Data sheet | Item number: 262-182
2-conductor terminal strip; without push-buttons; suitable for Ex e II
applications; with snap-in mounting feet; 2-pole; for plate thickness 0.6 - 1.2
mm; Fixing hole 3.5 mm Ø; 4 mm²; CAGE CLAMP®; 4,00 mm²; light gray
www.wago.com/262-182
i
Picture differs from the item.
Color:
Data
Electrical data
Rated voltage EN (Ex e II)
550 V
Rated current (Ex e II)
23 A
Connection data
Total number of connection points
4
Total number of potentials
2
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/10
Strip length
Pole No.
2
Wiring direction
Side-entry wiring
Physical data
Width
17 mm / 0.699 inch
Height from the surface
23.1 mm / 0.909 inch
Depth
33.5 mm / 1.319 inch
Module width
7 mm / 0.276 inch
Mechanical data
Design
horizontal type
Mounting type
Snap-in foot
Marking level
Side marking
Material data
Color
light gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.203 MJ
Weight
9.9 g
Commercial data
PU (SPU)
100 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918642019
Customs tariff number
85369010000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
AEx
UL International Germany GmbH c/o Physikalisch
Technische Bundesanstalt
UL 60079
E185892
ATEx
EN 60079
PTB 98 ATEX 3125
Physikalisch Technische Bundesanstalt (PTB)
Hansastr. 27
32423 Minden
U (II 2 G Ex eb IIC Gb
07.10.2021 Page 2/10
bzw. I M 2 Ex eb I
Mb)
CCCEx
CQST/CNEx
CNCA-C23-01
2020312313000186
EAC
Brjansker Zertifizierungsstelle
TP TC 012/2011
RU C-DE.AM02.B.
00127/19
IECEx
IEC 60079
IECEx PTB 04.0004
U (Ex eb IIC Gb or Ex
eb I Mb)
Country specific Approvals
Logo
Approval
Certificate
name
CSA
DEKRA Certification B.V.
C22.2
70010891
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
UL-Approvals
Logo
Optional accessories
Mounting
Mounting accessories
Item no.: 209-120
Mounting foot; can be snapped on terminal blocks with snap-in mounting foot; for mounting on relaymodules; 6.4 mm wide; gray
www.wago.com/209-120
Item no.: 209-137
Mounting adapter; can be used as end stop; 6.5 mm wide; gray
www.wago.com/209-137
Carrier rail
Hansastr. 27
32423 Minden
07.10.2021 Page 3/10
Item no.: 210-154
Aluminum carrier rail; 1000 mm long; 18 mm wide; 7 mm high; silver-colored
www.wago.com/210-154
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-108
Item no.: 216-109
Ferrule; Sleeve for 10 mm² / AWG 8; uninsulated; electro-tin plated
www.wago.com/216-109
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-110
Ferrule; Sleeve for 16 mm² / AWG 6; uninsulated; electro-tin plated; metallic brown
www.wago.com/216-110
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Ferrule
Ferrule
Item no.: 216-121
Hansastr. 27
32423 Minden
www.wago.com/216-121
07.10.2021 Page 4/10
Item no.: 216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-209
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; red
www.wago.com/216-209
Item no.: 216-205
Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow
www.wago.com/216-205
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-210
Ferrule; Sleeve for 16 mm² / AWG 6; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-210
acc. to DIN 46228, Part 4/09.90; blue
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-241
crimped; acc. to DIN 46228, Part 4/09.90; white
Hansastr. 27
32423 Minden
07.10.2021 Page 5/10
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-246
Item no.: 216-266
www.wago.com/216-266
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-286
www.wago.com/216-286
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-288
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288
Item no.: 216-289
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped;
www.wago.com/216-289
Hansastr. 27
32423 Minden
07.10.2021 Page 6/10
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
Item no.: 216-302
www.wago.com/216-302
Item no.: 262-402
Jumper; for conductor entry; 2-way; insulated; gray
www.wago.com/262-402
Jumpers
Jumper
Marking accessories
Marking strip
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Downloads
Documentation
Bid Text
262-182
Aug 17, 2017
doc
25.1 kB
Download
Feb 19, 2019
xml
3.2 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
doc - Datei
262-182
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAE data
EPLAN Data Portal 262-182
Hansastr. 27
32423 Minden
07.10.2021 Page 7/10
WSCAD Universe 262-182
URL
Download
ZUKEN Portal 262-182
URL
Download
URL
Download
URL
Download
CAD data
2D/3D Models 262-182
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 262-182
2-conductor terminal strip; without push-buttons; suitable for Ex e II applications; with
snap-in mounting feet; 2-pole; for plate thickness 0.6 - 1.2 mm; Fixing hole 3.5 mm Ø;
Installation Notes
Conductor termination
CAGE CLAMP® connection
Inserting a conductor.
Commoning
Hansastr. 27
32423 Minden
07.10.2021 Page 8/10
Commoning with comb-style jumper bar.
Installation
Mounting a terminal strip with snap-in feet
into holes.
onto aluminum rail.
Terminal strip with snap-in mounting feet
Snapping a mounting foot (209-120).
(Distance between mounting feet: approx. 25
… 30 mm)
Terminal strip; with snap-in mounting feet;
for DIN-35 rail
Hansastr. 27
32423 Minden
07.10.2021 Page 9/10
Terminal strip with snap-in mounting feet, for
0.6 … 1.2 mm plate thickness, 3.5 mm
mounting hole diameter (also for 210‑154
Aluminum Rail or with 209‑120 Mounting
Foot for DIN-35 rail)
Marking
Marking by direct printing (upon request).
Marking with self-adhesive marking strips.
Hansastr. 27
32423 Minden
07.10.2021 Page 10/10
很抱歉,暂时无法提供与“262-182”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+60.075581+7.80963
