporation
05.11.2021 Page 13/15
A4 printers.
Device Files
additional software
WAGO-EPLAN-Interface 64Bit
1.5.2
The new interface for EPLAN Electric P8 incl. ProPanel (from version 2.5) from WAGO Aug 10, 2021
as plug-in for more efficiency in digital engineering.
zip
1.7 MB
Download
zip
3.9 MB
Download
The advantages:
Continuity along the value chain
Reuse of data without media disruption
time and cost savings
The properties of the EPLAN interface:
Automatic terminal strip layout from the circuit diagram or installation space
navigator of EPLAN in the WAGO Smart Designer
Automated terminal block labeling, plausibility check, automatic completion of
missing components and ordering options in Smart Designer
Reimport from Smart Designer to EPLAN for a complete bill of materials in the CAE
tool
Automated terminal labeling and direct printing from EPLAN
WAGO Firmware for Thermotransferdrucker Smart Printer
V1.UW7v
Jun 24, 2020
ATTENTION: Firmware 1.UW7y is currently not available. Please install the update
WAGO Corporation
05.11.2021 Page 14/15
later. Thank you for your understanding.
Version V1.UW7v is a completly functional firmware outside the use of Data Matrix
Codes.
WAGO Smart Label
2.5
Oct 25, 2017
zip
37.6 MB
Download
WAGO GoDoctor
1.005
zip
810.4 kB
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 258-5000
Thermal transfer printer; Smart Printer; for complete control cabinet marking; 300
Installation Notes
WAGO Corporation
05.11.2021 Page 15/15
