Data sheet | Item number: 261-334/342-000
4-conductor terminal block; on both sides with push-button; suitable for Ex i
applications; with fixing flange; 1-pole; for screw or similar mounting types;
Fixing hole 3.2 mm Ø; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; blue
www.wago.com/261-334/342-000
i
Picture differs from the item.
Color:
Data
Electrical data
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
24 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
4
Total number of potentials
1
Number of levels
1
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/8
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Push-button, both side
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Pole No.
1
Wiring direction
Side-entry wiring
Physical data
Width
10 mm / 0.394 inch
Height from the surface
23.3 mm / 0.917 inch
Depth
28.1 mm / 1.106 inch
Mechanical data
Design
horizontal type
Mounting type
Mounting flange
Marking level
Side marking
Material data
Color
blue
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.079 MJ
Weight
4.4 g
Commercial data
Product Group
9 (Std. Chassis Mt. Blocks)
PU (SPU)
200 (50) Stück
Packaging type
box
Country of origin
DE
GTIN
4044918613446
Customs tariff number
85369010000
Approvals
/ Certificates
Hansastr. 27
32423 Minden
07.10.2021 Page 2/8
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60998
NTR-NL
6509
CCA
EN 60998
2110272.02
Approval
ABS
American Bureau of Shipping
19HG1869868PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
IEC 60998
91/20242
(E7)
Ship Approvals
Logo
Certificate
name
Required accessories
End plate
End plate
Item no.: 261-361
End plate; with fixing flange; gray
www.wago.com/261-361
Optional accessories
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
Hansastr. 27
32423 Minden
www.wago.com/210-658
07.10.2021 Page 3/8
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Mounting
Mounting accessories
Item no.: 209-123
Mounting foot with screw; can be screwed on terminal blocks with fixing flange; 6.4 mm wide; gray
www.wago.com/209-123
Item no.: 209-137
Mounting adapter; can be used as end stop; 6.5 mm wide; gray
www.wago.com/209-137
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Ferrule
Ferrule
Hansastr. 27
32423 Minden
07.10.2021 Page 4/8
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-205
Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow
www.wago.com/216-205
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Marking accessories
Marking strip
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Item no.: 261-402
Jumper; for conductor entry; 2-way; insulated; gray
www.wago.com/261-402
Jumpers
Jumper
Hansastr. 27
32423 Minden
07.10.2021 Page 5/8
Downloads
Documentation
Bid Text
261-334/342-000
Aug 17, 2017
doc
25.6 kB
Download
Feb 19, 2019
xml
3.4 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 261-334/342-000
URL
Download
WSCAD Universe 261-334/342-000
URL
Download
ZUKEN Portal 261-334/342-000
URL
Download
URL
Download
URL
Download
URL
Download
doc - Datei
261-334/342-000
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 261-334/342-000
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 261-334/342-000
applications; with fixing flange; 1-pole; for screw or similar mounting types; Fixing
Installation
Notes
Hansastr. 27
32423 Minden
07.10.2021 Page 6/8
Installation Notes
Installation
Assembling modular terminal blocks into
terminal strips.
Mounting an end plate.
Conductor termination
CAGE CLAMP® connection
Inserting a conductor.
Inserting a conductor via push-button.
With ferruled conductors, it is necessary to
use a terminal block one size larger than the
conductor's nominal cross-section.
Commoning
Hansastr. 27
32423 Minden
07.10.2021 Page 7/8
Commoning with comb-style jumper bar.
Marking
Marking by direct printing (upon request).
Marking with self-adhesive marking strips.
Hansastr. 27
32423 Minden
07.10.2021 Page 8/8
很抱歉,暂时无法提供与“261-334/342-000”相匹配的价格&库存,您可以联系我们找货
