2616-1104/020-000
2616-1104/020-000
    WAGO(万可电子)
    4 接线板 - 线至板 水平,带板 0.394"(10.00mm) 通孔
2616-1104/020-000 数据手册
| : 2616-1104/020-000 PCB terminal block; lever; 16 mm²; Pin spacing 10 mm; 4-pole; Push-in CAGE CLAMP®; 16,00 mm²; gray https://www.wago.com/2616-1104/020-000 : Dimensions in mm L = (pole no. – 1) x pin spacing + 12.8 mm gray • • • • • PCB terminal blocks with Push-in CAGE CLAMP® connection and levers Push-in termination of solid and ferruled conductors Intuitive and tool-free operation Several clamping units can be held open simultaneously, simplifying the connection of multi-core cables Testing can be performed both parallel and perpendicular to conductor entry Notes Variants: Other pole numbers Direct marking Other colors Other versions (or variants) can be requested from WAGO Sales or configured at https:// configurator.wago.com/. . Electrical data Ratings per IEC/EN Ratings per IEC/EN Ratings per IEC/EN 60664-1 Rated current 76 A Nominal voltage (III/3) 1000 V Legend (ratings) Rated impulse voltage (III/3) 8 kV (III / 2) ≙ Overvoltage category III / Polluti­ on degree 2 Rated voltage (III/2) 1000 V Rated impulse voltage (III/2) 8 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 8 kV Seite 1/4 . Stand: 17.08.2022 Fortsetzung nächste Seite ›› | : 2616-1104/020-000 https://www.wago.com/2616-1104/020-000 Ratings per UL Ratings per CSA Approvals per UL 1059 Approvals per CSA Rated voltage UL (Use Group B) 600 V Rated voltage CSA (Use Group B) 600 V Rated current UL (Use Group B) 66 A Rated current CSA (Use Group B) 66 A Rated voltage UL (Use Group C) 600 V Rated voltage CSA (Use Group C) 600 V Rated current UL (Use Group C) 66 A Rated current CSA (Use Group C) 66 A . . Connection data Total number of connection points 4 Connection 1 Total number of potentials 4 Connection technology Push-in CAGE CLAMP® Number of connection types 1 Actuation type Lever Number of levels 1 Solid conductor 0.75 … 16 mm² / 18 … 4 AWG Fine-stranded conductor 0.75 … 25 mm² / 18 … 4 AWG Fine-stranded conductor; with insulated ferrule 0.75 … 16 mm² Fine-stranded conductor; with uninsula­ ted ferrule 0.75 … 16 mm² Fine-stranded conductor; with twin ferru­ le 0.75 … 6 mm² Strip length 18 … 20 mm / 0.71 … 0.79 inches Conductor connection direction to PCB 0° Pole number 4 . . Physical data Pin spacing 10 mm / 0.394 inches Width 42.8 mm / 1.685 inches Height 37.2 mm / 1.465 inches Height from the surface 33.2 mm / 1.307 inches Depth 32 mm / 1.26 inches Solder pin length 4 mm Solder pin dimensions 1.2 x 1.2 mm Drilled hole diameter with tolerance 1.7 (+0.1) mm . PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip (staggered) Number of solder pins per potential 3 . Material data Note (material data) Information on material data can be found here Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating Tin Fire load 0.38 MJ Actuator color orange Weight 37.6 g . Seite 2/4 Stand: 17.08.2022 Fortsetzung nächste Seite ›› | : 2616-1104/020-000 https://www.wago.com/2616-1104/020-000 Environmental requirements Limit temperature range -60 … +105 °C Processing temperature -35 … +60 °C . Commercial data eCl@ss 10.0 27-44-04-01 eCl@ss 9.0 27-44-04-01 ETIM 8.0 EC002643 ETIM 7.0 EC002643 PU (SPU) 25 Stück Packaging type Box Country of origin VKOrg Germany PL GTIN 4055143707398 Customs tariff number VKOrg Germany 85369010000 . Approvals and certificates Country specific Approvals UL-Approvals CB DEKRA Certification B.V. EN 60947-7-4 NL-61617 CSA DEKRA Certification B.V. C22.2 70154737 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71-110774 cURus Underwriters Laboratories Inc. C22.2 No. 158 E45172 . . Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 2616-1104/020-000 . Documentation Additional Information Technical Section 03.04.2019 pdf 1949.09 KB . Seite 3/4 Stand: 17.08.2022 Fortsetzung nächste Seite ›› | : 2616-1104/020-000 https://www.wago.com/2616-1104/020-000 CAD/CAE-Data CAD data CAE data 2D/3D Models 2616-1104/020-000 ZUKEN Portal 2616-1104/020-000 . . 1 Compatible products 1.1 Optional accessories 1.1.1 Ferrule 1.1.1.1 Ferrule : 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; in­ sulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black : 216-289 Ferrule; Sleeve for 10 mm² / AWG 8; insu­ lated; electro-tin plated; electrolytic cop­ per; gastight crimped; acc. to DIN 46228, Part 4/09.90; red : 216-287 Ferrule; Sleeve for 4 mm² / AWG 12; insu­ lated; electro-tin plated; electrolytic cop­ per; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray : 216-288 Ferrule; Sleeve for 6 mm² / AWG 10; insu­ lated; electro-tin plated; electrolytic cop­ per; gastight crimped; acc. to DIN 46228, Part 4/09.90; yellow : 216-210 Ferrule; Sleeve for 16 mm² / AWG 6; insu­ lated; electro-tin plated; electrolytic cop­ per; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue . Installation notes Conductor termination Insert fine-stranded conductors – and re­ move all conductors – via operating tool. . Conductor termination Insert solid conductors via push-in termi­ nation. . Änderungen vorbehalten. Bitte beachten Sie auch die weitere Produktdokumentation! Adressen finden Sie unter: w w w.wago.com Seite 4/4 Stand: 17.08.2022 : 216-286 Ferrule; Sleeve for 2.5 mm² / AWG 14; in­ sulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue
2616-1104/020-000 价格&库存
很抱歉,暂时无法提供与“2616-1104/020-000”相匹配的价格&库存,您可以联系我们找货
2616-1104/020-000
  • 1+106.033981+13.15347
  • 10+84.8126710+10.52098
  • 25+80.6053325+9.99906
  • 50+78.3257550+9.71628
  • 100+76.61279100+9.50379
  • 250+74.98564250+9.30194
  • 500+74.10474500+9.19266
  • 1000+73.807231000+9.15576
库存:99
