Data sheet | Item number: 2606-1102/020-004
PCB terminal block; lever; 6 mm²; Pin spacing 7.5 mm; 2-pole; Push-in CAGE
CLAMP®; 6,00 mm²; black
www.wago.com/2606-1102/020-004
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/7
Dimensions in mm
L = (pole no. – 1) x pin spacing + 10.35 mm
Item description
PCB terminal blocks with levers and Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Intuitive and tool-free operation
Several clamping units can be held open simultaneously – convenient for terminating multi-core cables
Testing can be performed both parallel and perpendicular to conductor entry
Hansastr. 27
32423 Minden
07.10.2021 Page 2/7
Data
Notes
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Direct marking
Other colors
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
1000 V
Rated surge voltage (III/2)
8 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
8 kV
Rated current
41 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
CSA
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
31 A
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group C)
31 A
Approvals per
UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
31 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
31 A
Connection data
Number of connection types
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Lever
Solid conductor
0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 6 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 6 mm²
Hansastr. 27
32423 Minden
07.10.2021 Page 3/7
0.25 … 6 mm²
Fine-stranded conductor; with twin ferrule
0.25 … 2.5 mm²
Strip length
11 … 13 mm / 0.43 … 0.51 inch
Conductor connection direction to PCB
0 °
Pole No.
2
Physical data
Pin spacing
7.5 mm / 0.295 inch
Width
17.85 mm / 0.703 inch
Height
28 mm / 1.102 inch
Height from the surface
24 mm / 0.945 inch
Depth
24.3 mm / 0.957 inch
Solder pin length
4 mm
Solder pin dimensions
1.5 x 1.2 mm
Drilled hole diameter with tolerance
2 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (staggered)
Number of solder pins per potential
1
Material data
Color
black
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.017 MJ
Color of actuator
orange
Weight
8.2 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial
data
Hansastr. 27
32423 Minden
07.10.2021 Page 4/7
Commercial data
PU (SPU)
120 Stück
Packaging type
box
Country of origin
PL
GTIN
4055143924658
Customs tariff number
85369010000
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
CAD/CAE-Data
PCB Design
Symbol and Footprint 2606-1102/020-004
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
Hansastr. 27
32423 Minden
07.10.2021 Page 5/7
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2606-1102/020-004
URL
Download
PCB terminal block; lever; 6 mm²; Pin spacing 7.5 mm; 2-pole; Push-in CAGE CLAMP®;
6,00 mm²; black
Installation Notes
Conductor termination
Insert fine-stranded conductors and remove
all conductors via lever
Hansastr. 27
32423 Minden
07.10.2021 Page 6/7
Insert solid or ferruled conductors via pushin termination
Hansastr. 27
32423 Minden
07.10.2021 Page 7/7
很抱歉,暂时无法提供与“2606-1102/020-004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 35+24.89538
- 150+23.78301
- 500+22.65854
- 1200+21.71544
- 3600+20.77235
