260-351
260-351
    WAGO(万可电子)
    SPACE-SAVING, 4-CONDUCTOR END TE
260-351 数据手册
Data sheet | Item number: 260-351 Space-saving, 4-conductor end terminal block; without push-buttons; without protruding snap-in mounting foot; 1-pole; for terminal strips with snap-in mounting feet; 1.5 mm²; CAGE CLAMP®; 1,50 mm²; gray www.wago.com/260-351 i Picture differs from the item. Color: Data Electrical data Nominal voltage (III/3) 400 V Rated surge voltage (III/3) 6 kV Rated current 18 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Total number of connection points 4 Total number of potentials 1 Number of levels 1 Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Solid conductor Subject to changes. Please also observe the further product documentation!0.08 … 1.5 mm² / 28 … 16 AWG WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 1/8 Data sheet | Item number: 260-351 www.wago.com/260-351 Connectable conductor materials Copper Solid conductor 0.08 … 1.5 mm² / 28 … 16 AWG Fine-stranded conductor 0.08 … 1.5 mm² / 28 … 16 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Wiring direction Side-entry wiring Physical data Width 8 mm / 0.315 inch Height from the surface 17.1 mm / 0.673 inch Depth 25.1 mm / 0.988 inch Mechanical data Design horizontal type Mounting type Snap-in foot Marking level Side marking Material data Color gray Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.038 MJ Weight 2.5 g Commercial data Product Group 9 (Std. Chassis Mt. Blocks) PU (SPU) 300 (50) Stück Packaging type box Country of origin CH GTIN 4044918604635 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60998 Certificate name NTR-NL 6508 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 2/8 Data sheet | Item number: 260-351 www.wago.com/260-351 CCA DEKRA Certification B.V. EN 60998 2110272.01 CSA DEKRA Certification B.V. C22.2 70010891 VDE VDE Prüf- und Zertifizierungsinstitut EN 60998 40033303 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869868PDA BV Bureau Veritas S.A. EN 60947 07436/F0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register IEC 60998 91/20242 (E7) UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 Required accessories Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 3/8 Data sheet | Item number: 260-351 www.wago.com/260-351 Required accessories End plate     End plate Item no.: 260-371 End plate; with snap-in mounting foot; gray www.wago.com/260-371 Optional accessories Marking accessories     Marking strip Item no.: 210-833 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white www.wago.com/210-833 Item no.: 260-402 Jumper; for conductor entry; 2-way; insulated; gray www.wago.com/260-402 Jumpers     Jumper Testing and measuring     Testing accessories Item no.: 249-138 Test plug module; without locking device; modular; for 4-conductor terminal blocks; gray www.wago.com/249-138 Item no.: 260-405 Test plug module; with locking latches; modular; for 4-conductor terminal blocks; for 260 Series; gray www.wago.com/260-405 Tool     Operating tool Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured www.wago.com/210-657 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Mounting     Mounting accessories Item no.: 209-137 Mounting adapter; can be used as end stop; 6.5 mm wide; gray www.wago.com/209-137 Ferrule     Ferrule Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-101 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 4/8 Data sheet | Item number: 260-351 www.wago.com/260-351 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-221 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 5/8 Data sheet | Item number: 260-351 www.wago.com/260-351 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Downloads Documentation Bid Text 260-351 Jun 14, 2017 doc 25.1 kB Download Feb 19, 2019 xml 3.2 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download WSCAD Universe 260-351 URL Download ZUKEN Portal 260-351 URL Download EPLAN Data Portal 260-351 URL Download doc - Datei 260-351 X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 260-351 CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 6/8 Data sheet | Item number: 260-351 www.wago.com/260-351 Environmental Product Compliance Compliance Search Environmental Product Compliance 260-351 URL Download Space-saving, 4-conductor end terminal block; without push-buttons; without protruding snap-in mounting foot; 1-pole; for terminal strips with snap-in mounting feet; 1.5 mm²; CAGE CLAMP®; 1,50 mm²; gray Installation Notes Installation Assembling modular terminal blocks into terminal strips. Mounting an end plate. Conductor termination CAGE CLAMP® connection Inserting a conductor. With ferruled conductors, it is necessary to use a terminal block one size larger than the conductor's nominal cross-section. Commoning Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 7/8 Data sheet | Item number: 260-351 www.wago.com/260-351 Commoning with comb-style jumper bar. Testing via test plug modules snapped onto a terminal strip – wired or unwired. As touch contact is made with the CAGE CLAMP® (spring steel) unit, this testing type is limited to maximum 0.5 A. Testing after the conductors have been terminated. Distance between locking devices must be approximately 35 … 40 mm! Marking Marking by direct printing (upon request). Marking with self-adhesive marking strips. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 8/8
260-351 价格&库存
很抱歉,暂时无法提供与“260-351”相匹配的价格&库存,您可以联系我们找货
  • 1+22.693781+2.93964
