Data sheet | Item number: 2626-1101/000-006
PCB terminal block; 6 mm²; Pin spacing 7.5 mm; 1-pole; Push-in CAGE
CLAMP®; 6.00 mm²; blue
www.wago.com/2626-1101/000-006
i
Picture differs from the item.
Subject to changes. Please also observe the further product documentation!
WAGO Corporation
Germantown, WI 53022
Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.us
Do you have any questions about our products?
We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL.
08.12.2021 Page 1/7
Dimensions in mm
L = 9.3 mm
Item description
PCB terminal strips with Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Ideal for panel feedthrough applications via operation parallel to conductor entry
Testing can be performed both parallel and perpendicular to conductor entry
WAGO Corporation
08.12.2021 Page 2/7
Data
Notes
Note
The inherent stability of a single-pole PCB terminal block is less than
that of a multipole terminal strip. It is therefore necessary for the
customer to ensure, for example by additional support, short
interception of the connected conductor and corresponding
handling instructions for actuation, that this terminal block is
protected against excessive mechanical stress, for example
torsional or bending stress, during conductor connection and in use.
Variants:
Other pole numbers
Direct marking
Other colors
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
IEC Approvals
Ratings per
IEC/EN 60664-1
Rated voltage (III / 3)
1000 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
1000 V
Rated surge voltage (III/2)
8 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
8 kV
Rated current
48 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
UL Approvals
Approvals per
UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
38 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
38 A
CSA Approvals
Approvals per
CSA
Rated voltage CSA (Use Group B)
600 V
WAGO Corporation
08.12.2021 Page 3/7
600 V
Rated current CSA (Use Group B)
38 A
Rated voltage CSA (Use Group C)
1000 V
Rated current CSA (Use Group C)
38 A
Connection data
Total number of connection points
1
Total number of potentials
1
Number of connection types
1
Number of levels
1
Connection 1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 6 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 6 mm²
Fine-stranded conductor; with twin ferrule
0.25 … 2.5 mm²
Strip length
13 … 15 mm / 0.51 … 0.59 inch
Conductor connection direction to PCB
0 °
Number of poles
1
Physical data
Pin spacing
7.5 mm / 0.295 inch
Width
9.3 mm / 0.366 inch
Height
23.6 mm / 0.929 inch
Height from the surface
19.6 mm / 0.772 inch
Depth
24.2 mm / 0.953 inch
Solder pin length
4 mm
Solder pin dimensions
1.5 x 1 mm
Drilled hole diameter with tolerance
2 (+0.1) mm
Mechanical data
Mounting type
Feed-through mounting
PCB
contact
WAGO Corporation
08.12.2021 Page 4/7
PCB contact
PCB Contact
THT
Solder pin arrangement
Over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Note on material data
Information on material data can be found here
Color
blue
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
Tin-plated
Weight
4.6 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
PU (SPU)
200 Pieces
Packaging type
box
Country of origin
PL
GTIN
4055144059731
Customs tariff number
85369010000
Optional accessories
Ferrules
Ferrule
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-108
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-266
WAGO Corporation
08.12.2021 Page 5/7
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
acc. to DIN 46228, Part 4/09.90; gray
Tools
Operating tool
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-721
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
URL
Download
CAD files
CAD data
2D/3D Models 2626-1101/000-006
CAE data
ZUKEN Portal 2626-1101/000-006
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2626-1101/000-006
PCB terminal block; 6 mm²; Pin spacing 7.5 mm; 1-pole; Push-in CAGE CLAMP®; 6.00
mm²; blue
Installation Notes
Conductor termination
WAGO Corporation
08.12.2021 Page 6/7
Insert fine-stranded conductors and remove
all conductors via operating tool
Insert solid or ferruled conductors via pushin termination
WAGO Corporation
08.12.2021 Page 7/7
很抱歉,暂时无法提供与“2626-1101/000-006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+35.134461+4.56582
